Question about Transcend StoreJet Computers & Internet
My laptop does not recognize the transcend tho i have already used once and taken the backup
When i run SJelite3.exe i got following error if you already have your storejet device connected you might have to copy the SJelite3.exe file on the store jet device
bob_computer
  • 3153 Answers
SOURCE: store jet transcend 160gb not detected
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
saqeb
  • 47 Answers
SOURCE: transcend storejet 25 mobile 160gb show error " usb device not re
Most probably your drive has been damaged. Try it on another system and if fails, no way
Posted on Jan 28, 2009
sarasvatas
  • 329 Answers
SOURCE: My Transcend StoreJet 500 GB external disk is not
first try to connect it from usb port at backside of cpu. if it works well ....ten do reply me .....
Posted on Sep 30, 2009
  • 81 Answers
SOURCE: transcend storejet 25 mobile is not recognised
if your unit only uses one cord ( USB ) for data and
power , the unit side may be damaged , the life span
of the USB hubs and the cords that use them are not known sometimes for no reason whatsoever they stop
working , and is the most common reason for hard
ware to malfunction , and it is possible to replace
the outer closure , remove the HDD you can find
a suitable replacement closure at radio shack for
40$ that allows you to hook up a 2.5 SATA HDD
to any computer Gigaware makes a very nice
portable model , if the HDD works then you have
just trouble shot the closure to the HDD .
Posted on Jan 28, 2010
  • 104 Answers
SOURCE: MAC unable to read this storejet device
The format of your external drive is most likely NTFS which is used by Vista and Windows 7. At best the latest OS X can only read NTFS format with care..
You best bet is to put the data on dvd - r or (i prefer for DVD archiving) + r since you'll be able to port that to anywhere. Alternatively, after saving the data to an interim PC, reformat to FAT. Note FAT can only address 32 GB. so you might need to divide it into multiple partitions.
I hope this helps or you found out differently.
Posted on Mar 28, 2010
Error message: mbkkxhu11pchbsrfg.exe not recognized
Run both free utilities Spybot S&D.exe & Malwarebytes.exe to clean that unit up immediately. Get both at www.filehippo.com enter both names 1 at a time in the upper search window there. Download both, install both, run both.
Dec 04, 2013 | Computers & Internet
My Transcend Storejet just goes off-line...
better to swap, cannot trust a device with this error
Nov 15, 2013 | Transcend TS1TSJ25M3 - StoreJet 25M3 1 TB...
App error 523
Hi there
App error 523 means there was an application that caused corruption to your operating system.
You will need to reload the software to remove this error. It is best to update it as well if you are reloading the data. You can do this by going to this URL and getting the most up-to-date version of your software:
http://us.blackberry.com/support/downloads/download_sites.jsp
Once you download the blackberry device software you can run it on your computer and follow the prompts that it gives you. Once this installation is complete you can connect your phone to your computer and run the desktop manager. It should recognize your phone and then indicate that there is an update for your phone (if you don't already have the newest software on your phone). Make sure that when it prompts you to do a backup that you backup everything. If this does not work the first time try again. If it still will not work you can still reload the data but it is much more complicated. You can post a comment to this if it does not work and I can give you instructions for doing a complete wipe of your handheld and a reinstallation of the software. Good luck!
Sep 19, 2011 | RIM BlackBerry Curve 3G 9300 Cell Phone
How to backup my desk top and Acer Laptop to external HDD AH0025
dear thillai
you can make your laptops backup by using drive snaphot its a very small utility you can download from the internet (http://www.drivesnapshot.de/download/snapshot.exe)
just download and run this program and then make backup to drive you wish to.
thankyou
Gagan Gupta
Is that Useful?
Mar 17, 2011 | Computers & Internet
Reading jvm 102 error rest
Hi, you have to follow the instruction below to correct the jvm 102 error reset problem..
Step 1
Very Important!!!!
It is important to have the following software installed on your computer (at home and at work if you can):
1 - Desktop Manager - Hopefully this is already on your computer, if not click here:
https://www.blackberry.com/Downloads...93E4F3BB068C22
2 - Device Software for your BB - Here is the link for you to get the latest OS for your Blackberry
http://blackberryforums.pinstack.com...ll_models.html
3 - Java Commander - You can download it here:
http://blackberryforums.pinstack.com...d=5&linkid=452
4 - Backups - You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book, or at least once a month. If you do not already have a data backup, you are out of luck (SOL) as your data is gone.
STEP 2
The Process
From Pinstacker JTReeves:
You should be creating a backup of your device data regularly, e.g., as often as you update your calendar and/or phone book.
If or when you get a JVM Error 102/Reset message, do the following:
1. Connect your BB to the computer.
2. Run JL_Cmder
3. Choose option 5, wipe the device. This will delete all files - OS and data - from your BB. The BB screen will show JVM Error 507. This means the BB has no files installed.
4. Using Desktop Manager, reinstall your software. When you run the Application Loader, check all the available boxes.
5. When this process completes, restore your most recent backup file.
You should be back to normal, with the exception of having to reregister OTA or other 3rd party apps. Save their reg numbers in your Memo app so that you have them handy.
Jan 18, 2011 | RIM BlackBerry Storm 9530 Smartphone
Erecovery management
use an external usb cd or dvd burner
Mar 08, 2009 | Acer Aspire 5720 Notebook
Antivirus 2009
I see these every day, note: also fixes AV 2008 and many others.
This Malware is known as "Rogue anti-virus" software.
This program will remove it: http://www.majorgeeks.com/downloadget.php?id=5360&file=10&evp=2e0d43eb67e1e71c0b31e62c003599c0
the website that has it also has a really good antispyware program called malwarebytes
www.malwarebytes.org
once you run a full scan in this program run this program:
http://www.superantispyware.com/downloadfile.html?productid=SUPERANTISPYWAREFREE
it's another free antispyware. these are both professional grade removal software for free. I remove this stuff about 3 times a day. It seems this outbreak is the largest I've ever seen.
If you want a good protection suite that will keep it out buy a copy of NOD32 (www.nod32-av.com) another you may not have heard of, it will block this and many others before it even gets on your computer.
Jul 17, 2008 | Balance CN6555 Notebook
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Computers & Internet Logo
66 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
John Porter
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
