I have a cp3525 that has a 59.F0 error on startup. I have run the physical alienation test and the itb contact/alienation test. Both seem ok but the error persists. Any ideas?
4 Suggested Answers
taki99
  • 112 Answers
SOURCE: Fan runs loud,constant on HP a1620n
cheek the cable of cable properly plug in
R
OFF YOUR pc and system cell put out for 10 mint put back in to the system and stat your system
R
cheek out fan for electric shot
repaly me if i solve your problem
Posted on Dec 13, 2008
  • 61 Answers
SOURCE: HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Posted on Mar 27, 2009
ginko
  • 19396 Answers
SOURCE: Jenn-Air Range: I am getting an F0 error.
F0 is Function key faulty.
Replace touch pad or clock assembly (also called the ERC)
You can find parts online at partselect.com , or appliancespartspro .
Posted on May 29, 2009
I have Printer Laser jet HP P2055d error code is 59.f0 i need some one help thank you
Okay let's try this please.
Below is a recommended suggestion to resolve this problem:
  1. Upgrade the FW
  2. Remove the ITB
  3. Remove the fuser and on the left side (front of printer side) you can see the sensor flag holder (image #1 and #2 below)
  4. If the sensor flag/lever is stuck in the up position then reach in and carefully release the part with your fingers. The images below show the sensor flag/lever stuck in the up position. Actuate the flag/lever a few times to make sure it is loosened up.
  5. Re-install the ITB
  6. Re-install the fuser
  7. Reboot to see if the error clears
If the issue returns in a short period of time, then the flag/lever is likely dragging and returning slowly or getting stuck again. If this occurs, then it is recommended to:
  1. Remove the top cover
  2. Inspect the POSITION DETECT ASSY RM1-5604 to ensure the photo interupter is seated correctly
  3. Check the sensor flag for proper movement
  4. Replace the POSITION DETECT ASSY RM1-5604
NOTE: The ITB is typically not the cause of this issue.
I hope this helps.
Please do not forget to rate if helps thank you and have a wonderful day...
Mar 15, 2016 | HP Office Equipment & Supplies
Canon ira 5051i error E0074
Error in disengagement operation. check ITB connector is physically removed.
Jun 30, 2014 | Canon Office Equipment & Supplies
The printing is blurred, how can I correct?
# Do the color calibration..chk
# Take diagnoses page printout(menu print out).. ckh 'L' shaped corner images (as shown in fig), if they are not properly aligned, could be ITB faulty..Replace ITB..
For tech guys:
This activity requires lot of patience & experience..
* use gloves, don't use sharp tools, don't tough ITB belt, don't expose ITB in daylight longer..
ITB alienation sensor dirty, remove ITB, locate sensor clean clean it gently with swab.. re-fix back, calibrate the unit, chk...
May 02, 2014 | HP CP3525N Color LaserJet Printer
E00070-0001
E070 is an ITB home postion error, if the belt was recently replaced the ITB unit may have been reassembled incorrectly. If the unit has not been recently serviced, a faulty ITB cleaning unit can soil the ITB Belt enought to where the home posistion sensor cant read correctly. Also the sensor itself could have gone out but ive only seen a bad sensor once.
Check Transfer Belt Sensor (PS51) output in I/O mode. If sensor state does not change when blocked and unblocked, suspect a bad sensor.
Service Mode * 2/8 *Copier>I/O>DC-CON>P014>BIT-7 0=Blocked 1=Unblocked. The Transfer Belt Sensor PS51 (FH7-7394-000) and the Manual Feed Tray Paper Sensor PS15 are the same. Try swapping sensors and test them in I/O mode to determine if the sensor is bad.
If sensor seems fine replace the ITB Cleaning AssyTransfer Cleaning Assembly (FM2-0082-020)
Mar 14, 2012 | Canon imageRUNNER C3170U Color Copier
HP Color LaserJet CP352dn 59.fo error
59.F0 ERROR
The primary transfer-alienation motor has experienced an error.
1. Check to ensure the ITB is installed correctly.
2. Run a sensor test to verify that the primary transfer disengagement roller is functioning. If not replace the sensor (SR17).
3. Run the primary transfer drive test in actuator drive mode. If not functioning replace the ITB (Intermediate transfer belt).
Jul 27, 2011 | HP Laserjet Cp2025n Printer
Hp color laserjet code 59.fo error
All the book says is that one of the motors had a problem.
Power it off for at least 30 seconds. Power back on.
Make sure you are not using a surge protector.
Put the power cord directly into the wall outlet.
I just checked the manual for another printer and the 59.f0
could be the ITB. Make sure that it is seated correctly. If you have
a spare install it and see if problem goes away.
Apr 04, 2011 | HP Laserjet Cp2025n Printer
59.FO Error
1. Check to ensure the ITB(intermediate
transfer belt) is installed
correctly.
(SR17).
replace the ITB.
To replace the ITB
1. Open the right-door assembly.
2. Use the blue lever (callout 1) to lower the secondary transfer assembly.
3. Grasp the small handles on the ITB and then pull the ITB out of the product until two large handles expand along the right- and left-side of the ITB.
4. Grasp the large handles on the ITB and then pull the ITB straight out of the product to remove it.
Mar 03, 2011 | HP CP3525N Color LaserJet Printer
My irC-3200 cannon just show me this error E012 number on the display screen so i want to know what this code mean??Please help me
E012-0001 Error code At about 37 sec. after the power is turned ON, due to a drum ITB motor failure
Symptom About 37 sec. after the power is turned ON, E012-0001 is displayed due to a drum ITB motor failure. Cause Rotational failure of drum ITB motor Items to Check 1) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR, enter 1 and press the OK key.
2) In service mode level 1 COPIER > FUNCTION > PART-CHK > MTR-ON, press the OK key to check whether the motor is working normally.
3) Check whether 24V is supplied to J93 on the ITB drum motor. If yes, the ITB motor likely faulty.
4) If 24V is not supplied to the ITB drum motor, check whether 24V is output from fuse PCB J70-3 to the ITB drum motor.
Also, check whether 24V is output from the fuse PCB J71-1 to the microswitch PCB and also whether 24V is supplied to the fuse PCB J71-2 from the microswitch PCB.
5) If there is no problem between the fuse PCB J71-1, -2 and the microswitch PCB, the fuse PCB is likely faulty.
If 24V is output from the fuse PCB J71-1 to the microswitch PCB and not supplied to the fuse PCB J71-2, check the microswitch PCB. Field Remedy Replace the drum ITB motor.
FH6-1971 DC Brushless Motor
Sep 01, 2009 | Canon Office Equipment & Supplies
Irc 3100 e070-001
try to check the grounding plate did not come in contact with the shaft of the ITB
drive roller in the ITB unit, causing a poor ground (1 case). This grounding plate is used to establish a ground for
the ITB tension roller to the ITB drive roller.
E070-0003 can be displayed when the time that passes between the first detection of the ITB home position (HP)
and the next HP detection is shorter than a specific period of time.
Field Remedy
Follow the steps below:
1. Make sure that the inner surface of the ITB has stains or scratches on it.
2. Make sure that the ITB-HP sensor (PS19) operates normally.
3. Make sure that the grounding plate properly comes in contact with the shaft of the ITB drive roller.
Dec 06, 2008 | Canon imageRunner C3100N Copier
Canon MF8180c
E071 error stands for ITB position sensor fault,so you may try to check if the ITB belt is ok, if there is no paper left overs or similar, but this error can occure when the main board ( dc controller ) is defective.
Nov 01, 2008 | Canon imageRUNNER C3200 Color Printer
337 people viewed this question
k24674
jasbo
jasbo
