Question about GPS
Trying to set navigation path on igo8 gps empress
4 Suggested Answers
SOURCE: 2 navlinks with the same problem
Hey Guys
Found a patch that fixes this issue
Applied it to both my Navlinks and both are working fine now
Attached is the link
http://www.navsupport.net/gps/quickfix/index.html
hope this helps anyone else
Posted on Jun 20, 2009
ZJLimited
  • 17970 Answers
SOURCE: navigation path not setting up. on screen message,
I quote this write-up form GPS site...
I have recently installed iGO8 on 2 GPS units - one a Soniq Qnav QNG400 and the other an unbranded unit bought on ebay that had a timed lock on it. Both required slightly different installations that I will share here, to show appreciation for the useful discussions that helped me to successfully install iGO8 on both units.
DISCLAIMER: Do this at your own risk. If you render your GPS unit an expensive paperweight, do not blame me. The first thing that I recommend is BACK UP your files (SD card) before making any changes.
Firstly, I downloaded the iGO8 program and map files (other threads on this site have links to these files, which are updated fairly regularly, so I won't repeat them here).
Soniq Qnav QNG400:
This was given to me as a promotional gift. It came installed with Destinator software and the Australian map was a 2006 version from Sensis, which is dated and forced me to look for more recent maps. iGO8 was my choice.
What I was able to do was connect the unit to my Vista PC via USB. It allowed me to navigate the entire file system, including the internal flash memory. The flash memory contained a file that pointed to the navigation software executable:
\MyFlashDisk\DestinatorApps\DShell\Schema\Schema.i ni (took a while to work out the importance of this file)
1. Back up existing SD card files to your PC if you plan to use the same SD card.
2. If you haven't done step 1, don't go any further
3. Remove all files on the SD card. On mine, it had a directory 'DestinatorApps\Australia' with the map, poi etc. files in there and nothing else.
4. Copy the un-rar'ed or un-zipped iGO8 files to the SD card, using the same directory structure. There should be one folder called iGO8 in the root and under that the iGO8 executable, .dll's, sys.txt file and other folders.
5. The map, poi, language, etc. files should go in their respective folders under \iGO8\content. That is:
- map file(s) in \iGO8\content\map
- poi file(s) in \iGO8\content\poi
- language file(s) in \iGO8\content\lang etc.
6. Connect the GPS unit to your PC and open the Schema.ini file (location given above). There is a section titled [DestinatorBtn], which defines the program that will be executed when the navigation option is selected from the startup menu screen (at least on the Qnav QNG400 running Destinator software). The 'Action' parameter defines the location of the executable. Below is the relevant section with the original Action commented out and the iGO8 executable (on the SD card) defined.
[DestinatorBtn]
Rectangle=0,206,125,62
CaptionRectangle=8,240,111,30
Caption=TxtDestinator
Font=FontDestinator
Color=0,0,0
; Left button -------------
; Original Destinator application (located in internal flash memory)
;Action=\MyFlashDisk\DestinatorApps\Destinator\Des tinator.exe
; iGO8 application (located on SD card)
Action=\SDMMC\iGO8\iGO8.exe
The above details indicate that the original SD card only contained the map files (which explains its relatively small size of 128MB). The application software (Destinator.exe) is in the flash memory. What this means is that without access to the flash memory (to modify the schema.ini file as above), it would be difficult to install/use different navigation software and maps.
7. That's it. Go to the 'Testing' section below.
Unbranded GPS device:
A locked GPS unit was given to me to check out (i.e. try and unlock and/or install iGO8). The navigation software (trial version) was due to expire at the end of this month. It came with basic MobileNavigator software and an Australian Route66 map on a 1GB SD card without TTS capability.
When connected to my Vista PC or an XP SP2 PC, only the SD card files were visible. There was no easy way of accessing any internal files like I was able to do on the Qnav.
This unit required a slightly different installation procedure:
2. If you haven't done step 1, don't go any further.
3. Remove all files on the SD card except 'GpsShell.ini' in the root (specific to MobileNavigator I think). If you delete this, you can copy it from the backup you made in step 1.
4. Copy the un-rar'ed/un-zipped iGO8 files to the SD card, using the same directory structure. There should be one folder called iGO8 in the root and under that the iGO8 executable, .dll's, sys.txt file and other folders.
6. The sys.txt file may need changing, but the one I used contains:
[folders]
app="%SDCARD%/MobileNavigator"
[interface]
maxzoom2d=6000000
show_exit=1
skin="ui_igo8"
vga=0
[debug]
skip_eula=1
[msnd]
msnd.start=0
Note the app directory "%SDCARD%/MobileNavigator". This will be explained after step 7.
7. Since the internal flash memory was not accessible, the button on the GPS unit's main menu that runs the navigation software looks for (and expects) MobileNavigator.
To overcome this:
7a. Rename the 'iGO8.exe' file (in the \iGO8 folder) to 'MobileNavigator.exe'
7b. Rename the root 'iGO8' folder to 'MobileNavigator'
This basically tricks the unit into thinking that MobileNavigator (and associated maps) are installed, when in actual fact it is iGO8 that will be running.
It is also why it is important to set the app folder correctly in the \iGO8\sys.txt file mentioned in step 6.
8. The original card came with an .ini file called 'GpsShell.ini'. This should be copied (from the backup) to the root of the new SD card, otherwise it may not work. I've seen other posts mentioning similar files such as 'shell.ini'. Finding the correct file may require some trial and error for other devices/software, although there would not normally be many .ini files in the root location.
Testing:
That pretty much completes the setup and necessary changes. Insert the SD card into the GPS (if it isn't already) and select the navigation option. If all is well, iGO8 should start, possibly with a few option screens for language etc. and then into the main navigation menu.
I hope this information helps others who need to do similar mods to their GPS/mapping software.
The above ideas should be usable for other units and map software as long as the necessary configuration files have the correct settings and, if necessary, directory and executable file are renamed according to the original software.
Hope this helps; keep us updated
Posted on May 19, 2011
gopakumarg43
  • 75311 Answers
SOURCE: I have an igo8 car gps.when i turn it on selecting
Hello
Select the written language of the application interface.
Menu => Settings => Regional
[#] Program Language
This button displays the current written language of the iGO My Way 8user interface. By tapping the button, you can select a new language from the list of available languages. The application will restart if you change this setting; you are asked to confirm this.
[#] Set Date & Time Format
You can set the date and time format. Various international formats are available
[#] Time and Time Zone Settings
You can access time and time zone settings. iGO My Way 8 helps you with correcting the device time to the ever accurate GPS time. iGO My Way 8 can also help you set the time zone based on your current GPS position
[#] Units
You can set the distance units to be used by the program. iGO My Way 8 may not support all the listed units in some voice guidancelanguages. If you select a measurement unit not supported by the chosen voice guidance language, a warning message will appear
OK.
Posted on Sep 10, 2011
When I pull up the gps for directions it says it cannot find program. Please set Gps path in file. What do I do to fix it.
Set GPS Path ..
On your Sylvania GPS go to System Setting > GPS Path .This function is to set GPS path for your navigation. Screen display will show asfollows:
File folders of TF card will be listed on screen. Click a folder to open it. Select GPSSoftware If there are two or more maps from different companies on an TF card, then thisfeature can help you select each of them easily. The way to Select: :In TF card directory,open the file folder to find the map to be used, select navigation software of .exe,(whichhas different names from each different company), then select andclicK 10_3_2011_2_45_46_am.gif icon, a dialogue frame will pop up on screen, as it shown below:
Click the accept icon to accept.
Click X icon on the upper right corner to return to GPS path interface.
Oct 03, 2011 | Sylvania SGPD430 GPS Navigator
By pressing Navigation I am ask Please set Navigation Path.I have not idea what to do next.
On my GPS, I scrolled down to and pressed Navi Path, then turned on "Auto run GPS when starting", then set the Navigation Path to Resident\.........\iGO8. It then worked ok.
Aug 11, 2011 | GPS
Go Cruise S350 from ''Tempo'' in Sydney will not connect to route 66 and cannot be upgraded. Looks like driver problems ,I am using Win XP/2 Any ideas??
I bought a Go Cruise S350 from ebay first locked up when I did the install following prompts (GPS told me I had lost 2 ? resource files) told seller he swapped for another and it did the same both had Route 66 on them neither would finish the update installs and that was the end of it trying to connect. So I dragged out my other GPS (Orange Cool G350M I bought in Paraguay Jan 2010) It uses IGO8 as its mapping system (but only had Brazil and Argentinian maps which was ok when there) Both use Windows CE as there platforms so did some googling and found this site
http://www.austech.info/igo/33277-ultimate-new-igo8-thread-hollowman-feb-2010-a.html worth it to register and read that page and look at other threads.
I now have the IGO8 on the Go Cruise S350 instead of Route 66
Also have Brazil and Argentina plus Australia on BOTH units now.
Use a card reader for the sd card and back up whatever is on the unit before you add IGO8.
Good luck and worth the effort.
Jan 19, 2010 | GPS
Hey Guys
Jun 20, 2009 | GPS
My navlink gps says "not find navigation software"
If you haven't already fixed this; try going into, settings, navsetup, - this should give a Path of navigation software line, this line should read: '\StorageCard\iGO8\iGO8.exe' click on file icon at end of the path window "select storage card, select iGO8.exe, select tick to apply then exit.
This works for mine but I assume that if an alternative software is shown in the path window you must choose an approppriate .exe file in the storage card files.
Oct 28, 2008 | GPS
Maps for sony navu-73t
I inquired of Sony about map updates for my navu-73T after realizing several routes took me way out of the way. I was told "Unfortunately, map updates are not available for your Sony GPS Navigation System at present. If available, it can be purchased from our Parts and Accessories Sales Web site or from the Sony Style Web site. " They provided this site:
http://servicesales.sel.sony.com/ecom/accessories/web/index.jsp
Jul 03, 2008 | Sony nav-u NV-U70 GPS Receiver
Install european maps
What is the GPS make and model
May 01, 2008 | GPS
Tom tom cannot detect GPS signal
Install another navigation software (iGO8, Navigon, Destinator, OziExplorer, etc....) and check you problem again.
If you need help or professional GPS-consultation or unlock you PNA, update navigation maps - please ask
http://www.goodslowprice.com/en/unlock.htm
Apr 29, 2008 | GPS
Problem with gps not connecting.
I have Google maps for Mobile working on Mio P550 with GPS Program Port: COM9.
GPS Hardware Port to COM2, baud rate 4800.
http://blogs.msdn.com/windowsmobile/archive/2006/06/07/620387.aspx
Dec 24, 2007 | GPS
GPS Logo
214 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
