Smtp server address fix error - Office Equipment & Supplies
SOURCE: Email Address Problems
when I setup the SMTP server as an IP adress the e-mails are sent correctly. I looked up manually the IP adress of my SMTP server. This is only a temporary solution. In this case you naturally have to choose the IP adress option in the settings.
However when I setup the SMTP server as a hostname (ex. smtp.telenet.com) and I chose the option Host Name, it does not work.
Posted on Feb 08, 2008
SOURCE: Cannot scan to email Konica Minolta 250 Bizhub
To scan to email, Administrator email address must be set in the machine (any bogus email address will work too).
Also, email server address must be input as IP address if DNS or WINS is not running in LAN.
Posted on Mar 09, 2008
  • 22 Answers
SOURCE: ricoh 2045e
The delivery server IP address is pushed to the machine from the scan router software. If it needs to be updated, you will have to remove and readd the I/O device within the scan router administration utility. If you do not use scan router you can set delivery option to off, and it will eliminate the error message.
Posted on Jul 22, 2009
SOURCE: Add SMTP server address to Canon iR3570?
Hello, I have one of these. The iR3570 has no smtp server - you would need the iR3570i. It may be possible to buy the additional hardware and software to effectively turn your 3570 into a 3570i - but they are getting on a bit and it will not be easy to find. Once the machine is upgraded the smtp option will appear in the menu.
Good luck to you.
Posted on Nov 10, 2009
SOURCE: Scan to email gives server response error.
I've just discovered that Ricoh's built in software only works if your SMTP server sends out without picking up password or authentication.
Having same issue and it worked fine when it was behind corporate firewall with the same connection settings (IP address) as the SMTP server.
Once I changed web hosting - it won't recognize the SMTP server or any authentication methods. According to IKON (Ricoh support for the USA) - your SMTP server has to have "relay exception"
Posted on Mar 23, 2010
The host 'SMTP' could not be found. Please verify that you have entered the server name correctly. Account: 'POP3', Server: 'SMTP', Protocol: SMTP, Port: 25, Secure(SSL): No, Socket Error: 11001, Error...
You want to use these settings to  configure a mail client for yahoo:
Incoming mail server settings
POP server: plus.pop.mail.yahoo.com
Use SSL
Port: 995
Outgoing mail server (SMTP) settings
SMTP server: plus.smtp.mail.yahoo.com
Use SSL
Port: 465 (or 587 if your ISP is blocking 465)
And, of course, you also need to put in:
Username (yahoo login username)
Email Address
Password (yahoo password)
Mar 20, 2010 | Yahoo Mail
Can recieve e mails,cannot send or reply to in-comming mail.all messages come up as failed delivery.no problem when first connected
1. Change the settings in your email software so that the email account you're using designates an Outgoing Email Service that your internet service provider won't block. Your internet service provider should provide you with the address of an acceptable Outgoing SMTP Mail Server. This information is often listed on their website; if it isn't, call their technical support and ask them the address of their Outgoing Email Server. Then go into your email software and change your current Outgoing SMTP Address to the one your ISP requires.
2. After you designate a SMTP address not restricted by your ISP, you may still receive the following error:
Port: 25, Secure(SSL): No, Server Error: 530, Error Number: 0x800CCC78
Now you are reaching the Outgoing SMTP Mail Server, but it won't process your request without further authorization. You will need to go into your Email Software and find the setting that indicates that your Outgoing SMTP requires further authorization. Select this setting and enter the username and password required by your ISP (or reqired by who ever is the administrator of the Outgoing SMTP Mail Server that's not blocked by your ISP). For example, at the time this article was written MSN Internet Service's SMTP Address was: (secure.smtp.email.msn.com). However, this email server won't allow you to use it unless you send your MSN username and password along with your request to send email.
Feb 22, 2010 | Computers & Internet
Scan to email gives server response error in home network. SMTP server tried by IP address and DNS name. Port 25 Authorisation POP for SMTP. The other authorisation types give a network error straight...
Feb 20, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Outlook express
0x800CCC78 SMTP_REJECTED_SENDER Unknown sender. This is caused by having the incorrect e-mail address in the Reply-To field.
You may have to authenticate in outlook express by putting in the SMTP server name of your internet provider instead of yahoo
for example
Incoming = smtp.mail.yahoo.com
Outgoing = smtp.yourISPservername
Some isp's will not let you send out with a different smtp server than theirs.
It's why you can receive but not send.
Sep 15, 2009 | E-Machines eMachines Desktop PC
Message could not be sent. Server rejected sender's email address
the message could not be sent because it rejected as the sender
Jan 15, 2009 | Computers & Internet
Outlook Express Setup - error message
contact comcast and get the pop3(outcoming) address, and the SMTP (incoming) address
"mail.comcast.net seems correct but the outcoming smtp.comcast.net seems wrong.
Oct 13, 2008 | Microsoft Windows XP Home Edition
221 people viewed this question
jasbo
jasbo
