Question about Kitchen Ranges
Help, there's a small hole in bottom of my oven - an old Kenmore stove
This stove is at least 20 years old but still works fine. But while cleaning it, I noticed a couple of holes (corrosion?) in bottom of oven. Can I find a part for something this old? Doesn't seem good to have that kind of leakage from an oven. Can it be safely patched?
  • emsterdamsel Feb 21, 2012
    It's an apartment size 24" gas range from Kenmore. I'll see if I can find model no. Seems much cheaper to find a new floor for the oven. I was forced into an expensive remodel of the bathroom of my rental apartment and a new stove wasn't in my budget!! Sounds like there's no easy way to patch it? The oven was barely used in all that time except I think my tenant might have turned it on and left the door open for heating purposes which I forbade him to do! There was also moisture in the apartment. Not sure if any of these factors contributed. Trying to fix all these things!
  • 183 Answers
SOURCE: Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Posted on Jul 28, 2007
Bgillespie
  • 89 Answers
SOURCE: Oven pilot light will not stay lit on Garland 6 burner, double stove, salamander commercial in home
Use a needle right where the pilot flame comes out. Should do the trick. GOODLUCK!!
Posted on Dec 16, 2007
SOURCE: GE gas stove XL44
I have the same exact problem with my XL44, any ideas? Time to buy a new stove? If I do, no more GE for me!
Posted on Sep 11, 2008
SOURCE: Kenmore Electric Range - Door handle
I had the same problem with my stove. I tried to replace, glue the srews and other things, but nothing really worked well. It's a shame that Kennmore has such a design flaw in their stoves, but did nothing to help their customers.
Here is the solution that worked for me:
Fix the thread with helicoils (these are inserts that create a new threat in the handle). You can find the instructions how to use the helicoils on Youtube.
I replaced the crews with new screws that fit to the helicoil threat and now the handle is safely secured.
Regards
Michael
Posted on Aug 24, 2009
  • 552 Answers
SOURCE: there is a hole three
Not sure let me look into this for oyuy
Posted on Mar 08, 2011
Gas oven takes 30 mins or more to to preheat
Open the bottom and have a look at the burner while its heating. The flame should be strong blue/white and both sides the same, if they are not you have some blocked holes in the burner. Remove the burner and clean out the holes (carefully, don\'t ream them out, use a small paperclip to clean them, be gentle.). Above all do NOT use any kind of oven cleaner on them, if they are aluminum, and most are the oven cleaner will destry it.
Jul 29, 2014 | Kenmore Ovens
Gas oven tripping breaker
Get an electrician in, do mess about u could burn the hse down. Wiring probably cann't handle the specialist load.
Aug 26, 2012 | Kenmore Kitchen Ranges
My kenmore over stove microwave oven is now LOUD and not heating when on. What's up with that?
The problem is in the magnetron or the inverter board, either part will be costly.
May 29, 2012 | Kenmore Microwave Ovens
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Dislodged oven door, can't re-attach.
All oven door hinges have small grove or tooth that must be engaged to opperate correctly.
Reinsert hinges one at a time, noting there is a small "tooth" or "gap" on each hinge.
This gap must engage with the lower part of opening in which you place door hinges. When you engage one tooth, do same on opposite hinge. Door now works correctly.
Apr 17, 2009 | Kitchen Ranges
Regards
Michael
Jan 03, 2008 | Kenmore 96213 Electric Kitchen Range
Kenmore Convection STove - All Oven elements non-fonctional
is the control electronic wih a dial or the whole manual if you can answer me with the model number i can look it up there will be a serial plate some where on the front of the oven most of the time you open the bottom drawer mod#is a bunch of numbers like 106.48062890 should be able to help more after that
Dec 10, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
23 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
