Question about Bell Sports Wireless Door Bell with Waterproof Sender
Set up manual for a siemens jsjs-204 door bell
Siemens model jsjs-210 door bell manual to chnge radio band
Siemens door chime jsjs-210
Without doubt the worst piece of design I've ever encountered.
The battery housing on the chimer is so large that on closing the lid with the batteries fitted they pop out, nothing holds them in place other than the contact elements - the case snaps shut with quite a jolt and the batteries just pop out...had to use a padded envelope cut to size to keep them in place.
Also the button unit is dreadful - the button isn't actually a button - it's a light, pushing the button just flexes the circuit board and activates a small push sensor on the reverse of the circuit board!?! WHY? A button that isn't a button? The sensor is also too short to touch the rear of the casing and thereby close the circuit - had to pad this out with 2 bits of cardboard...too much it will ring all the time, too little it won't connect.
Please do not buy this product - if you have return it, it is dreadful - and from Siemens it's not even funny.
Apologies for not answering the question directly - I was also searching for a manual for this, to maybe figure out why this device is so badly constructed.
Sep 28, 2013 | Bell Sports Wireless Door Bell with...
Siemens jsjs-208 door bell
Mine keeps doing it. Taking a battery out to force reset on the ringer but mine seems to need this every few weeks. Tried new batteries but still problems.
Mar 19, 2013 | Bell Sports Wireless Door Bell with...
I have a JSJS 203 wireless siemens door bell how do I change the tune?
On my JSJS315 there is a small button (hole) on the back mine is marked S to switch the tunes. When you press it will play the next tune and so on. Hope this helps
Jul 04, 2012 | AT&T Home Security
Change the chime frequency on a siemens door bell
With Siemens door chimes, there are often no dip switches. Instead you need to take the batteries out of both the receiver and the switch, wait for a few minutes, replace them and then try again. The set should "learn" the new frequency of the doorbell automatically.
Mar 19, 2012 | Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
I have a Siemens Wireless Doorbell (Model No. JSJS-204. It started making ringing tones when no one was pushing the doorbell. I replaced the battery thinking that it was wearing out. Now the unit does not...
Hi
To fix the issue you need to remove the batterys from both the bell push and the bell unit for 10 mins, then replace the batterys and then push the bell push so it can switch channels and be different from the house down the road
Sep 17, 2011 | Vacuums
Bell Sports Wireless Door Bell with Waterproof Sender Logo
2,462 people viewed this question
Top Bell Sports Home Security Experts
Lawrence Oravetz
Are you a Bell Sports Home Security Expert? Answer questions, earn points and help others
