Question about Dryers
Kenmore dryer exploded diagram - Dryers
I have a kenmore elite he3 smart heat quiet pak4 how much is a motor for this dryer
  1. Kenmore Elite He3 Parts - searspartsdirect.com‎
    Adwww.searspartsdirect.com/Kenmore-Parts‎rating for searspartsdirect.com
    Shop Today at Sears PartsDirect™. The Largest Appliance Parts Seller.
    Ratings:Shipping 9/10 - Website 9/10 - Selection 9/10 - Quality 9/10
Search Results
    MOTOR diagram for model # 41794130000 Kenmore-elite ...
    www.searspartsdirect.com/model-part/41794130000/0583/.../00004.html
    MOTOR Diagram and Parts List for KENMORE ELITE Dryer-Parts model # ... MOTORdiagram for model # 41794130000 Kenmore-elite-Parts Dryer-Parts (18).
    PUMP AND MOTOR PARTS Diagram & Parts List for Model ...
    www.searspartsdirect.com/model-part/11047789702/0583/.../00006.html
    PUMP AND MOTOR PARTS Diagram and Parts List for KENMORE ELITE ... ANDMOTOR PARTS diagram for model # 11047789702 Kenmore-elite-Parts ...
Nov 01, 2015 | Kenmore Dryers
Locating heating element kenmore 80 series and a safety switch
If you are looking to purchase replacement parts, you can purchase on line at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Use your model number for your search criteria. Prices vary between these sites, so shop and compare. The first three sites listed also have helpful exploded view diagrams to assist in parts location/identification.
If you are trying to determine WHERE these parts are located on your dryer, please post back with a complete model number (located on a nameplate around the door opening) so I can determine how your dryer is configured.
If you have questions, please let me know. I hope this helps you.
Jan 14, 2010 | Kenmore 63942 Dryer
Need exploded pic of dryer and instruction on how to replace belt it is broken
Searspartsdirect.com has some excellent exploded view parts diagrams you can refer to. Two other sites you may also try are pcappliancerepair.com and appliancepartspros.com.
For dryer belt routing diagrams, refer to repairclinic.com. Click on the "Repair Help" link, followed by the "Dryer Belt Diagrams" link under the "Special Features" section.
If you need further assistance please let me know. I hope this helps you.
Dec 29, 2009 | Dryers
Need to replace heat element in Kenmore dryer model #96350100. I need a diagram of the inside of dryer and where the piece goes
go to http://www3.sears.com
Look up your model# . ( BTW, the model number should start with 3 digits, followed by a dot)
Click on the section you'd like to se the exploded view of.
Enjoy :)
Oct 13, 2009 | Dryers
My Kenmore HE dryer door handle has cracked. How
Carefully remove the door from the dryer by removing the screws from the hinges and lie on a flat surface face down. Lay a towel under the door to prevent scratching the door window. Remove the screws from the back of the dryer door and the hinge. The back panel should lift off exposing the screws holding the handle in place.
Searspartsdirect.com has some excellent exploded view diagrams that you can work from as well.
Sep 30, 2009 | Kenmore Elite HE4 Electric Dryer
Schematic Diagram
I couldn't find an electrical schematic, if that's what you're looking for. If so, let me know what it is you're trying to troubleshoot via the comment button.
Here's a link to three (3) line drawings (exploded view) for your dryer that might be helpful.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.66524501&pop=flush
Hope you find this very helpful. Best regards!
Aug 18, 2009 | Kenmore Dryers
Kenmore laundry center stacked washer/dryer washer tub shakes almost violently on spin cycle.I may have changed setting during spin cycle.Tub is off balance.The appliance cabinet is balanced and on a solid...
Head over to the manufacturer's website.
www.SEARSPARTSDIRECT.com and enter your full model number for an expanded parts diagram and ordering information.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 11, 2009 | Kenmore Washing Machines
Kenmore dryer wiring diagram
Can I get a diagram to fix the heating problem for a Kenmore dryer?
Jan 13, 2009 | Kenmore 62602 Electric Dryer
Don't know if this is right model
Okay...took me a while to get a good cross reference on this one. Drop the last four characters of your model number and place a "110." in front of the remaining numbers. That way the number reads 110.86921100. The "110" identifies the manufacturer. Your dryer is made by Whirlpool. If you go to searspartsdirect.com and type in the model number I provided, there are a series of drawings on the next page showing an exploded view of the layout of your dyer. Does this look familiar to you? Under the "Cabinet" heading you will find the dryer belt listed as item number 56 (part number 341241). For a diagram of how the belt goes on, go to repairclinic.com and you will find a dryer belt diagram link listed under the "Repair Help" section. Locate the Whirlpool diagrams and you will use drawing "K". I apologize if this sounds like absolute madness. If you get confused, please post back and let me know. I hope this answers your questions.
Jul 23, 2008 | Kenmore 62872 Electric Dryer
Kenmore TopLoad Drying Machine
It could be a part in the bulkhead unit. Shaft, Tri Ring, and support roller all fit together. You can put grease on the rollers and shaft support if they are in good shape. You can download the 3D-diagram, and parts list from HTTP://WWW3.SEARS.COM All you need is the model #110-62622100. If you do need parts, you can order them from the website and it comes with an exploded diagram on how to repair it. GO YANKEES !!
Jul 09, 2007 | Kenmore 62602 Electric Dryer
Dryers Logo
22 people viewed this question
Top Dryers Experts
