Question about Hobart Welding Tools
Schmatics hobart porta feed 17 - Hobart Welding Tools
2 Suggested Answers
luis_david
  • 407 Answers
SOURCE: I am in need onf
It's call gun block assy. part number is: HOB 193189, DUAL 035-045 drive roll part number is: HOB 202926
Posted on Jan 15, 2011
Hobart porta stick .is it possible to do steel and aluminum with this machine.dc only ?
Not really.
You can purchase aluminum stick electrodes, but they generally don't work that well.
You will find it best just for steel.
May 05, 2017 | Hobart Welding Tools
How to remove "sewage" odour from porta potti
Amazon Sell this product: Thetford 1.5L AQUAKEM & RINSE DUO PACK. It's around £16-17 for the two bottles.
Jan 06, 2015 | Sport & Outdoor - Others
Wire feed is not stable on Hobart handler 135
is this a lower end machine ? the cheaper machines take the power from the welding transformer to power the feed motor and as a result the feed isn't stable, also is the wire liner and tip in good condition if not replace them, try blowing through the liner with compressed air to clear any dust from the wire
Sep 17, 2013 | Hobart Welding Tools
Need tascam porta 07 manual
Havent find the porta 07, most simmilar I think is porta02. I suggest to go to the http://www.tascam.com and and look in right corner in same line with the menu (under- legacy products). When you choose the product an image will came. Go to the RESOURCES tab to get the manual.
This site has a service manual for 17$:
http://www.bonanzle.com/items/search?item_search_page[only_title]=0&item_search_page[search_term]=SERVICE+MANUAL+TASCAM
Aug 06, 2010 | Audio Players & Recorders
I have a Hobart handler 120/90amp wire feed welder.When i try to weld,all i get is a small spark.I turn it off,turn it on and it does it again.The wire feed works good,it just sparks,but will not keep...
I have welded countless hours with Linde & Lincoln & even a few Hobarts & the only time that I ever had the same problem was when the ground connection either to the object I was welding, or the welding cable ground wasn't good & clean & tight. Same on stick welders also. I did develop the habit of grinding not only where I was preparing to weld, but where I was placing my ground clamp & that always provided a better "frying bacon" sound as I went along the business of pushing a bead. In a welder, the only other thing than that is involved is the step-up transformer and your wire. Hope this helps.
Feb 01, 2010 | Hobart Welding Tools
Hobart handler 135 feed motor for wire doesn't feed wire. motor is ok I tested it with seperate power source. No power to motor from main board or ??????
check the SCR ,looks like a big transistor mounted
to a heat sink or some of the older units had a relay
in-line with a fuse , I have a older Hobart and it is
a great little welder. If you snap a pic of the P.C.
board and email it ill rsheehan@northernsteeldesigns.com
point out what parts to check.and replace.
Rob
Dec 06, 2009 | Hobart Handler 140 Mig Welder
Hobart 135 wire feed sped control problem
you have a resistor down, first check the resistor on the centre pole then those going off to the two other pins
Oct 04, 2009 | Hobart Handler 140 Mig Welder
Hobart handler 140 will not feed wire
A schematic would certainly help, give Hobart a call and ask for a wiring diagram. or manual. Hobart are very helpful and may even give you guidance, you may have to pay the postage, they usually fax these documents so it will not cost you anything.
Feb 13, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
81 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
Troy
Troy
Level 1 Expert
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
