HOW TO FIX THE TEXT PRINTING OF CANON MP258 BECAUSE IT COMES OUT BROKEN ,OFF, WITH SHADOW, & BLURRED?
yooperbud
  • 8637 Answers
SOURCE: Canon ip1000 printing problem,pls help?
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 2072 Answers
SOURCE: Phaser 8500N Text looks like a shadow or an echo effect
there is an encoder on the end of the drum drive shaft. located on the right frame of the machine.
It becomes contaminated with the silicon lubricant from the maintenance kit, and off the rotating drum.
You remove the power from the machine, remove the encoder, and flush it thoroughly with alcohol. Then give it time to dry well, and put it back on the shaft. That WILL correct that problem. It is possible the encoder is bad, but I really do not suspect that because your problem is intermittent. But that is your problem, I guarantee it.
Posted on Jun 02, 2009
  • 1335 Answers
SOURCE: colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
Posted on May 27, 2010
SOURCE: okidata 5150n is printing blurred text
You can set the registration using the control panel in the front.
Posted on Jul 23, 2010
  • 794 Answers
SOURCE: can u help me how
Hi cinlytan,
With the error that you're getting with your Canon mp258 , error number 6000 this means that your printer needs to be reset. You will need a software resetter for this specific printer. You may also use the software resetter for its many other errors. Kindly click on this link for the instruction and for you to be able to download the service tool. This should fix the error code that you're getting and other issues with your printer.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 29, 2011
The black ink in my mp258 canon printer is blured how can i fix it
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.
Jan 16, 2013 | Canon MP250
Error Code E05 Canon MP258
Error Code E05 Canon MP258 may solve by the following steps.
1. Press Stop/Reset button for 5 seconds.2. After five seconds release the button.3. Now your printer will start its process and it is ready to use... thanks
Sep 25, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Can u help me how to fix canon printing model is mp258 , error number is 6000, what is problem? thanks
Hi cinlytan,
Hope it helps.
Mar 29, 2011 | Office Equipment & Supplies
How to fix canon mp258 error code 006
i'm using canon printer mp258, the printer wont print anything after i refill both ink(color & black), the both l.e.d still lid and and the alarm l.e.d still lid and the printer window keep popping telling me the colors now empty..heeeeellllppppp.........
1)try to reset the printer - wont work
2)try using the resetter - wont work(error 006 occur)
Feb 26, 2011 | Canon Office Equipment & Supplies
Colors print blurred
May 27, 2010 | Canon i860 InkJet Photo Printer
Zebra xi III Plus printing shadows and blurred text on labels. Initial printing was fine but all prints now have a shadow and blurred text.
Try adjusting your printhead. If that doesn't work you might need to replace.
Please contact me if you have any question or if you come across needing a printhead for your unit.
I carry all parts for that printer in stock .
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 01, 2009 | Zebra 110Xi III Plus Thermal Printer
HP CP1515N ONly prints half a page
There are 2 reasons for this either the ink is drying out nor your page settings isnt set to the correct size of the paper you are printing to.
Apr 19, 2009 | Canon PIXMA MX310 All-In-One Printer
Document printing blurred
You may have some custom print settings active. Go to the print properties and set the printer to default print settings. You may try downloading and installing the newest print drivers too. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=10236 here is the canon site for your machine. Let me know what happens Good Luck, Tim
Mar 14, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
158 people viewed this question
k24674
jasbo
jasbo
