Question about Cisco -Valet Wireless Router
Free downloud cisco yalet router - Cisco -Valet Wireless Router
Tip
Cisco 1841 Router, Hot Sales Product Cisco 1800 Business Router
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
on Jul 07, 2011 | Computers & Internet
Tip
How to Select a Very Right Router for Home or Business
No matter which group you belong to or stay with? If you want to connect outside world through computer, router is an essential element of modern home and business networks. A router lets your computer connect to the Web to read your favorite Web sites, check e-mail, IM friends, or teleconference with colleagues....
When we speak of routers, I usually think of Cisco---a network giant, even though so many others such as Nortel, D-link, Netgear, etc. Because Cisco router is considered as the top choice while choosing a router for home or office, and the more important is that Cisco System offer SOHO, small, medium and large-sized offices or enterprises with different types of routers to meet their different needs.
As we known, the popular Cisco router in the market are Cisco 800 series, Cisco 1800 series, Cisco 1900 series, Cisco 2800, Cisco 2900, Cisco 3800, 3900, 7200 and 7600, etc.(for small to large businesses), also Cisco Linksys-E series for home.
More choice, harder to select the very one for family or for enterprise. But it doesn't matter if you evaluate and weigh the following eight criteria that can help you figure out which router best fits your needs.
Your Usage and Router's Performance For home or for office (small or large size?), first be clear about it. Different demands require different performance of router. For example, choosing a one for family, you may just want to surf on the internet, no need of a router as a heavy-duty gamer or a small business, Cisco Linksys-E series will fit you. Because you know the more expensive the router, the more features it will contain. However, it doesn't necessarily buy a higher performance router. And for business, especially for large or head offices, router's higher performance and safety is vital elements which must be considered while buying. Cisco 1800, 1900, 2800, 2900(for small to medium-sized business or enterprise branch office, Cisco 3800, Cisco 3900, Cisco 7200, Cisco 7600(for medium to large-sized business and enterprise head office), these types can meet companies' various requirements...
Expandability The router usually has a default number of interfaces-but some routers, such as the 3600 series, have none. So, pay attention to the number of interfaces you can add on top of the default.
Router's Integrated Services This refers to functionality supported by a router that previously required separate boxes. For example, a 16- or 32-port switching module in a router negates the need for an Ethernet switch; having a firewall, VPN server, and IDS/IPS sensor in a router can negate the need for a firewall, VPN concentrator, and dedicated IDS/IPS appliance.
Support and Reliability Cisco routers are traditionally reliable, and Cisco is always offering a high level of support. When purchasing a router, you will have various levels of support options. Select the best level for your organization. Of course, using these features in your decision-making process requires some research. You could peruse the Cisco Routers Product Portfolio, scan through the specifications, and select the router yourself. Or, you could also use the criteria above to work with are seller or directly with Cisco to determine which routers offer the features you need.
Warranties Router manufacturers always provide a warranty package together with their equipment. The length and terms of these warranties vary widely. A better warranty may indicate a manufacturer more committed to support their products, while a lesser warranty could indicate a somewhat lesser standard of product quality or reliability. Always consider router warranties when making your purchase decision.
Router's Cost Router manufacturers or router suppliers (like Cisco router supplier) sometimes offer rebates or other discounts from the full retail price of their routers. So you can buy a suitable router at a very great price while router is at a big discount. (Routerswitch.com, hardware.com, often have big discount for hot routers, like Cisco 1800, Cisco 1900, Cisco 2800, Cisco 2900, etc.
Actually, besides considering router's basic function, performance, quality and style, you must notice router's price. So you'd better make a comparison among different routers in order to choose a highly efficient and cost-effective one.
More you need pay attention to while buying a router...
on Jun 15, 2011 | Computers & Internet
Cisco 1941 VS 1841 router? features or advantages comparison
The 1941 is a superior product. However, it will come with a superior price tag. You will want to take a look at your business needs and the feature sets you require/desire before making the decision. Here are links to Cisco's data sheets for both products:
http://www.cisco.com/en/US/prod/collateral/routers/ps5853/product_data_sheet0900aecd8016a59b.html
http://www.cisco.com/en/US/prod/collateral/routers/ps10538/data_sheet_c78_556319.html
Feel free to post your business needs if you still need guidance.
Best Wishes.
Aug 21, 2013 | Cisco 1941 Router
Cisco 861 behind Wimax Router from ISP
> WAN IP: 44.55.66.777
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
Tip
Popular Cisco 1900 Series Routers Including Cisco 1941/K9, Sepcial for Mother's...
Cisco 1900 router series including CISCO1941/K9, C1941-SEC-SRE/K9, CISCO1941-SEC/K9, CISCO1941W-A/K9, CISCO1941W-E/K9, etc. are designed for small office and small enterprise branch offices, delivering high-performance, highly secure connectivity with multiservice integration that can transform the workplace with a broad set of services, rich-media support, and operational excellence.
Key features of Cisco 1900 series in detials:High Perfomance: Cisco 1900 series routers offer significant performance improvements over previous-generation ISRs such as 1800 series.
Investment Protection: Cisco router 1900 Series reduces deployment costs and increases flexibility. The platform also offers investment protection with support for a majority of existing WICs and HWICs.
Services On-Demand: The Cisco 1900 Series Integrated Services Routers reduce total cost of ownership by decoupling the delivery of software from hardware on optional service modules. In addition, you receive a Universal IOS image capable of enabling all of Cisco's rich IOS features and allowing you to quickly deploy new services.
Energy Efficiency: The Cisco 1900 Series architecture incorporates higher-efficiency power supplies with intelligent power management.
Specifiction of Cisco Router 1900 series:* Embedded hardware-accelerated VPN encryption.* Secure collaborative communications with Group Encrypted Transport VPN, Dynamic Multipoint VPN, or Enhanced Easy VPN.* Integrated threat control using Cisco IOS Firewall, Cisco IOS Zone-Based Firewall, Cisco IOS IPS, and Cisco IOS Content Filtering.* Identity management that uses authentication, authorization, and accounting (AAA), and public key infrastructure.* 2 Integrated 10/100/1000 Ethernet ports.* 2 enhanced High-Speed WAN Interface Card slots that can host 2 single wide or 1 double wide and 1 single wide (e)HWIC.* Fully integrated power distribution to modules supporting 802.3af Power over Ethernet (PoE) and Cisco Enhanced PoE.
Overall, Cisco 1900 Series Routers offer unparalleled total cost of ownership savings and network agility through the intelligent integration of security, wireless, and application services.
After knowing more information about Cisco router 1900 series, it's nice choice for you to select one of Cisco 1900 series that meet yor need in net to net.Why not choose? More tips about Cisco products and other Cisco network equipments you can visit here: http://www.router-switch.com/Price-cisco-routers-cisco-router-1900-series_c16
on May 05, 2011 | Computers & Internet
How to block web access to facebook on cisco 2911 router
For most cisco routers there may be an option under "access restrictions" in routers interface called "Website blocking by URL address"
To access the routers administrative interface, open up a web browser and type in the address 192.168.1.1 (by default unless previously modified) Cisco Router Price Buy Cisco Routers 3Anetwork com
Nov 04, 2011 | Cisco 2911 Router
What are some wifi passwords
The default passwords for cisco models can be found here: http://hubpages.com/hub/CISCO-Router-Password-Default-Password-for-CISCO-Router
Nov 28, 2010 | Cisco (WS-X3011) Router
Cisco -Valet Wireless Router Logo
22 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Gareth Tomlinson
Gareth Tomlinson
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
