Question about Hanns.G Corporation HW173D Monitor
Hanns-G HW173D When I turn on my monitor the power light is green,but I don't see anything. The screen just keeps blinking and i can hear a high pitched sound coming from it. Can somebody please helpme?
  • 1 more comment
  • jkmhahn Oct 28, 2008
    I have to hold in the "M" button to get my monitor to work. I am waiting for the manufacture to get back to me.
  • Anonymous Mar 26, 2014
    pressing the right button will turn on
    If i turn of my monitor, the green light works but after a 1-2 seconds, the monitors go off and if i hold the right button, it will turn on if i holding it. Why?
  • 35 Answers
That once happened to my LCD screen. I had to send it to the supplier for a fix. If it's still under warrenty, try sending it back for a replacement.
Posted on Oct 27, 2008
How to get rid of main menu on my hanns-g hw173d that keeps on popping. help me to solve this please
It's not a very good solution, but you can open the monitor and disconnect the button-panels plug on the mainboard. Afterwards the buttons don't work any more (surprise) but the control panel disappears.
Feb 07, 2012 | Hanns.G Corporation HW Computers &...
I unplugged my computer and turned off the monitor to save power since we were not using. Now with the computer plugged in, when I turn monitor on the green light just blinks.
Make sure the data plug is in correctly. Turn the computer on. No you can try using the power button on the monitor to power it off and on. Or you may need to pull the power for the monitor out of the plug and then put it back in.
The blinking light means the monitor is in sleep mode. They need activity on the data or signal cable before they wake up. Unfortunately sometimes they get stuck and you have to reboot them to wake them up. I have seen a few where they had failed and would not come out of sleep mode but that is pretty rare. Usually you just have to sweet talk it and threaten it a bit and pull it plug a few times and all of a sudden it will start up,
Feb 01, 2011 | Hanns.G Corporation HW173D Monitor
Monitor will not always turn on. The green power light blinks and the screen does not show any light or picture.
Try it with another PC and also check the VGA cable, if it still does not work, you will have to do in-depth troubleshooting.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Nov 02, 2010 | Hanns.G Corporation HW173D Monitor
Monitor problem
You may have failing capacitors in the power supply, you need to open it up and look for bad caps with bulging top or seal. See example of failed caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you find. You can also have components failure in the inverter circuits, etc.
Mar 22, 2010 | Hanns.G Corporation HW173D Monitor
No display
Try replacing the VGA cable if it is not hard wired to the screen. Check that the CPU is not sending an out of range signal (i'e. To Low / To high) Hope this may help.
Feb 17, 2010 | Hanns.G Corporation HW173D Monitor
Is it possible to use HW173D monitor with DVR and security camera
Unless your DVR offers a VGA output connector, you won't be able to use your monitor simply by plugging in a cable. The monitor VGA input requires separate signals for each color (red, green and blue) and synchronizing signals (vertical and horizontal). If the DVR has only composite video out, you'll need a video to VGA adapter. These are available from many online sources. They aren't cheap since they are active electronic devices, but many are in the $50 to $75 range. Here is one typical result from a Google search for "video to vga converter". You might also check eBay or local sources such as craigslist to see if anybody has bargains.
Feb 10, 2010 | Hanns.G Corporation HW173D Monitor
POWER LED ON BUT NO IMAGEN
I HAVE A DELL MONOTOR WITH, TODAY I TURNED IT ON AND IT HAS A 2 INCH YELLOW LINE GOING VERTICAL ON THE LEFT SIDE OF THE SCREEN ...WHAT CAN I DO TO POSSABLY FIX THIS ISSUE?
Jan 31, 2010 | Hanns.G Corporation HW173D Monitor
Model HU171D Hanns.G... Monitor is on but blank screen appears...
I think the data wire may be disjoined in the Center. try to replace the data cable and reply me.
Aug 19, 2009 | Hanns.G Corporation JW-199DPB 19" LCD...
I have a monitor HANNS-G It worked 3 years. And exactly after 3 years warrant policy ended my monitor got a problem. It looks like there is a problem in power connection on front buttons. After I connect a...
This is a problem with the power supply unit inside the monitor, there is no easy way out here. If you keep on using your monitor like this eventually it won't switch on no matter how long you wait. Keep on using it like this for the time being without switching off anything but ultimately you will have to take it in for repairs or otherwise purchase a new screen..
Aug 02, 2009 | Microsoft HannsG HU171D 17" LCD Monitor
I keep resetting my pc because my monitor just keeps blinking showing nothing on the screen. I need help
Your monitor MAY have a built in sleep timer. You can usually find it in the Monitor's Menu, under the category " MANAGEMENT " Disable the sleep timer and you shouldn't be having that problem anymore.
Jul 05, 2009 | Hanns.G Corporation HW173D Monitor
Hanns.G Corporation HW173D Monitor Logo
964 people viewed this question
Top Hanns.G Corporation Computers & Internet Experts
Matthew Spark
Matthew Spark
 Grubhead
Grubhead
Are you a Hanns.G Corporation Computer and Internet Expert? Answer questions, earn points and help others
