Question about Panasonic KX-T7735 Corded Phone
Time display how do you change the time on these phones. the user manual is of no help with this.
  • Panasonic Master
  • 2,460 Answers
The SYSTEM manual is. From Jack 01 try PROG *#1234 then program 000 Your FWD button steps you through to the time and you dial the correct hour and minute (using the FWD button to step to the minutes after the hour). Press STORE to save it and PROG to exit.
Carl
Posted on Oct 28, 2008
The above directions worked perfectly! Thank you!
Posted on Nov 12, 2008
Avaya phone 5410 how can I manually change time
The IPO should get its time from the VM Pro server. The time server should be
set to the IP address if the VM Pro pc. If there isnt a vmpro pc, you can set
it manually.
http://mfurrer.dyndns.org/?p=224
For IP Office systems without access to a time server, a number of methods to
manually set the system time exist. These are available in the IP Office 4.1+.
The following method is only supported on these phones: 2410, 2420, 4412, 4424,
4612, 4624, 4610, 4620, 4621, 5410, 5420, 5610, 5620, 5621, 6412, 6424. It is
supported on any analog, T3, T3 IP or wireless (IP DECT, 3600, 3700 Series)
phones.
Note: If the IP Office system that is still configured for automatic time
updates (on by default), any manually set time and date will be overridden on
the next automatic update. The use of automatic updates can be disabled by
setting the System ' System ' Time Server IP Address to 0.0.0.1.
Enabling a User Button for Time and Date
Select the user who can adjust the system time and date.
If necessary create a new user who can be used to log in and set the
time and date before logging out.
On the User ' Telephony tab, ensure that the option System Phone is
selected.
On the User ' Button Programming tab select and double-click on an available
button.
Select Emulation > Self-Administer as the action.
In the Action Data field enter 2.
Enter an appropriate label for the button.
Adding another button set to the Emulation > Time of Day action is
recommended as this will allow the user to view and confirm the systems current
time.
In the User tab, Change System Phone Rights to "Level2"
Send the updated configuration to the IP Office.
Using the Programmable Button
Press the programmed button. If the user has a Login Code enter it as
requested, and press Done
The options Date and Time are displayed.
To set the date press Date.
The current system date is displayed.
Enter the new date, using two digits for day and month. Use the * or #
keys to insert the / separators. The format for date enter matches the locale of
the IP Office system.
During entry the key labeled <<< can be used to backspace.
When the full date has been entered as required, press Next.
Press Done.
The phone will return to idle.
To set the time press Time.
The current system time is displayed.
Enter the new time using 24-hour clock format. Use the * or # keys to
insert the : separator.
When the full time has been entered as required, press Done.
Nov 05, 2012 | Avaya IP Office 5410 Terminal - New
I have a corded model #77519 phone, how do I change the time and date.
The complete user's manual for your phone is available at the following link:
http://www.retrevo.com/d/df/MANUAL000032975.pdf?doc=532906c5a747ab87134404141e9c11c8&ts=1313184836863&rk=0.17208479428095913
Just use your mouse to click on the link which is the highlighted and underlined text above. This will open a new browser page for you automatically and allow you to download the manual.
Here is an excerp from that manual which describes how to set the time and date:
GETTING STARTED
Caller ID Initial Setup:
After the battery installation and telephone line connection the display will show the Set Language screen:
Set Language
1. Press the Review UP or DOWN button to select the desired language.
E=ENGLISH
F=FRENCH
S=SPANISH
2. Once the desired language is selected , press the ERASE button to
confirm selection.
3. Then the display will change to the Set Time / Date screen and the hour icon will be blinking.
Set Time/Date
1. Press the UP or DOWN button to set the current hour.
2. Press the ERASE button to shift to the minute setting.
3. Repeat steps 1 and 2 above to set MINUTE, MONTH and DATE.
4. Once the correct TIME/DATE is shown on the display, press the
ERASE button to end the setting. Then the display will change to
show the normal status.
Changing The Language Mode and TIME/DATE
1. Press and hold the ERASE button then press UP button.
2. Then follow the steps described above.
Good luck, I hope this was helpful.
Joe.
Aug 12, 2011 | Northwestern Bell 77519 Corded Phone...
How do i change to time & date on the display?
Go to settings and change it..Find the Correct instructions in User Manual.
Nov 08, 2010 | NorStar M7310 Phone
Is there an downloadable users manual? we just installed this phone and do not know how to set date/time.
Here's a link to avaya's site for a Partner ACS users guide. Not knowing which type of partner system you have, this one should get you into the ball park. Theres also programming and installation guides for the different systems there.
http://support.avaya.com/css/P8/documents/100007287
Also, here's how to change the time.
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#103"
the display should say system time and the current programmed time
enter the new time in 24 hour format
press feature "00" to logout
Nov 04, 2010 | Avaya 18D Phone
Panasonic KXT7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Nov 03, 2008 | Panasonic KX-T7453 Corded Phone
Change time
Hey here is something you can use to adjust the time on your T7206.To Change the Time:
1. Press the CHANGE softkey Display will read: "Hour:
2. Press the CHANGE softkey Display will read: "Hour: _ "
3. Enter the new HOUR. (in 24-hour format - Ex.: 5:00pm = 17:00. Display will then read the new Hour programmed.
4. Press NEXT Display will read: "Minutes: # # "
5. Press the CHANGE softkey Display will read: "Minutes": _ "
6. Enter the new MINUTES.
To Change the Date:
1. Press NEXT Display will read: "Date DD MM YY"
2. Press the CHANGE softkey Display will read: "Year: # # "
3. Press the CHANGE softkey, (If the year is incorrect) Display will read: "Year: _ "
4. Enter the new YEAR Display will then read the new Year programmed.
5. Press NEXT Display will read: "Month: # # "
6. Press the CHANGE softkey, (If the month is incorrect) Display will read: "Month: _ "
7. Enter the new MONTH Display will then read the new Month programmed
8. Press NEXT Display will read: "Month: # # "
9. Press the CHANGE softkey, (If the day is incorrect) Display will read: "Day: _ "
10. Enter the new DAY Display will then read the new Day programmed
Let me know how that turns out and good luck
Oct 03, 2008 | NorStar T7208 Corded Phone
Change display information
Feature **23646 password 23646 (if you phone admin hasn't changed this) and then select set day& time then change there
Aug 07, 2008 | NorStar M7208 Corded Phone
Panasonic KT-T7431
Hello. You can change the time when you enter the User Programming Mode (this information is found in the Digital Super Hybrid System User Manual, not in the manual for the phone):
Press PROGRAM + ** + User Programming Password (default is 1234)
Press 000
Press NEXT (Sp-phone button) : The date will be displayed.
Press NEXT (Sp-phone button): The time will be displayed.
Use the <-- (Conf button) or --> (FWD/DND button) to move along the line and keypad to update
Press Select for AM or PM
Press Select for 12 or 24 clock hour
Press STORE (Auto Dial button)
Press END (Hold button) to exit
Hope this helps you all!
Sep 24, 2007 | Panasonic KX-T7431 Corded Phone
How do I change the date and time on display screen
how do I change the time i've press program and # what is next
Jun 08, 2007 | Sony (ITID80) Phone
Panasonic KX-T7735 Corded Phone Logo
255 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
