If i call my ip phone and it's busy, voice message
  • 112 Answers
SOURCE: How do you do a factory reset on the Mitel 5220 IP Phone ?
To Restore Factory Default Settings:
1. Press both Up and Down Arrow keys simultaneously while powering up the
phone. NETWORK SETTINGS? appears
2. Press NO until TOOLS & FEATURES appears and then press YES.
3. Press NO until RESTORE DEFAULTS? appears and then press YES.
4. Press CONFIRM. The phone resets with default settings.
Posted on Jan 11, 2009
  • 8 Answers
SOURCE: ip 5220 Mitel
You'll need to log into the voicemail server or PBX that hosts the VM and reset the passcode for each mailbox you're trying to access. If you have an embedded Mitel VM you can change the passcode by logging into the Admin mailbox then select option 2 to edit mailboxes, pick the mailbox to edit and follow the prompts until you have the option to change passcode
Posted on Feb 10, 2009
  • 5 Answers
SOURCE: how to clear message waiting light on Mitel 5220 IP Phone
it depends on the setup of the system the codes can be changes by the admins.
Mine is set to #87
You need to dial this code then your extension number so if your extension is 1234 you would dial #871234 this in theory can be done from any ext, it does not have to be yours, there is a posibility that it will not work as you can change permissions so tht some extensions cant do this. If ythis is the case ask your admin to change the "class of service"
Posted on Apr 15, 2009
  • 3 Answers
SOURCE: mitel 5220 ip phone locked out ICP 10.0.0.135
Locked out generally means the phone is off the hook and there is no live call. Just press the X or cancel key, or pick up and hang up the phone.
Posted on Jun 24, 2009
  • 3 Answers
SOURCE: need installation/hook-up instructions for mitel
Generally you just need to log into the ICP and go into desktop device assignments. The default username and password for a SX-200 is:
Username: installer
Password: 1000
If you don't know the IP of the ICP, you can try netscan (www.softperfect.com/products/networkscanner/) and sort through the results.
How do I delete voice mail from a Droid Maxx
Go into voice mail and listen to your message then press option 3 that will delete the message
Just repeat for all messages hou wsnt to get rid off
Sep 27, 2014 | Motorola Mobility DROID RAZR Maxx 4G...
The very first password that comes with the phone new out of the box. I can't access the voice mail without a password.
The voicemail password is typically set on your PBX or Callmanager. The phone is only a registered extension, when you enter the VM password it is simply passing those digits to your PBX for validation.
Sell Cisco Phone Equipment
Aug 31, 2012 | Cisco 7942G IP Phone
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
Aug 09, 2012 | Panasonic KX-T7630 Corded Phone
Hello I have question regarding Avaya phone (red light on the top of the device) Why some users have that light on and some of them they do not?
When you get a new voice message the red light turns on. As long as you don't check the voice message the red light stays on.
Sep 07, 2011 | Avaya 5610 IP Phone
Phone shows a voice mail but no message on phone
The phone's voice mail indicator works with the voice mail function from your phone service provider. When your line is busy or goes unanswered (depending on how it's set up), the message is recorded by your service provider at their end, and you need to retrieve it. Most systems give a "stutter dialtone" when you pick up the phone to make a call (a few short bursts of dialtone before it becomes steady) to tell you when there's a waiting message. The message waiting light on the phone lets you know in case you don't pick the phone often.
Once you pick up your voice mail the light will go out and the dialtone will go back to normal. Check with your service provider for how to do it.
May 25, 2011 | Lands Phones
We use the Mitel 5212 IP phones for our hotel. We are trying to find a way to retrieve a previous voice message from a previous guest that stayed with us. How should I go about finding this information?...
If you're using the embedded voicemail, you won't be able to retrieve such messages. If you're using another, external, voicemail system, then it might be possible.
Every hotel I've ever installed, I've left hotel admin guides for the voicemail. This information should be in such a guide if your vendor is any decent.
To find out what sort of voicemail you've got, you should contact your vendor.
Sincerely,
Mark
May 12, 2011 | Mitel 5212 IP Phone
Message waiting led stays on even though there are no messages in voice mailbox
There is this thing on Norstar systems called Reply message... this turns on your voicemail light, but there is on messages when you go into the mailbox.
Try this: FEATURE # 6 5
There might be something on you set that will tell you who sent the message, and you can hit the # or press the OK button to cancel this message!
Good Luck.
Jul 14, 2009 | Nortel Business Series Terminal T7208 -...
"flash busy" message when trying to retrieve voicemail messages
It is telling you that the voice mail ports are busy and can not take another call in to the voice mail system. If the port the does not clear up after a min or two then reset the voice mail system . Unplug the power cord from the wall and let it set for a min , then plug it back in and wait about 5 min for the system to come back up , that should free up the ports .
Apr 16, 2009 | Lands Phones
New Voice mail flashing on phone but no new messages
Have someone call you and leave you a message. then listen to the message and that might reset it.If that dont work call the manufacturer and they will walk you through it and should not charge you for it.
Jan 04, 2009 | GE 25865 Cordless Phone
Computers & Internet Logo
David Payne
David Payne
