Red light on haier le42b1380
Bought tv, took tv home, pluged in tv, turned on xbox, tv turns off, we turn tv back on, tv shuts off and then flashes red light, tv wont turn back on. Sad need help whats wrong with it? Please Help..
SOURCE: technika tv
any joy ?
am having the same problem !
Posted on Aug 20, 2008
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
SOURCE: TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Posted on Feb 23, 2009
skotkolr
  • 558 Answers
SOURCE: akia 27 inch tv wont turn on
Power packs can be repaired, and most time it is simply capacitors. I don't charge an arm and a leg
Posted on Apr 05, 2009
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
Posted on Jun 10, 2009
Samsung ln46c530 lost picture, now won't turn on. Indicator light turns on solid red when on, flashes five times when shut off
The fault is with its main board itself. Troubleshooting to this board is not an easy work to a user can do. It will be best to contact any service technician. google.com/+GopakumarGopalan
Nov 24, 2013 | Samsung LN46C530 TV
My flat screen tv dont turn on
Hey,
My TV had the same problem. From my experience try when turning the TV on changing the TV channel on the TV not the remote.
Jul 26, 2009 | Proscan PS27500 27" TV
TV SHUT OFF WHILE WATCHING. UNPLUG AND THEN PLUGED BACK IN. RED LIGHT CAME ON IN FRONT FOR A SECOND AND WENT BACK OFF. TV WILL NOT COME ON.
power in the tv has nothing related with the DVD. The tv has to have raster (white screen) even without signal (cable, DVD, others) if the tv alone is just having the led flashing and neither sound nor video (black screen) The tv has a short circuit in some of the boards that are part of the tv system. the blinking is part of a protection when the tv was created in the factory. Refer to the technician to repair this problem.
Apr 14, 2009 | Hitachi 61SBX59B 61" Rear Projection...
Red light blinking on front of xbox 360
How many red lights flashed? One, or three?
One means that your harddrive isn't seated correctly.
Three means that your console is more or less screwed, and needs to be repaired by Microsoft.
Apr 10, 2009 | Microsoft Xbox 360 Arcade
Thier is the red light that is shown instead of green
You have a problem with your hardware. This happens to about 30% of xbox's over time. It is called the red ring of death. You need to reflow the solder under the GPU chip to fix it, find an xbox repair place on ebay.com
Mar 23, 2009 | Computers & Internet
Xbox 360 power brick turns rd when connected to console
When the light turns red that means the power brick is to hot.
Dec 26, 2008 | Microsoft Xbox 360 Console
No picture or sound on the tv
where you put the cables for the sound and picture if you look on the end where you plug it into the xbox 360 you will see a little switch it has HD and TV on it depending on what your tv supports (HD ready TV) (normal TV) switch that switch to what TV you have (e.g. HD TV, switch the switch to HD) if that doesnt work then try checking that you have all the cables in the right ports if you have pluged the HD cables into a normal TV then this is not going to work, check cables and check the switch!
Jun 05, 2008 | Microsoft Xbox 360 Console
Remote codes
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Sep 09, 2007 | Haier HTF20R21 20" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Electro Med Services...
