Question about Ricoh Office Equipment & Supplies
Ricoh aficio 2045 error code sc990 - Ricoh Office Equipment & Supplies
SOURCE: Ricoh Aficio 2045 error code sc 502
sc 502 is the problem related to tray lift motor .open the backside of the machine ,almost downside u ll find one spring broken .replace tat the tray will start working.
Posted on Jan 21, 2009
Bubbabear64
  • 2794 Answers
The lift motor in the second tray is reporting a malfunction. If it isn't lifting, it isn't going to feed the paper. Remove the second tray by gently lifting on it and check to see if there is any paper jamming it from lifting. If there isn't any, the lift motor may need to be replaced.
Posted on Sep 26, 2008
  • 16 Answers
SOURCE: sc990
sc 990 relates to the nv ram chip on the main board also check the values of the lazer unit are correct and not changed
Posted on Jun 18, 2010
  • 3 Answers
SOURCE: sc990
sc 202 mpc 1500 and af 1075 sc 995
Posted on Jul 10, 2010
domotek
  • 591 Answers
SOURCE: Ricoh Aficio 2022 Unit indicates to call for
You could reset all the counters but you should call a proffessional with a good mantenance KIT, your copier probably needs it...
Have fun!
Posted on Jan 04, 2011
I have an sc 326 error code in my ricoh aficio 2045 copier
If you wish to get some details; check the site linked here. Pull up older posts....
Jun 19, 2016 | Ricoh Aficio 2045e 2035e Copier...
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
I have problem in Ricoh AF 2045 SC 990 pl z help me out from it
this is software performance error.but this in most cases will appear on life over of either drum or developer.
Jul 26, 2011 | Ricoh Aficio 2035 Copier
Have fun!
Jan 04, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
Service SC 990 RICOH Aficio 551
sc990 is a general software error. It could be caused by a specific application or function, or it could be caused by a problem with the process control. In general, you can get rid of the sc990 error by turning the machine off with the main power switch (the orange switch on the left side of the copier) but if the error comes right back, the best first solution is to update the machine's firmware.
Nov 18, 2010 | Ricoh Aficio MP 1600 Black and White...
Sc990
sc990 is the software problem. replace the HDD of the machine and it should be fine. don't format the hard drive as it might result in laser error code.
Oct 22, 2010 | Ricoh Aficio 1035 Copier
Sc990
Jun 16, 2010 | Ricoh Aficio 450 Copier
RICOH AFICIO AP3800C CS 99 CODE HOW CAN I FIX THAT
I am new to this printer myself. but most codes error I see have 3 numbers to it I can only say that the codes I see for this printer with 9 in it are:
SC990 Defective software
SC998 Application start error
Maybe the machine lcd not show all the number on it.
Pineworks.
Jan 05, 2010 | Ricoh Aficio AP3800C Laser Printer
In rioch 2045bprinter problem
Do you mean that when you install the printer unit you get the error message, and if you remove it it is ok?
"SC990" is a software error. Are you sure it is the proper board? There is a similar model (2045E). Installing that by mistake might make it go into the error...just guessing.
Anyway, the error is a 'software performance error", which could be the hard drive -try unplugging it when you install the printer board to see if it goes away in order isolate the problem.
Mar 15, 2009 | Ricoh Aficio 450 Copier
251 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
