Question about Kodak EasyShare M320 Digital Camera
Kodak easyshare m320 white blank screen problem
When I switch on my camera there is nothing except white blank screen. How I can solve this problem?
  • 11967 Answers
SOURCE: The lens in my kodak easy share M320 seems to be
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 05, 2010
SOURCE: Kodak easyshare camera not transfering photos
My kodak easyshare camera will not transfer my photos to the computer. Everything is plugged in and the camera is blinking but nothing is happening. Please help. I checked the connections, they are fine.
Posted on Sep 17, 2008
  • 11967 Answers
SOURCE: My Kodak EasyShare M320 won't let me upload pictures
Get yourself a card reader do download pics. This one is $13 at Walmart. 38ba78b.jpg
Posted on Apr 28, 2010
Wolfeh
SOURCE: my kodak easyshare M320 isn't charging
I had this problem too, after about 3 minutes the charging light would go out, I found the problem appeared to be either my charger or the wall socket, for some reason now it is charging, try plugging it in to different sockets, and watch the light, after 10 minutes you can be sure it won't go out. After charging DO NOT use your camera for about an hour, I found that if you use it right after charging its a real pain to charge again, and it acts as though its battery is still dead.
Posted on May 26, 2010
  • 28 Answers
SOURCE: my digital camera , kodak easyshare M320 saying
Don`t you have a SD/SDHC memory card in the camera .In review picture mode select copy & send photos from internal memory to SD card and then delete internal memory for fresh space
Posted on Aug 12, 2010
Kodak easyshare m320 froze and won't turn on
Send it back to Kodak, these models are nothing but trouble, far to many customer complaints, Made in China and not made very well, not dependable, Try a better brand. Kodak has seen better days with their products. Buyer Beware
Oct 15, 2012 | Kodak EasyShare M320 Digital Camera
My kodak easyshare M320 isn't charging
I believe your camera has a specific battery and battery charger? You may need to purchase a new one. Even rechargeable batteries need to be replaced after awhile. Try purchasing a new kit (battery and battery charger) and see if that works!
Something like this:
http://www.amazon.com/Kodak-M320-Digital-Camera-Accessory/dp/B004J5C2JO
Hope this helps!
Jul 26, 2011 | Kodak EasyShare M320 Digital Camera
My Kodak EasyShare M320 camera works fine except for the fact that everytime I try and zoom in, the camera shuts off. I'll charge it and the problem still doesnt resolve itself.
sounds like the zoom motor is shot. to prevent further damage, the unit shuts off when the power goes to the motor but the motor doesn't move. if power kept going it would overheat and melt inside if was allowed to get hot enough. it could be the motor is stuck but either way i think you may need to take it in to a repair shop. if still under warranty, i would take it back.
hope this helps
Apr 17, 2011 | Kodak EasyShare M320 Digital Camera
We purchased a Kodak easyshare M320 on 11-04-10 at Walmart in Many, La. There was no manual in the box. We just started using the camera and did not notice until today.-12-11-10. We need a manual. What...
User guide:
http://support.en.kodak.com/app/answers/detail/a_id/19077/kw/m320
Extended user guide:
http://support.en.kodak.com/app/answers/detail/a_id/19074/kw/m320
Dec 11, 2010 | Kodak EasyShare M320 Digital Camera
Kodak M320 with message "internal
You need to get rid of whatever is in the internal memory. With no card in the camera, go into the menu and find "format"....follow the on-screen instructions. Then, remember that all new cards must be formatted in the camera to work properly.
Oct 29, 2010 | Kodak EasyShare M320 Digital Camera
Kodak Easyshare M320 Memory Card Protected
If there is a slide switch on the side of the card, make sure it is "unlocked".
Jun 22, 2010 | Cameras
How do I download the codec for the Kodak Easyshare M320. Cannot use Quicktime in Window's Movie Maker.
Normal 0 7.8 ? 0 2 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:????; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://onlinevideodownloader.net/how-to-put-cell-phone-videos-on-windows-movie-maker.html
have a look in here, you will get a satisfied answer.
Jun 04, 2010 | Kodak EasyShare M320 Digital Camera
Apr 27, 2010 | Kodak EasyShare M320 Digital Camera
Kodak EasyShare M320 lence cover cracked a bit when it fell down how much will it generally cost 2 repair & is it possible 2 repair...
All you need to do is to contact kodak at 1 800 235 6325 ext 12. You may ask also about the total repair cost of the camera or avail their service upgrade program. Dont worry about the camera kodak can fix it.
Nov 20, 2009 | Kodak EasyShare M320 Digital Camera
Kodak EasyShare M320 Digital Camera Logo
107 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
