Question about LG KU990 Viewty
Problem in bluetooth hardware
Cant use my bluetooth
I cant install my bluetooth in msi u100
Not all MSI Winds were sold with bluetooth. If bluetooth doesn't switch via fn + f11 then the hardware isn't present even if the software is installed.
Oct 28, 2010 | MSI Wind U100 Netbook
I deleted bluetooth on my laptop now i want it back but i cant find it lol please help thanks....
Go to device manager and click on scan for New Hardware. This will come up with the bluetooth hardware.
Aug 03, 2010 | Computers & Internet
Cant work bluetooth
The first thing that I would advise you to do is,
Uninstall the bluetooth Adapter totally from the System first,
(For WIndows XP)
Right-Click on my computer Icon, Properties-->Hardware-->Device Manager,
select the bluetooth Adapter under network adapters, and right click on it, then select uninstall
Next, Click on Action on that Same page, and select "scan for hardware changes",
This will bring up a prompt to install the new hardware found (Which is your bluetooth Adapter).
(For WIndows Vista)
Right-Click on my computer Icon, go to
Properties-->>Device Manager, select the bluetooth Adapter under network adapters, and right click on it, then select uninstall
This will also bring up a prompt to install the new hardware found (Which is your bluetooth Adapter).
After this, Press your bluetooth button on the system and ensure that it is On, then Scan for bluetooth devices.
It should connect like that.
Try this out and kindly let me know how it goes,
Hope this helps.
Thank you for using Fixya.
Goodluck
Jul 28, 2010 | HP Pavilion Tablet Notebook
I cant find bluetooth on my IBM R52 laptop i have tried above solution but bluetooth is not shown on wireless radio
there is a configuration part in BIOS for bluetooth and an icon under the display. Is it possible that the laptop has not a bluetooth hardware.
Oct 25, 2009 | IBM ThinkPad R52 Notebook
I have Aspire 4730Z acer laptop. but can't install blue tooth. when going to install driver from utility CD showing no device found. let me clear how can I resolve the problem i am trying to bluetooth...
The 4730Z does not have bluetooth onboard. The bluetooth button is there because the 4930,model shares the case and some hardware with your 4730Z. hardware with the 4930 which does have bluetooth. You will need to add an internal bluetooth device or USB bluetooth dongle if you want bluetooth.
Apr 27, 2009 | Acer Aspire 4720 Notebook
BLUETOOTH DRIVER
If you are using the Preinstalled version of Windows using the Recovery Disks or Recovery partition, you should be having the Bluetooth drivers.
However, you can download the drivers for the Bluetooth Hardware in your Notebook from the links provided below for Vista and XP :
Bluetooth hardware drivers for XP :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34264.exe
Bluetooth hardware drivers for Vista :
ftp://ftp.hp.com/pub/softpaq/sp34001-34500/sp34275.exe
Note : If the Notebook is not having a Bluetooth hardware and by installing the Drivers, you may find a Bluetooth icon in the Taskbar and this doesnot mean that you have Bluetooth hardware in the Notebook
Oct 16, 2008 | HP Compaq Presario v3000z Notebook
Bluetooth wont stay connected
probably a hardware issue on the phone itself...
i would call up lg support first ask them why is this...
bluetooth does have a 10m range and connecting a bluetooth headset shouldnt be as far as 10m
Aug 21, 2008 | LG Shine CU720 Cellular Phone
I have a problem to use my bluetooth on my laptop
First of all, check whether your Notebook is having Bluetooth devices or not since the Remote Controller you are using works based in Infrared like the Remote Controll like the remote controller in Televisions.
To check whether your Notebook is having a Bluetooth hardware or not, go to Device Manager by following the steps below :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Check if there are any entries with Bluetooth in the the Device Manager.
If you find any entries with such name, click on the [+] mark next to it to expand the tree.
If you find any entries called Bluetooth emulator, it is just the software you had installed and not the Bluetooth Hardware which you can use to transfer data.
If the Bluetooth hardware is installed in your Notebook, there should be HP Integrated module with Bluetooth.
However, to use Bluetooth, the Wireless button should be turned on.
Just follow this steps and make sure that your Notebook is installed with a Bluetooth Hardware and get back to us if the Notebook is having Bluetooth hardware and unable to use it.
Aug 20, 2008 | HP Pavilion dv4000 Notebook
Problems
Now iam using nokia 6600 ,not played mp3 ringtone
Sep 12, 2007 | Nokia 6600
LG KU990 Viewty Logo
18 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
