Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Intermittent power on problem, monitor now completely dead
This monitor had an intermittent power on problem. I took it apart to see if there were obvious issues such as blown fuse, burnt or blown device, bad solder connections on power connectors, etc. Found nothing obvious but before reassembling I had plugged it in to check output voltage from the power supply; Got 12V and 5V output from output connector, however, the led on control panel lit up and viola, the monitor worked. It continued to work for about 3 weeks until I had to replace the surge protector it was plugged into. Once it was plugged in, it wouldn't turn on. If I unplug it then plug it in to the live outlet, the status led (green on, amber idle) flashes very faintly but it does nothing else. I'm pretty sure the PS is good. If it is, then what else could be causing it to not turn on.
    Scholar:
  • 94 Answers
See other post regarding IC901 Please feel free to RATE me if it helps
Posted on Oct 13, 2006
My 2011 Dodge Grand Caravan won't start; the message was "No Fuse". How do I figure out which fuse to replace?
You can remove each fuse, one at a time (making certain you know where you took it from each time). A bad fuse will be obvious. The metal inside will be burnt apart instead of looking completely clean. Your bad fuse may take a while to find. Your owner's manual tells you where EVERY fuse is located.
Sep 03, 2014 | 2011 Dodge Grand Caravan
Lcd monitor no power
if totally no power indicator it was a indication of bad power supply board. check for blown fuse first and then any burnt parts.just let me know if you need further assistance thanks good luck.
Dec 16, 2012 | Computers & Internet
Benq FP92G screen blank, power lit not lit either. Tried different cables but still the same.
More likely to have power supply problem, that will be the first place to check, look to see if it has any caps with leaking/bulging tops/seal, burnt spots, shorted transistors in the backlight inverter board, cold solder joints. Look at my DELL albums (BenQ made a lot of monitors for DELL). Be real careful when removing the front bezel, you can easily rip apart the cable.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 02, 2010 | BenQ FP92G+S (Black,Sylver) (Silver,...
What and how much is a power supply board for the westington lcm-22w2 monitor. my tv went out i took it apart checked the circutry to me doesnt look like anythings rong. dont know what the caps are the...
Check here: <a href="http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2">http://www.shopjimmy.com/catalogsearch/result/?q=Westinghouse+LCM-22W2</a><br /> <br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools and know safety precaution then please read on:</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: <a href="http://s807.photobucket.com/home/budm/allalbums">http://s807.photobucket.com/home/budm/allalbums</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Post back what you see inside so we can guide you further and it will help out other people in the future also.</span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"><a href="http://en.wikipedia.org/wiki/Capacitor_plague">http://en.wikipedia.org/wiki/Capacitor_plague</a><span style="mso-tab-count: 1"> </span></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <span style="mso-spacerun: yes"> </span><a href="http://lcdalternatives.auctivacommerce.com/">http://lcdalternatives.auctivacommerce.com/</a><span style="mso-spacerun: yes"> </span>he can make you a set of caps for you.</span><br />
Aug 26, 2010 | Westinghouse Electric LCM-22W2 Monitor
On initial powerup, the monitor comes on, then flickers off. I can cycle it a couple times, and eventually it stays on. I took it apart, and didn't see any obvious connection or "heat" issues...any...
Look for bad caps.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Aug 11, 2010 | Samsung 215TW SyncMaster 21" LCD Monitor
Same thing.
If you have the 2 blown capacitors on the power board then most likely yo also have blown MOSFETs and a blown fuse. The MOSFETS and fuse blow when the capacitors short out when they blow. We sell a kit with the capacitors, MOSFETs and fuse with instructions for $10.00 plus shipping. Let me know if you need a repair kit.
Buddy
Corporate Computer
www.ccl-la.com
Jun 25, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Keeps Blowing Fuse
You obviousely have a short somewhere. Take it to a repair place.
May 26, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Gateway fpd 1960 goes black intermittently
Your inverter is dying. It produces ~2k volts for the ccfl (cold cathode fluorescent lights) that surround your display. At a few milliamps. Probably bad or leaking capacitors on the inverter or power supply board. So it is either using too much power (bad ccfl) or a weakening power supply (higher likely).
It could be cold solder connections becoming intermittent. Remove the base, remove the screws on the backside, and split the case CAREFULLY. Inspect the power supply and inverter for obvious failure or leaking capacitors. Replace same... If your lucky, it will work.
tom
Jan 04, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
No output to speakers mackie 808s power mixer
I can hardly even tell what you're talking about because you don't use any punctuation.
Jun 10, 2008 | Audio Players & Recorders
Monitor isn't working
just replacing the fuse should help. There are two of them on the inverter board. depending on which one is blown will give you 2 different issues. One will cause the screen to flash content perfectly for two seconds and then drop out. the other will be really dark if can see any picture at all,
Feb 10, 2008 | ViewSonic VX900 19" LCD Monitor
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
413 people viewed this question
Clive
Clive
Alun Cox
