Question about HP PSC 1410v All-in-One Printer
Printer problem when i power on my hp all in one printer .the cartridge carriage starts banging and jumping from left to right non-stop with a very heavy noise.it was working properly till yesterday.just shifted the printer and the problem started.please help.......
  • johntoday Oct 27, 2008
    thanks for your help .i will check.
    Scholar:
  • 155 Answers
Its a problem of the encoder strip . either the encoder strip is loosened or damaged.the carriage sensor reads the plastic encoder strip while it moves.if the sensor is not able to detect the encoder ,such a problem arises.u can check the position of the encoder and take the necessary step accordingly.if the encodder is damaged replace it.
good luck.
thanks.
Posted on Oct 27, 2008
Hp desk jet 3512 making banging noise on start up and say cartridge jam
Probably a CARRIAGE jam, not likely a cartridge jam. Paper dust and stray ink can cause the end of carriage sensor(s) to malfunction. This will cause the carriage to crash into the stops. Sometimes cleaning the sensors can solve this. Other times the crash damages the carriage drive gears and basically requires the printer to be replaced. Repair is not really an option as these things are so inexpensive they are manufactured as throw-away items.
Sep 07, 2016 | HP Deskjet 3512 Inkjet Multifunction...
HP Photosmart C3180 carriage permanently stuck on right. How to fix this?
If the carriage totally stuck on the right side of the printer, Unplug the printer from Power outlet.
Open the front access door. You will see the cartridges. Remove the cartridges. Check for any paper stuck in the Carriage Rod. Try to manually move the carriage 5-6 times left to right and it should move without any trouble. Put the cartridges back into the Cartridge slot and power on the printer
If the Carriage does not move manually, there could be chances the printer needs mechanical repair as its broken.
Regards,
Sean
Sep 16, 2012 | HP Photosmart C3180 All-In-One InkJet...
My hp printer 960 c ligth keep blinking red
One or both ink cartridge is failed.First remove the cartridges and clean the contacts on the carriage unit using piece of cotton and some alcohol.If problem persist open the cover and look where the carriage unit stops.There is two marks on the left side where the carriage stops.On the carriage there is a yellow arrow.If this arrow show left mark the color cartridge ia failed and need to be replaced.If the arrow show right mark replace the black cartridge.If you replace both cartridges and problem still persist carriage unit or logic board assembly is failed and your printer need service.
Nov 26, 2009 | HP DeskJet 960c InkJet Printer
Yellow light for ink missing is blinking all the time i put the two new black and color catridge
This is a typical cartridge problem.Try clean the contacts on the carriage unit using piece of cotton and some alcohol.If this not help open the printer cover and look when carriage unit stops.On the carriage unit have a yellow arrow.In the left sidе of printer, where the carriage stops have a two icons.If the arrow shows left icon change the color cartridge.If shows right icon change the black cartridge.If this not help there is a problem in carriage unit and your printer need repair.
Nov 05, 2009 | HP DeskJet 1280 InkJet Printer
The red light on left is blinking. What does that indicate? I have a deskjet 904C. There are three light The left one is blinking, the middle is okay and the right is the green one, that shows me the...
Hi:
If you open the door on the top of the printer, while it is powered on, the ink cartridges will move to a spot that shows you the status of your ink.. There are little cartoon pictures of the cartridges with smiles or frowns to tell you if you have an empty color or black cartridge.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
Hp deskjet 882c printer carriage is stuck
Hi first of all you need to make sure that everything is in good shape on the carriage and the cartridge holder,
also check if you have any broken plastic pieces in the printer.
you mentioned the reset a well
was it a partial or a semi full reset
another thing which we can try is
1>take out both the cartridges
2> unplug the power cable while the printer is on
3>press the power button for 30 sec to remove the static
3>replug the power
now let the printer lights blink prompting you to put the cartridges
4>put the black cartridge first
some Hp printers work on single cartridges as well.
5>see if you hear the same grinding noise again
6>try cleaning the rollers with a little damp lint free cloth
7>try putting the color cartridge
make sure that the cartridges snap inside properly.
8>see if the problem persists
Jun 15, 2009 | HP DeskJet 882c InkJet Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
970 Cse cartridges bang over to the left and then nothing
I had the same problem with my HP Deskjet 970Cse which was quickly resolved by going to the below HP site and looking under the Issue: The carriage is stuck or makes a grinding noise. Note that the blinking lights displayed as: Resume Light Blinking Simultaneously AND Power Light Blinking Simultaneously.
The Solution:
1. Lift the top cover to the printer.
2. Turn the printer off and then on again.
3. Unplug the power cable from the back of the printer when the grinding noise starts.
4. Move the carriage towards the middle of the printer.
5. Take out the cartridges and close the top cover.
6. Plug the power cord to the back of the printer. Turn the printer on.
7. Open the top cover, reinstall the cartridges, and then close the top cover.
Hope this helps as it worked for me.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&lc=en&cc=us&lang=en&product=60097&dlc=en
Jan 11, 2008 | HP DeskJet 970cse InkJet Printer
System error 000 carrier stall Presss power Key
Does carriage bash against side when power up? if so encoder strip is dirty or incorrectly seated... plastic strip inside printer lines on it 1cm wide, must sit vertical in slot on carriage
Might be somethin stopping print head from moving along rail, check ink carts are installed correctly and fully, check for paper squashed up left and right inside ends of printer. make sure carriage moves left and right
Try power up without cartridges and just black and just colour cart to eleminate cart faults does error change?
Oct 19, 2007 | Lexmark X85 All-In-One InkJet Printer
HP PSC 1410v All-in-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
