Question about Casablanca Fan Bel Air 3811T Ceiling
Casablanca fan speed problem
Fan operates by a wall switch with three buttons, light, fan speed, and Power. one touch on the fan speed normally gives low speed, then pressing 2 times gives medium speed, and so on. Now, one press on the button gives only high speed, no low or medium. This has happened to two of these ceiling fans. Do we need a new switch or what?
  • 37 Answers
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Posted on Jan 24, 2009
How do you operate a inteli-touch casablanca ceiling fan
i looked everywhere,casablanca doesnt have anything but a picture,but,i eventually found this for you,dont break it,there are no parts being made http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ReplaceElectronicsIT.pdf
May 28, 2015 | Casablanca Fan CAS 66668T Panama II...
Casablanca Isatope 52 inch fan not working
The combination of wall switch control and remote control tends to throw the unit into a tizzy. Try disconnecting power at the source and starting all over again. You may have to abandon wall switch control and rely solely on the remote.
Apr 02, 2017 | Casablanca Fan Televison & Video
I have three casablanca fans in three rooms. An electrician installing electrical outlets, in the attic says he only accessed the main power line. However, all three fans suddenly malfuctioned in the
Are the fans all on one main line just for the fans and are they plugged into a GFI receptacle. If so you may have to reset the GFi or maybe your electrical box needs to be reset.
Jun 12, 2017 | Casablanca Fan Panama II 50" Ceiling
I have a 16 year old intelitouch fan from Casablanca. I was trying to change the light bulb, but after turning off the power to change the bulb, the power would not return to the fan. I have two wall...
I have a casablanca intellitouch ceiling fan and if you change a bulb while the unit is powered on you ruin the control board. The control boards are expensive but easily replaced by a diy-er. I think I have encountered this problem twice. These fans are very well made and in the past I decided it was worth repairing. However with the new fan technology out there it would be wise to shop around and weigh your options.
Jul 10, 2012 | Casablanca Fan Dryers
When the Casablanca fan remote control wall button is pushed the fan beeps and progresses to the fastest fan speed and stays there. How do I adjust the fan to be able to vary the fan speed so I don't have...
the button may get stuck or the sensor may be off.... also it could be that the setting is backwards on the fan to start on the fastest and end on the slowest
Dec 01, 2010 | Casablanca Fan Dryers
How do you program a casablanca fan remote control to work for the fan?
Howdy,
Casablanca control systems are specific, for instance Inteli-Touch (4 button wall control with power fan light and reverse buttons) uses power line signals to a computer board inside the fan's motor housing and a remote control using RF will not work. However, you do not state what control you have, or what specific control you wish to attempt to use with the fan. Some will work some, will not.
Thanks and Reply so I can better help you!
Sep 14, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Intell-Touch instructions for casablanca fan/light
Light Operation: With the light in the off position press and hold the light button (do not let go). The lights should start at a dim setting and gradually get brighter and brighter. When they get to a setting you desire let go of the light button. To reduce the brightness of the light you must first turn the light off, and then press the light button and hold it in as described above. If the light is off, and you press the light button quickly to turn it on, the light will go back to the previous setting. So if you last had the light on the high setting, it will go back to the high setting, if you had the light at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the light intensity at any time by pressing and holding the light button, but to decrease the light intensity, you must first turn the light off, and start over by pressing and holding in the light button.
Fan Operation: With the fan in the off position, press and hold the fan button (do not let go). The fan should start at a slower speed and get faster and faster. When the fan is at the speed you desire, let go of the fan button. To slow down the fan speed you must first turn the fan speeds off by pressing and releasing the fan button. If the fan speeds are off, and you press the fan button quickly to turn it on, the fan will go back to the previous setting. So if you last had the fan at the highest setting, it will go back to the high setting, if you had the fan at a lower setting it will turn back on to the lower setting. Keep in mind you can increase the fan speed at any time by pressing and holding the fan button, but to decrease the fan speed you must first turn the fan off, and start over by pressing and holding in the fan button.
Jul 20, 2010 | Casablanca Fan (3232A) Ceiling
The Intelitouch wall control operation is intermittent. If the power button is off for a period of time, when powered on the fan doesn't operate properly. I need to push the reverse button, power the unit...
Your control is malfunctioning. If the fan will sometimes operate normally, it is not a problem with the board in the fan. The replacement control is $50~ through Casablanca, but you can find them on ebay for half that cost, or less. Depending on your model of fan you may have the W-32 control, or the W-33. Most likely you have the W-32, but, reply with the model # and I'll let you know which control you have.
Thanks
Nov 15, 2009 | Casablanca Fan Panama II 50" Ceiling
My casablanca fan/light wall switch only works
No . have this checked by a licensed professional it is more than likely bad switchs in the fixture but you can never be to careful with electricity
Aug 23, 2009 | Dryers
Dryers Logo
816 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
