Question about HP Pavilion dv6000z Notebook
No display on startup; lights up and seemlingly boots but soon restarts process
Help
  • 186 Answers
First of all, try connecting an external display source like a Desktop Monitor to the VGA Port of the Notebook after turning it on and press hold the FN key and press the F4 key once to toggle the display to the monitor connected.
If you are able to see the display on the Desktop monitor connected to the Notebook, the issue is with the LCD, if not, the issue is either with the Graphic Card or with the Motherboard.
Additionally, I would like to inform you that HP had identified some hardware issues with few Notebooks installed with AMD Processors and is providing free repairs for notebooks purchased and currently available in US and Canada.
You need to get the Product Number of the Notebook which is indicated with P/N and is printed on a white sticker pasted at the bottom of the Notebook.
Check if the Product Number of your Notebook is listed in the list available in the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=c01300427
If your Notebook product Number is listed in the link provided above and if the Notebook is installed with AMD Processor, you need to contact HP Chat Support and provide the required details and get the Notebook repaired by HP for free.
You can find more information about this repair offered by HP from the link below :
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c01087277&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope this helps...
Posted on Oct 27, 2008
Doesnt startup,but rather displays "A disk read error occurred.Press Ctrl+Alt+Del",it does that again and again
maybe a usb device plugged? if not try in bios\boot sequence to set cdrom - hd - usbdev. then try to boot with the puppy sturdust linux cd. if it work is just the internal hd; format it and reinstall. hope it help bye
Nov 16, 2013 | Acer Aspire one D270-1375 Intel Atom N2600...
Disable auto shutdown
Restart the Computer and keep tapping the F8 key till you see the advance boot options, You should be tapping the key as soon as you see the manufactures screen. Once you get the advance boot options -> Select the option which says Disable Automatic Startup on System Failure.
Good Luck!!!
May 16, 2013 | Toshiba Satellite Computers & Internet
I can't restore windows startup. Asking to remuve music player or camera, bat it's not installed. No any CD or USB devices attached.
Restart your computer
during the boot process you will see on the screen a certain key to press usually the Delete or F2 to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Nov 12, 2012 | Computers & Internet
Monitor goes into power save mode as soon as I fire up my computer. Help!
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
hope this helps
Aug 18, 2011 | Computers & Internet
PoweReadACValue error
Probably it is cause due to power management system corruption
Try following steps
Perform a Clean Boot
If your computer is not starting normally, or if you receive errors when you start your computer that you cannot identify, you could consider performing a "clean boot." This operation starts the computer by using a minimal set of drivers and startup programs. This can help you troubleshoot the problem.
Method :Perform a Clean Boot
Step 1: Start the System Configuration Utility
1. Click Start, click Run, type msconfig, and then click OK.
2. The System Configuration Utility dialog box is displayed.
Step 2: Configure selective startup options
1. In the System Configuration Utility dialog box, click the General tab, and then click Selective Startup.
2. Click to clear the Process SYSTEM.INI File check box.
3. Click to clear the Process WIN.INI File check box.
4. Click to clear the Load Startup Items check box. Verify that Load System Services and Use Original BOOT.INI are checked. 5. Click the Services tab.
6. Click to select the Hide All Microsoft Services check box.
7. Click Disable All, and then click OK.
8. When you are prompted, click Restart to restart the computer.
Step 3: Log on to Windows
1. If you are prompted, log on to Windows.
2. When you receive the following message, click to select the Don't show this message or launch the System Configuration Utility when Windows start check box, and then click OK.
Note: Start Windows in Normal State
Steps to configure Windows to use a Normal startup state
After you used the clean boot to resolve your problem, you can follow these steps to configure Windows to start normally.
1. Click Start, and then click Run.
2. Type msconfig, and then click OK.
3. Click the General tab, click Normal Startup - load all device drivers and services, and then click OK.
4. When you are prompted, click Restart to restart the computer.
Sep 04, 2010 | HP Pavilion dv7-1130us laptop
Automatic restart boot
It is either stuck on the install process or you picked up a virus that was going around a while back. Run Virus check from a boot disk if you weren't installing Windows. If you where installing windows, format the drive and reinstall something glitched. You could try removing the file Firststart from the Main Directory but that rarely works.
Jun 29, 2010 | EliteGroup P4VMM2 Motherboard
This seems to be a common problem. The device seems to be trying to start or "boot" but will not function. The power button will not light up and the device does not respond to commands from computer. What...
Hi..
I suggest you to disable all HP related items, which will not startup at system boot up and might not cause any issues.
For Windows XP
Disabling HP Applications from MSCONFIG:
1. Click Start and select Run.
2. Type MSCONFIG and press Enter.
3. Click the Startup tab.
4. Clear the checkboxes for all HP related applications.
5. Click OK.
6. Restart the system.
You can restore any of the removed items by repeating the above steps and replacing the checks for the designated applications.
For Windows Vista
Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA
1. Click the Start icon.
2. In the Start Search text box located above the Start icon, type msconfig and then press Enter.
3. On the User Account Control window, click Continue. The System Configuration window displays.
4. Click the General tab.
5. Select the Selective Startup check box.
6. Verify that the Load Startup Items check box is not selected.
7. Click the Services tab.
8. Select the Hide All Microsoft Services check box.
9. Click Disable All.
10. Click OK.
11. Click Restart to apply the changes. The computer automatically restarts.
NOTE: After the computer restarts, a System Configuration message might display. If it displays, Ignore this message.
I hope this helps you...
Thanks..
Roger
Oct 11, 2009 | HP OfficeJet 7410 All-In-One InkJet...
My Memeo Auto-Backup does not start automatically with the PC. I have to go to START/ALL PROGRAMS to get it to load. It's been working fine for a couple of years, now suddenly it wont load automatically
Hi there!
The process for that application might have been removed from or disabled in the MSCONFIG startup file. To edit this, click Start>Run>Type: msconfig.
In the Startup tab, search for a process that is similar to or resembles the title of the application. You can also search by using the Command column by looking for the program folder the startup file is located in. Each entry will have it's corresponding company name in the path displayed. In this case that would be Memeo.
If that process is unchecked, check it and perform the same process within the Services tab - if the process has been disabled, the startup properties don't apply.
Click OK and you will be presented with the option to Restart or Exit Without Restart. To view the results immediately, restart and observe the behavior of the boot process. If the Auto-Backup doesn't load like it should, look in the Preferences section of the application and make sure "Launch application during boot" (or similar) is selected. Then restart once more to see what happens.
If the application still doesn't load, you may need to uninstall it and reinstall.
Hope this helps! Good luck!
Aug 19, 2009 | Computers & Internet
Frozen Toshiba P100
Try This. Restart your computer and as soon as it boots up tap the F8 key repeatedly until you see windows advanced options menu. select safe mode. when it asks you for the operating system just hit enter. as soon as it boots to safe mode do this. click start> run> type msconfig then hit enter. On the system configuration utility click on the startup tab then select disable all. Click apply then close. restart your computer again. It may be a corrupted startup program that is preventing your computer to boot up properly.
Oct 08, 2008 | Toshiba Satellite L25-S119 Notebook
Reformatting my computer
  • Using System Recovery CDs
  • Change the boot order in the BIOS:-
  • Turn off the computer:
  • Disconnect devices that are connected to USB, Fire wire, parallel and serial ports, except the keyboard, the mouse anb Internet Connection.
  • Turn on the computer.
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.)
  • Wait until the BIOS setup program opens.
  • Press the right arrow key to select Boot.
  • Press the down arrow key to select Boot Device Priority, and then press Enter on the keyboard.
  • Change the first boot device to CD-ROM using one of these methods:
  • Press the down arrow key to select the CD-ROM item. Press the + (plus) key to move the CD-ROM item up until it is the first item in the list.
  • Press the down arrow key to highlight the First Boot Device selection. Press the + (plus) key until CD-ROM is the selection.
  • Start the recovery:-
  • Press the Eject button on the top CD-ROM drive, and wait for the tray to open. Insert the System Recovery CD #1 and close the tray.
  • Press the F10 key to save the changes and exit BIOS.
  • With Yes selected, press Enter.
  • The recovery window automatically starts; wait for the onscreen instructions to display, and then follow the instructions:-
  • Press R, and then press the F key again.
  • Click yes to perform the full system recovery.
  • Insert the remaining CDs when directed.
  • When the recovery program finishes, click Restart to restart the computer.
  • Before the computer restarts, the CD tray ejects. Remove the CD
  • Return the BIOS to the previous setting
  • When the color screen with the logo appears, press the F1 key on the keyboard until Entering SETUP is displayed. (You only have a few seconds to press the F1 key before the normal startup process continues.) Wait until the BIOS setup program opens.
  • Press F5 Key to Set Default Settings in BIOS.
  • Select yes and press Enter.
  • Complete the recovery
  • After the computer restarts, a series of startup screens appear. Complete Microsoft Windows setup as follows:
  • Complete the registration process, and then reconnect the devices that were disconnected earlier.
  • Reinstall software that did not originally come with the computer.
  • Write data files that were previously saved on the backup CD or diskette you made from the hard disk.
Jul 04, 2008 | Computers & Internet
HP Pavilion dv6000z Notebook Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
