CANON MP258 TEXT PRINTING COMES OUT BROKEN ,OFF, WITH SHADOW, & BLURRED?
yooperbud
  • 8637 Answers
SOURCE: Canon ip1000 printing problem,pls help?
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 27, 2009
  • 2072 Answers
SOURCE: Phaser 8500N Text looks like a shadow or an echo effect
there is an encoder on the end of the drum drive shaft. located on the right frame of the machine.
It becomes contaminated with the silicon lubricant from the maintenance kit, and off the rotating drum.
You remove the power from the machine, remove the encoder, and flush it thoroughly with alcohol. Then give it time to dry well, and put it back on the shaft. That WILL correct that problem. It is possible the encoder is bad, but I really do not suspect that because your problem is intermittent. But that is your problem, I guarantee it.
Posted on Jun 02, 2009
  • 1335 Answers
SOURCE: colors print blurred
you need to run the nozzle deep cleaning utility, nozzle check and alignment procedure under the printer properties maintenance tab.
Please rate this solution. Thanks.
Posted on May 27, 2010
SOURCE: okidata 5150n is printing blurred text
You can set the registration using the control panel in the front.
Posted on Jul 23, 2010
SOURCE: Zebra xi III Plus printing shadows and blurred
I changed the printhead and now the display is not displaying any data, only light.
Posted on Apr 22, 2011
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Colors print blurred
May 27, 2010 | Canon i860 InkJet Photo Printer
Okidata 5150n is printing blurred text
Aug 10, 2009 | OKI C5150n Led Printer
Zebra xi III Plus printing shadows and blurred text on labels. Initial printing was fine but all prints now have a shadow and blurred text.
Try adjusting your printhead. If that doesn't work you might need to replace.
Please contact me if you have any question or if you come across needing a printhead for your unit.
I carry all parts for that printer in stock .
Thanks
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 01, 2009 | Zebra 110Xi III Plus Thermal Printer
Jan 26, 2009 | Office Equipment & Supplies
Document printing blurred
You may have some custom print settings active. Go to the print properties and set the printer to default print settings. You may try downloading and installing the newest print drivers too. http://www.usa.canon.com/consumer/controller?act=SupportDetailAct&fcategoryid=257&modelid=10236 here is the canon site for your machine. Let me know what happens Good Luck, Tim
Mar 14, 2007 | Canon PIXMA iP1500 InkJet Photo Printer
87 people viewed this question
jasbo
jasbo
