Question about Sharp CD-BA2100 CD Shelf System
Protect mode the system is locked in protect mode and will not function
  • no13stunna Oct 27, 2008
    Try plugging in a pair of headphones. I tried it without the speakers connected and since it found the headphones and they were OK the system came out of protect mode.
I own a Sharp DVD Micro System XL=DV60 that began to have a "protect" error message when I crank up the volume. Not sure if this applies to your system, but it could be worth a try. Before you proceed, the solution requires you to open up your system (Do not proceed if the unit is still under warranty :)).
IF you are not experienced in opening up electronic equipment, I suggest you find somebody who does. The error on my system was caused by the cooling fan being stuck or not able to spin. The system has a sensor or sense circuitry wherein, when it detects that the "amplifier" IC heats up, it spins up the fan to cool it down. IF the system detects that the fan is not spinning during the cooling phase, it will give out the "protect" message. Note that the fan only spins when you crank up the volume. Less or 0 volume will shut down the fan due to it's "energy star" feature. One possible reason why using headphones does not show the error, since headphones require less energy that the main speakers, thus the amplifier IC does not overheat. To solve the problem, I cleaned out the dust in the system via a 1 inch wide paint brush (haven't tried the compressed bottled air used to clean computers BUT it might do) and nudged the fan. Played the system w/o a cover and observed the fan operation and so far it has solved the issue. I plan to lubricate the fan shaft with very small amount(less than a drop) of machine oil using a syringe. If it does not work, I plan to see if I could purchase a replacement motor for the fan...
Again, I have not seen the internal layout of CD-BA2100 and not sure if there is a cooling fan. But then again, it's better than having the "protect" error popping up. :) hope this helps....
Posted on Nov 22, 2008
I have had this camera for two years and never had a problem. Now when I switch it on the screen shows the message, " Memory card is write protected" and the camera will not function.
On the memory card is a slide lock that locks the card from being accidentally written to or erased. embossed with a lock that is unlocked/locked.
Somehow this slide lock has been moved to the write protection mode/locked. Could have happened if you removed the memory card lately.
Remove the memory card and slide the lock to unlock reinstall the card and that should cure your problem.
Feb 05, 2016 | Nikon Coolpix S3300
Power problem
If the protect function works but is causing you problems, cancelling the protection function should help, and it will be possible to enter the self-diagnostic function mode. This should disable all functions of the protection mode, excluding the 'excess electrical current detection' feature.
While pressing the "Tone Control" and "Info" keys, try pressing the power key to turn on the power. Keep pressing those 2 keys for 3 seconds longer.
this should activate the Self Diagnostic function, with your Protection Mode disabled.
in this mode the 'sleep' section on the tv's fluorescent display flashes to indicate that the mode is properly activated.
just be very aware, this function is normally there as a safety feature and i cant guarantee that disabling it altogether won't cause other problems down the road. best of luck!
Jun 06, 2014 | Yamaha Audio Players & Recorders
What's your problem?powerprotection mode unlock
If the protect function works and causes hindrance to trouble shoot, cancel the protection function as described below, and it will be possible to enter the self-diagnostic function mode. (The protection functions other than the excess current dtect function will be disabled.)
While pressing the "Tone Control" and "Info" keys, press the "Power" key to turn on the power and keep pressing those 2 keys for 3 seconds longer.
The seld-diagnostic function mode is activated with the protection functions disabled.
In this mode, the "Sleep" segment of the Flourescent Display flashes to indicate that the mode is self-diagnostic function mode with the protection functions disabled.
Caution!!!! Usiong this product with the protection function disabled may cause further damage to your unit, so use special care when using this mode.
Apr 18, 2012 | Yamaha RX-V671 7 Channel AV Receiver -...
What do "write protect" mean
1. Switch to playback mode using the mode
dial. Use the Left/Right buttons to locate
and display the photo or movie that you
want to protect.
2. Select the Protect setting from the
Playback menu as described previously.
3. Use the Up/Down navigation buttons to
select One to protect this picture/video,
or select All to protect all pictures/videos in
the internal memory or memory card. Then
press the Right navigation button.
4. Use the function button to select Yes to lock
the displayed picture/video or Unlock
to unlock it, and use the Up/Down
navigation buttons to select Back to
return to the Playback menu.
5. A key icon will appear on the top of
the screen to indicate that the picture/
video is protected.
6. Select reset to cancel protection for all
files that have been placed in the protected
mode.
Also keep in mind the card it self has a write protect on it if you hold the sd in front of you label side up its on the left hand side its just a little slide tab.
Jun 21, 2011 | Cameras
How do I enter the Test Mode on my RISO 790 duplicator?
Do you mean into the unprotected mode?, if so
Turning OFF Protect mode in a Riso MZ 790u (and other models I'm sure).
1. Go to Admin Tab on the main console screen and scroll to the "Protect" button.
2. Select (press) the "Protect" button on the screen; printer will go through a reset function (takes about 3-5 seconds).
3. After printer is finished "resetting", pull out one of the master disposal boxes (doesn't matter which one).
4. Press the "Protect" button again.
5. the screen should say "Protect = Off"
6. You're done and your machine should be un-locked now.
May 11, 2011 | Office Equipment & Supplies
How can we remove write protection in sony dscw320 digital camera
I'm going to assume you mean the "protect" function in the camera, rather than the whole-card "lock" function. I don't think there's a single manufacturer that makes this clear. But let me tell you their little secret... whatever you did to protect it - do it again. It's a toggle function! They wouldn't want to put "protect/unprotect" in the menu system instead of just "protect", it might look 'cluttered'. Of course, it might be more useful too. I just dug out my own Sony camera, and it's easy enough to find; be in playback mode on the picture in question, press 'menu' and scroll to the 'protect' function.
Feb 23, 2011 | Sony DSCW320 Digital Camera
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My vivtar 8025 camera locked my pictures so I can't delete the, how do I unprotect them
1. Press the Home button.
2. Enter Playback mode by touching the Playback (right-facing triangle) function area.
3. Press the Menu/OK button.
4. Touch the downward arrow function area until the Protect option comes up.
5. Touch the key icon function area to enter the Protect menu.
6. Touch the left arrow function area to select Lock or Unlock.
7. Press the Menu/OK button to confirm.
This should be on pages 29-30 of your manual.
Jan 03, 2010 | Vivitar ViviCam 8025 Digital Camera
Sony str-de525 system "protector" problem
You've blown it. It recognizes a potentally harmful situation and goes into protect mode.
Mar 15, 2009 | Sony STR-DE935
Protect mode on vivitar vivicam 5386
hi there
this is the disc that you use in your camera correct, put the disc back into camera if so go to your camera setting like if you were going to review your pics.and go to the place where you went to lock the pictures press menu find protect again hit function settings hit select it will bring that picture back up again click function again and this will unlock it. this works for my cannon but it goes something like that hope this works for you its hard to explain but i had the camera in hand its easier do it. i just did it with my sons hope i didnt confuse u
Jan 19, 2009 | Vivitar ViviCam 5386 Digital Camera
Sharp CD-BA2100 CD Shelf System Logo
529 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
