Question about Dewalt Saws
Why would my dewalt d28402 grinder start smoking?
  • 2,176 Answers
Could have been from an overload situation, usually SMOKE is from the electrical parts e.g. armature/field and would need to be diagnosed and repaired to prevent further damage.
Posted on Mar 04, 2012
3 Suggested Answers
  • 94 Answers
SOURCE: new angle grinder dewault d28402 diamond disc
check your arbor size. (hole in middle of disc's) they must match up
Posted on Apr 21, 2010
  • 87 Answers
SOURCE: My son's Dewalt D28402 angle grinder gets so
that is normal...
Posted on May 26, 2011
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
My grinder d28110 dewalt stop working. My friend told me that it may be the problem with brush. I opened the machine but I do not now where is the brush and how to replace it. Please help, Bozena
Most times , unless the unit has been used a big bunch, it's not the brushes it's the comentator that the brushes run on . spin it in the clockwise position while holding some crocus cloth to clean it. Remember to clean each groove as a piece of metal could short two copper pads and burn a wire and cause a dead spot. This can make act like a bad switch.
Nov 15, 2010 | Dewalt 65091601 Brush Set D28110 D28112...
I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side...
What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
Jul 08, 2010 | Dewalt D28402 412" (115mm) Small Angle...
How do i change wheels
There usually is a locking pin that stops the wheel from turning. MAKE SURE YOU HAVE THIS UNIT UNPLUGGED!!! Press this button in while slowly rotating the wheel, once it engages the wheel will lock. With your wrench you can now take off the blade. It may have a left handed thread so going clockwise will loosen it.
Jun 06, 2010 | Dewalt 4 1/2" Small Angle Grinder D28402
Saws Logo
307 people viewed this question
Top Dewalt Saws Experts
JOHN LAPIER
Craig Butler
Craig Butler
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
