Question about Mitsubishi WS-65807 65" Rear Projection Television
Screen looks bowed on top and bottom, then looks fine.
Our tv is just out of warranty and it just started acting up. It appears to bend the top and bottom of the screens towards the center and split the beams. I was fast enough to take a picture but cannot figure out how to post it. This is an intermittent problem currently and has been happening for months. It tend to do it more when just turned on, but will do it in the middle of a movie too. I am guessing it is a board problem because it is intermittent. I took the front cover off today as it was doing it and could not hear any clicking on the boards or anything that would point me in the right direction. If you want to see the pictue of the screen, email me at starvingpilot/at/junodot/com and I will send screen shot of my problem, Thanks in advance Midgetwidget
  • 3 more comments
  • Doug Jensen Aug 27, 2006
    I just wanted to follow up by saying that when the TV does this, the colors are seperated as well and don't look in alignment. The letering will have ghosts with all the colors represented.
    Here is a picture
    This picture is taken and condensed to be loaded on this website. As you can see the lettering is bowed. You are looking at the left side of the screen. Both sides are pinched towards the middle. Thanks for any help you can provide.
  • Doug Jensen Sep 04, 2006
    Techman,
    Your the man! That fixed it. Thanks!
    Midgetwidget
  • Doug Jensen Sep 05, 2006
    Easy vote!
    President:
  • 3,130 Answers
Your problem is a common one. It is a convergence problem. There are two IC's that stand up on a heat sink, that will start with STK that has to be replaced. Once these are replaced, there will be some convergence alighnment that has to be done.If you know how to work on solid state electronics, replace the IC's. If you dont , please dont tinker with this set, and call a trained tech to service this for you as a TV set is no place for a handi-person to be experimenting with. good luck
Posted on Aug 28, 2006
  • Larry  Dillon
    Larry Dillon Sep 04, 2006
    Good glad to hear it But wheres the vote??
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
Center bow on picture top and bottom with 1" black showing
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Toshiba TN55X81 55" Rear Projection...
I have a sony kp-41t65 tv acting like computer screen out of whac
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
Nov 10, 2009 | Sony KP-41T65 41" Rear Projection...
Bowing top and bottom temporary on cold TV
problem with unit is convergence--i would resolder convergence ics(they start with stk932-......)if that does not work replace them--if you need the exact part numbers email me at djstvrepair@comcast.net
Sep 15, 2009 | Pioneer SD-P50A3-K TV
Same problem as above, picture bowed top and bottom, convergence
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 19, 2009 | RCA P52939 52" Rear Projection Television
Screen is bowed on top and bottom.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngSOLUTION
Jul 13, 2009 | Samsung PCL5415R TV
GE 52 " rearprojection flat screen picture bowing 3d effect
Thats usually a very easy repair by replacing FL231, DL231 and CL230 total parts are about 11.00 at the following link and they provide free instructions. The components are all listed under RCA parts category.
http://servicemanuals.vstore.ca/
May 16, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
Picture is bending at the top and bottom and looks 3d
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Red/Orange looking picture
You can see some more examples and find a fix here
Dec 15, 2008 | Samsung PCN5425R 54" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
99 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
