Question about Cell Phones
How do i get my Android phone blue tooth and pair my friends t- mobile behold phone
SOURCE: pairing a nexus drivesmart
To put the Drivespeech into pairing mode - with power OFF, press the power on button until the Drivespeech powers on and CONTINUE to hold the button until it announces it is in pairing mode and the LED flashes alternate Red/Blue.
Select 'Discover' on your phones Bluetooth menu and enter the code when requested (usually 0000 or 1234)
HTH
Posted on Mar 23, 2009
SOURCE: I need a pairing code
Thanks, the code 0000 for the T305 worked.
Posted on Apr 07, 2009
SOURCE: Nexus bluetooth lost code to pair with new phone
1234
Posted on Apr 23, 2009
  • 12 Answers
SOURCE: pairing an "universal" bluetooth to the samsung behold
Do you still have the user manuals for both the phone and the IHF1000? Start by reading the bluetooth pairing sections in both manuals and trying what is listed. If you have already done this, then please detail where you are having difficulty in the pairing process.
Posted on May 05, 2009
  • 21 Answers
SOURCE: nokia 5800 will not pair
Try sending an MP3 to the Parrot kit. I couldn't even get the Parrot BT in my car to ask for the BT password numbers but found out to try sending an MP3, which will fail by the way, and it asked for the password finally.
There was an error in my case, but then the phone asked to connect to the Parrot again and the pairing worked.
There is an issue with newer Nokia phones, something I will be thinking about next phone upgrade.
Posted on May 11, 2010
How to send music to a cellphone
You can transfer the music files to computer, and then use an android transfer software to add them to your another phone.
MobiKin Assistant for Android Windows Version
Jun 26, 2017 | Cell Phones
When i try to pair with my galaxy tab s through bluetooth the tab goes through the process of connecting but doesnt pair however my galaxy s5 phone pairs immeditely ?
  • Your issue is that you can only connect one mobile or tab to a blue tooth.
  • It only accepts one device at a time.
  • You need to connect one to your blue tooth in your vehicle and try something like a blue tooth pill or blue tooth speaker.
  • I have had this problem with my Parrot car kit.
  • Hope this helps. Russell
Nov 22, 2015 | Cell Phones
How do you pair blue tooth to Jabra VBT185z
it auto pairs .
set mobile phone to bluetooth on
finger click on blue tooth and select discover bluetooth devices
you should see mobile phone detect jabra vbt185z
then pin is 0000 if asked
http://uswww03.gnnetcom.com/jabra/verizon/vbt185z/Datasheet_VBT185z.pdf
Oct 19, 2015 | Jabra Radio Communications
How do you connect it to a nokia 6300
To connect a jabra 250 to the Nokia 6300: On the Nokia go to menu > settings > connectivity > bleutooth = select and the next line = visible
On the headset when it is off > push the upper button for ± 8 seconds until the lamp is burning constant and release this button.
Choose on your Nokia on the same bleutooth menu > search audio.... It will be pairing in a few seconds . It will ask if it is ok to make the connection. The password is "0000" and push on "yes"
I hope you cann understand my english, I'am dutch.
Nov 17, 2010 | Jabra BT250 Consumer Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
What is the bluetooth passkey code for lg gt505 mobile phone to pair with other devices
HOW TOCONNECT BLUETOOTH
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Take care.
Jul 02, 2010 | LG GT505 Cell Phone
I AM TRYING TO PAIR MY MOTOROLA HEADSET HS801 WITH MY NOKIA MOBILE PHONE BUT THE PHONE ISN'T FINDING THE HEADSET.
have you checked if the battery for the blue tooth is charged? And did you power the blue tooth device on, like wide that of the Nokia phone before you begin pairing?
If all the above are intact and the blue tooth is still not finding the phone, Then you have to test the blue tooth with another phone to be sure its not faulty.
Best regards.
Feb 19, 2010 | Motorola Mobility HS801 Consumer Headset
How do i run my motorola h505. I got it from a friend and have no idea how to use it.
the following procedure is dependent to the phone in use!
1. Turn on your mobile phones bluetooth function
2. On the Moto headset, From turned of state, Try holding down the power button for at least 5 seconds.
- The light should stay constantly on
3. search in your mobile phone for blue tooth devices(the phone and headset shouldn't be more than 5 meters away from each other )
4. When you find your blue tooth headset, chose it and hit "connect" or "pair" with the device!
5. you will be asked for a pin, put in "0000" and ok!
now your headset should be paired with your phone and work for receiving calls!
Great Success :P
Bruce
Dec 07, 2009 | Motorola Mobility H505 BLUETOOTH HEADSET
I have an audi S4 2007 what is my blue tooth pairing code???
When u want to pair your bluetooth phone the first time, you must do this in the first 30 seconds after ingnition. This is the only period your audi bluetooth carkit is in search mode. Follow these steps to make it work:
Put your bluetooth phone in search mode, then start your car. Your phone will now detect something like AUDI UHV-1 or similar. Connect to this device, and enter either code 1234 or else code 0000. Your phone will then connect. Command your phone to keep the Audi device listed as a save connection, which can automatically connect. The next time you enter your car it will connect by itself (after ignition that is).
Dec 21, 2008 | 2007 Audi S4 Convertible
Cell Phones Logo
16 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
