Question about Lexmark X6170 All-In-One InkJet Printer
Blank page printer sounds like it is printing but page comes out blank. new ink still nothing. tried uninstalling and reinstalling, unplugging, rebooting, will show scan picture but will not print. thanks for your help
  • nubian_hime Nov 19, 2008
    Hi I checked the hardware-- no error, the inks are new, the printer operates, but it still prints blank pages (even during test page)
  • j3hs Nov 25, 2008
    sounds as if printing, but no ink on page. New cartridges, etc. Says both are missing. Shows 'hardware error 0504'. Owner's manual does not show this error. Any help would be greatly appreciated. Thanks.
    Sergeant:
  • 390 Answers
Hello, hope i can help. Glad you tried all these things. Sorry they did not help. Is the printer set as the defaukt printer in your settings. Sometimes this can be the isue. You should have an icon for your printer in my computer. Right click on it and go to properties. Is the printer set to work offline?? This can affect printing too. If this does not help, you need to check if it is installed correctly by going to control panel, selecting system, then hardware, then device manager for printer and scroll down list and make sure it says it is working correctly, with no exclamation marks or errors. If you find some, you need a new driver from lexmark website. If no errors, we need to look at further issues then. Good luck, post back if not resolved please. Cheers lilacgerry
Posted on Oct 28, 2008
Epson Stylus CX3800 won't print, just prints blank pages?
the fact that U havent used it alot is the problem the printheads are clogged with dried ink, you need to do a printhead cleaning (or Several) There should be an INK button on the printer press that and scroll through the options till you find cleaning or maintenance and do a nozzle check after each cleaning to see if U are making progress. If there is no INK button then look for maintenance in the printer properties
Apr 13, 2014 | Epson Stylus CX3800 Printer
Paper feeds through the printer but nothing prints. I thought I was out of ink, so bought new black ink and replaced it. The first page printed but the next sheets came out blank. It was making noise...
the problem will be on the cartridge reader. you should see if the ink disposal system is running as fluid as possible.
Check on the driver also, uninstall then reinstall it back.
Mar 14, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Only printing blank pages. Sounds like its printing but pages are blank.
Try to reset by remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts or a faulty printing head.
Sep 30, 2010 | Lexmark Z600 InkJet Printer
I455 printing totally blank pages
Don't know that particular model but try this.
Sounds like the lines are a bit plugged and are running dry again after the script page.
Never leave an inkjet or deskjet for more than a week or so without using it because the ink wells can dry up.
Take a Q-tip and dip it in alcohol.
Remove the cartridges and soak each hole with a brand new Q-tip.
Let it dry.
You may have to do this a few times before you get results.
Now put in the cartridges.
Go to
Start
Control Panel
printers
Click on your printer
Go to Properties
Go to Maintenace
There should be some kind of thing in there that will allow you to clean and deep clean your cartridges.
I have recovered many "seemingly hopeless" printers this way. A lot of printers that can be rescued end up in e-waste, wasting a lot of money.
Look in the yellow pages and find you local dealer if all else fails. These people are often quite helpful.
Sep 24, 2009 | Canon i455 InkJet Photo Printer
Printing blank pages
Try another ink tank before you start looking for more sinister problems
Sep 01, 2009 | Dell 926 All-In-One InkJet Printer
Photosmart 7960 prints blank documents; prints from internet ok
If it can print from the internet, it is working properly. I would disconnect the printer from the computer, uninstall the drivers and reboot twice. Reinstall the drivers and hook up the printer when instructed. Make sure that you select this as the default printer. (unless, of course, you have another as default)
Jul 24, 2009 | HP PhotoSmart 7960 InkJet Printer
Canon iP90 only prints blank pages
Remove the printer from control panel, under installed printers, then unplug the usb cable and reinstall the printer drivers using printer cd, or download from canon support website.
Apr 27, 2009 | Canon PIXMA iP90 InkJet Printer
I have a 1320 printer that just prints blank pages
If ink is ok , then you may need to reinstall printer drivers.
Unplug printer USB.
Go to control panel>>Installed printers and delete existing printer installation.
Reinstall printer driver software using printer CD.
Mar 02, 2009 | HP Laser Jet 1320 Printer
Print page comes out blank
If the cartridges are old too this may be a problem. When ink gets old it can clog the cartridges. If they are old replace them with new ones. If they are new ones did you peel the protective covering off before you inserted the cartridges? Hopes this helps
Sep 16, 2007 | HP DeskJet 952c InkJet Printer
Lexmark X6170 All-In-One InkJet Printer Logo
156 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
