Question about Karcher K DS 5500 Vacuum
Noisy motor and bad smell - Karcher K DS 5500 Vacuum
Burning smell and noisy motor
burning smell is over heating motor --could be bearings but if it is an old machine it could be the impeller blades that create the vacuum are loose --noise and that is loading up the motor
unless it is a new and expensive vacuum cleaner you could take it in to an appliance repair shop for a quote or if old simply junk it and get a new one
May 09, 2016 | Vacuums
How do I check my hoover floormate deluxe spinscrub's filter and motor? Thanks in advance!!
The filter is at the top of the recovery tank (dirty water tank), should be replaced when dirty or odors occur. as to your motor, there is no way for an end user to remove any cover and check it. If you are experiencing noise, have it checked by an authorized service center.
Oct 20, 2014 | Hoover Vacuums
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Smelled burned wire, then motor just slowly died. Upright Windtunnel 2.1 bagged
I suspect it's the motor you smelled and not a wire. To find out for sure, you can either remove the motor and smell it (bad odor means bad motor) or take it to a repair shop and let the repair tech check it out.
Jan 26, 2011 | Hoover U6630-900 WindTunnel Bagless...
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Numatic gve370 canister wet/dry motor gone noisy
Try blowing out the motor housing with commpressed air through the cooling vents as it is running, if that dont quiet it down it may be the bearings are dry and need to be oiled, use 20w 3 in 1 oil in the blue container.
Nov 11, 2009 | Numatic GVE370 Canister Wet/Dry Vacuum
My eureka capture is very noisy
check belt whistling may be something in hose
Aug 12, 2009 | Eureka 2971AV EZ Kleen Bagless Upright...
Wind tunnel supreme sounds very loud
Sounds like a bad motor, you have a years warranty on this, take it in for warranty repair. You will void the warranty if you mess with it.
May 08, 2008 | Vacuums
My vampyr 5040 vacuum has lost suction and is starting to smell. can it be fixed economically?
Lose of suction can be from a clog in the hose, dirt inlet by the brush roll, or the motor running slow. A smell, depends which, if a rubber smell, then could be a bad belt and/or brush roll. An electrical smell, could be the motor going bad, if it is the motor, it will need to be replaced.
Apr 23, 2008 | Vacuums
Very noisy
Usually when the motor fan or motor bearings go bad, it will run very loud. You will have to replace the motor. Part #2031214, sells for around $55.
Jan 17, 2008 | Bissell 6594 PowerForce Bagless Upright...
Karcher K DS 5500 Vacuum Logo
47 people viewed this question
Top Karcher Vacuums Experts
kbright1
Level 1 Expert
richie46
Are you a Karcher Vacuum Expert? Answer questions, earn points and help others
