Question about HP LaserJet M5035 MFP Printer
41.3 unexpected paper size error in tray 2,3,4
  • 26 Answers
SOURCE: Iam facing in hp 4050 printer,when i have giving
swap trays and test - if OK then your tray is set up wrong. remove paper and check that it is set for letter. also check the small switch (if there is one) on the Right hand side of the tray that maybe set to customer - change to standard. compare trays so they look the same - and check the settings in the menu for letter / plain on both trays
Posted on Jul 24, 2009
  • 14 Answers
SOURCE: try printing from tray 2 using letter size paper
check the paper size in the printer driver settings.
this should also be set to letter.
Posted on Oct 29, 2009
  • 744 Answers
SOURCE: I want to print from
Assuming the printer is otherwise working ok and we are talking about a Windows operating system....
When you choose the Print command from the drop-down menu in your application, instead of just proceeding, choose "Properties" or "Preferences" in that window. This should open up another dialog window from which you can choose additional printing options. It may be under Advanced or Tray Select, etc.
You can also get to the printer dialog windows by clicking on the Start button, then Settings, then Printers and Faxes, then double-clicking on the printer icon in that window for your printer and proceeding from there.
Posted on Jan 02, 2010
  • 150 Answers
SOURCE: hp 4000N 41.3 unexpected paper size
Clean the sep. rollers one in the paper tray and one inside the paper tray port. Then clean the feed roller. Its behind the sep roller in the paper tray port. You must look close with a flash light. It has 4 D feed rollers. It will rotate down to clean them do not knock the spring off. Use only water on a cloth no alcohol. Steven 818-888-0006
Posted on Mar 11, 2010
SOURCE: I want to print from Tray 2 where I have letter
You cannot do that it is "Hardwired" in the printer.
Posted on Mar 20, 2010
Unexpected paper size in tray 2.the paper in tray 2 is legal size..8.5 x 13 custom size in philippines..
Papers come in different standards across the world. This size is neither US nor metric. You will need to set the printer for custom-size paper and enter the dimensions.
Oct 13, 2011 | HP LJ 4100 Series Black toner 6K Printer
41.3 unexpected size in tray 2.my printer is hp laserjet 4200.can you solve this
Thank you for contacting FixYa with your printer Inquiry.
41.3 Unexpected Paper Size Explanation
  • The printer detected a paper size different than what it was expecting.
  • This is typically caused if two or more sheets stick together in the printer, or if the paper tray is not properly adjusted.
Recommended action
  1. Reload the tray with the correct paper size.
  2. Ensure that paper in the tray is loaded under the front and back tabs.
  3. When printing from tray 1, verify that the correct paper size is selected in the control panel (see the Paper Handling Menu section in the User Guide ).
  4. When printing from tray 2, 3, or 4, verify that the three paper size adjustments on the paper tray have been made correctly (see the description of adjustments in the section on Loading Trays 2, 3, and 4 in the User Guide ).
  5. After performing the actions above, press GO. The page containing the error will automatically be reprinted if jam recovery is enabled. Or, press CANCEL JOB to clear the print job from the printer's memory.
    Hope this helps. Please keep us updated and remember to rate this answer.
Feb 07, 2011 | HP LaserJet 2420 Printer
Printer says 41.3 unexpected size in tray 2. How do I fix this?
A couple of things to check.
1) Make sure the paper guides in the tray are adjusted correctly for width and in particular the length. 2) Remove the tray completely check guides. 3) Make sure the tray is fully seated into the printer. 4) Make sure the paper in the tray matches the size of the guides.
If the guides and paper seem OK, the printer may need servicing by authorized service center.
41.3 UNEXPECTED SIZE IN TRAY [xx] alternates with LOAD TRAY [xx]: [type] [size] Description This is typically caused if two or more sheets stick together in the printer or if the tray is not properly adjusted.
Jan 14, 2011 | HP LaserJet 2420 Printer
My printer keep saying "
The unexpected paper size may cause the above error. Whenever your printer detects an abnormal size, this error appears on the device. It mainly happens when more than one sheet are attached with each other or when the paper trays are not set properly. To handle this issue, reload the trays with appropriate paper size followed by front and back tabs. For all the trays verify that correct paper size adjustments have been done. Now enable the jam recovery button and press the button 'GO' to print your document.
Nov 09, 2010 | Office Equipment & Supplies
My printer as problem in getting the paper
Oct 22, 2010 | HP DeskJet F4280 All In One Printer InkJet
Hp2840 printer error "Too large to print" even with a very small file.
http://www.fixya.com/support/t6355639-hp_2640_half_right_side_page
Oct 08, 2010 | HP LaserJet 2840 Printer
Hp 4000N 41.3 unexpected paper size
Mar 11, 2010 | HP Office Equipment & Supplies
HP COLOR LASREJET 3500 41.3 ERROR
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
RK2-0247-000CN
chris
May 27, 2009 | HP Color LaserJet 3500 Printer
Hp 4000n
page size of doc getting sent to printer, file, page settup, page size/papersize is set different than printers tray size via keyboard on printer, ie tray size.
Dec 09, 2007 | Office Equipment & Supplies
HP LaserJet M5035 MFP Printer Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
