Question about Welding Tools
Clarke pipe freezing kit replacement parts
In need the flexi pipes and freezer block
  • 374 Answers
SOURCE: cutting cast iron soil pipe
Phil, I recommend a ratchet snap cutter as it will allow you to cut the pipe in a clean manner. These are available for rent at most major home improvement stores in the US. One can also rent one at a tool rental company. I rented mine for $35.00 the bulk of which was a deposit on the tool. Just a reminder when buying the coupling device ensure you ask for or get a 4 inch cast iron to 4 inch PVC coupling. A bit of vaseline will help you get the neoprene coupling to seat properly with the PVC if you encouter resistance. Good luck. If you need more assistance let me know.
Posted on Sep 26, 2008
stephanos18
  • 144 Answers
SOURCE: Blocked drain pipe from freezer
you need to defrost the unit for 48 hours with both doors open, then try using some curtain wire up the drain and see what comes out.
cheers
Posted on Mar 25, 2009
  • 37 Answers
SOURCE: how can you tell if the waste pipe is blocked on a saniflow toile
Yes the bowl will be slow to empty. Try squeezing the white discharge hose as the unit operates, if there is a blockage then this hose will be hard to squeeze. If hose is soft then blockage could be in the toilet pan U-bend in which case fill bowl with very hot water and leave to soften the toilet paper.
Posted on Feb 26, 2010
Macmarkus
  • 2605 Answers
SOURCE: pipe behind freezer look red hot
Hi, yes you bet they do, at least modern day "frost free" firdges do. As the saying goes though, "out of site out of mind". Not to worry, this is the way the fridge keeps from frost/ice building up on the evaporator. It defrost's by way of a heater which does heat to a point to melt the frost, be it only briefly though ( usually 10-20 min. depending on the frost accumulated and the bi-metal thermostat tolerance...the part which insures it shut's off ). Anyway, I hope that re-assure's you this is normal and perfectly fine. If you however, think you want a pro to come and look at it, than that is what you should do. Hope this has addressed your concern or inquiry. Thanks for visiting "fixya" for assitance today, please take a moment to rate the info provided to you, whether helpful etc. Thanks again. Macmarkus :)
Posted on Mar 02, 2010
myrlex
  • 674 Answers
SOURCE: american fridge freezer siemens KA58NA50GB. Freezer not freezing
If you are not capable to do that much better to call service Engineer to avoid big damage of your Freezer.
Posted on Apr 04, 2010
Need flexi pipe repaired replaced on exhaust downpipe
Measure the diameter of the pipe you have and get a flexi part that will just slide over it and get clamps for both ends. Do not last all that long.
Nov 10, 2015 | Cars & Trucks
Water Pooling & Freezing
Assuming your fridge has a defrost cycle ( I.e. is a frost free model), you are probably suffering a blocked drain hole or pipe, leading to the top of the condenser or a tray nearby, where the frost water can evaporate.
The pipe can block with food or a mould plug, leading to water retention that freezes and further blocks the drain. the water is produced when a heater switches on in defrost mode and thaws the internal or external ice build up and, with nowhere for it to go it will pool on the bottom and may, when in defrost mode, run out onto the floor.
With frost free fridges/freezers, there is a drain outlet, usually hidden behind a removable panel inside the fridge/freezer compartment or, a drain hole near the bottom. If there is a drain pipe as well, access is usually from the rear base of the machine. The pipe is usually removable and can be cleaned out but prepare for some water to escape. An ice block in the drainage hole can be thawed using a hair dryer BUT GENTLY, so as not to warp the plastic inners of the fridge.
Jan 20, 2014 | Refrigerators
If i insulate my pipes, will it stop them from freezing the water? This problem has been happening a lot this winter, it is colder than usual where I live.
Insulating your pipes won't stop the water from freezing but it will take a much longer time for the water to freeze, so it defintely helps a lot. I would do it if I were you.
Jan 31, 2013 | Insulation
My henry vacuum has lost suction and there's no blockage in the pipe.
Suction cannot be lost if the motor is running normally unless the air flow has been interupted. Lift out and clean the filter so air can flow through, replace the bag, unscrew the flexi hose at his "nose", and also remove from the steel pipes. Finally drop a
Sep 28, 2010 | Henry Vacuums
Freezer will not freez ,warm air
replace temp sensor, should work also first check drain pipe some time gets blocked.same symptoms...
Feb 07, 2010 | Refrigerators
Hotpoint FFS70S fridge drain pipe blocks with FROST in a few days after clearing. I suspect that the drian pipe is too close to the freezer compartment. Is this a common problem. More to the point, is...
I have the same problem. Engineer said most likely problem with insulation and since pipe is moulded onto the back, it cannot be fixed easily. Defrosting is a temporary solution only. Luckily I kept extended warranty going, they are going to replace it with a new one.
May 17, 2009 | Hotpoint FFS70 Bottom Freezer Refrigerator
Subzero 550 coils
I had same problem very recently.  The problem with both the refrigerator and freezer on the 550 is that the drain line that takes condensation and water from the defrost cycle to the drain pan freezes up. Sub Zero parts suppliers will sell you a fix-it kit which I used for the refrigerator.  The kit is simply a heater wire that you plug into one of the existing circuits and runs down the length of the drain pipe to keep it from freezing up.  When my freezer started doing the same thing I ordered the kit for the freezer but the wire was too fat for the drain pipe so a Sub Zero rep gave me a better and more elegant solution.  You need a length of bare 12 guage copper wire, about 24 inches.  Run it through the drain pipe with about 6 inches exposed at each end.  On the underside of the fridge, wrap the end of the copper wire a few times around the black heater coil that you will see running back and forth.  At the upper end, wrap the copper wire around the black heater coil that defrosts the freezer coil.  The heat generated by the two coil will simply conduct heat through the copper wire and keep your drain line from freezing up.  There is a 90 degree bend in the drain line which makes it difficult to feed the copper wire through.  I suggest using guitar string or picture hanging wire as a snake.  Feed that through first, then us it to pull the copper wire through.  Good Luck!
Aug 10, 2008 | Sub-Zero Bottom Freezer Refrigerator
I lost the manual to my vacuum
Hi.
If no suction from hose check the following.
The (U) shaped inspection port at the back of machine where flexi hose enters has not come off or has a blockage.
Remove flexi hose from rear of machine once off slide it fully up the wand handle hold handle end up to a light & look up the pipe for blockages.
Check side premotor filter.
Does it pick up ok when using to vacuum carpets or is that got bad suction to ?
http://dc07.atspace.com/
Chris.
Nov 16, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Welding Tools Logo
26 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
