Question about Bush Industries IDLCD26TV16HD LCD TV
Bolt size for a IDLCD26TV16HD LCD TV to wall mount
2 Suggested Answers
gopakumarg43
  • 74185 Answers
SOURCE: Bush IDLCD26TV16HD Left side of screen red causing distortion
Check its degaussing posistor at the power supply regulator section.
Posted on Apr 03, 2012
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
Aug 23, 2015 | Panasonic Viera TC-32LX85
What size of mounting bolts do I need for mi sony
Are you mounting to a stud wall? If so be sure at least 2 of the screws penetrate into a stud at least 1&1/2" after passing through the drywall. The minimum size should be #12 wood screws. Two other screws can be #10 drywall butterfly bolts.
Feb 04, 2012 | Sony Bravia KDL46V4000 46 in. LCD TV
What size bolts do i use to mount it
It is very likely that the correct mounting bolts to attach a wall mount to your TV are type M8 bolts 20 MM long. It is a rather standard size and you should be able to find them locally without a problem. This is the most probable size although you may find that it requires a different size. It should be either a M5 or M4 bolt of similar length. Give it a try, I think you will find it works perfectly!
Mar 07, 2011 | Toshiba 42HL67 42 in. LCD Television
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
How do I mount my Soyo MT-SYTPT3227ABMS on the wall
Mounting an LCD (Liquid Crystal Display) TV on the wall may seem a bit overwhelming at first; but it's not that difficult. With a few simple tools, a proper mounting kit and a helper, the job will be a breeze. With a little bit of patience and an hour or two, your LCD TV will look great. Follow these steps to learn how to mount an LCD TV on the wall.
Things You'll Need:
LCD TV
Mounting kit
Tools
Step 1
Find the best spot on the wall to mount the LCD screen. Think about how much room you may want on that wall, especially if you plan on mounting speakers, too. You could hang a poster or picture relative to the size of the television on the wall to see if you like the placement.
Step 2
Pick a mounting kit. You can purchase mounting kits online (see Resources below) along with many other sites. Look to make sure the kit and TV are VESA compatible so that you have standard measurements and quick, easy attachment during the mounting process.
Step 3
You may already have tools needed to mount the TV. You'll need a set of screwdrivers, a socket set, a saw capable of cutting into drywall, a drill and a measuring tape. Having a stud finder with a built-in level is also great to pinpoint the exact location of the stud. The stud finder will be useful if you'll be running wires through the wall.
Step 4
Get the location for the TV picked out. Check near the bottom of the wall to see if the area you plan on using to run the wires is free of obstructions. Using the stud finder for this will make it easy.
Step 5
Find the studs. You should use at least one stud when mounting the LCD screen to make sure that the mounting bolts are driven into something solid that will support the weight of the TV and the mounting bracket. Using two studs is ideal for mounting larger TV's, those with screens larger than 37 inches. Use a pencil to mark the drill holes for the anchors and stud location.
Step 6
Secure the mounting rails to the back of the LCD screen. Double check them for proper fit. Make sure that they're hidden behind the body of the television for a finished look.
Step 7
Cut the hole for the wires to come through by using a drywall saw. The easiest way is to pull them out at the electrical box. This avoids having to go into the basement, closet or otherwise. You can purchase a wall box at your local home improvement store to place in the exit hole of the wires.
Step 8
Drill the holes for the bolt anchors in the locations that you measured and marked previously. Place the bolt anchors into the holes and tap them in with a hammer.
Step 9
Secure the wall mount to the wall. You'll need a socket wrench to ensure that the mounting bolts get snugged down tightly to the anchors. Use a level to make sure you've done an even job.
Step 10
Grab a friend or family member to help you lift the LCD screen onto the mount. Make sure it's locked down tightly and the screen is set to go.
Hope this helps and Good luck
Aug 03, 2010 | Microsoft MT-SYTPT3227AB 32 in. LCD TV
Bolt size
They are Metric screws, either M5 or M6, you can get them from hardware store for about 25 cents each, so get different length depend on the mounting brackets.
Wall mount usually comes with mounting screws already.
http://s807.photobucket.com/home/budm/allalbums
Jul 04, 2010 | Sylvania LC-321SS9 32 in. LCD TV
Screw size to bolt panasonic 32 inch lcd into
Metric M5 or M6, they should come with the mounting kit.
Dec 23, 2009 | Televison & Video
What size bolts hold the wall mount bracket to the tv
The bolts that hold the wall mount bracket to the TV vary in size depending on the manufacturer of the tv you have.
The best thing to do is to purchase a wall mount bracket specifically made for your TV.
It may be possible that your owners manual will list the size of the bolts you will need.
Aug 23, 2009 | Televison & Video
ILO 32" LCD
yes it is mountable. the 4 bolts are metric size is 6mm -1.0 x 40 mm
Use are large tv wall mount unit and buy the bolts seperately. I just hung mine and the
only problem I am having is I cannot remove the table top mount off the bottom of my TV
Can you halp??
Mar 29, 2008 | iLO 3200 32 in. LCD Television
Bush Industries IDLCD26TV16HD LCD TV Logo
44 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Raj Patel
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
