Question about Canon imageRUNNER C5180 Color Copier
Canon irc 5185i with error code E000007-0001 copier office equipment
E000007-0001
checkitright
  • 1362 Answers
SOURCE: canon ir6000 error codes E000061-0001..
E061 Specific potential is not required or the limiter is activated as the potential is controlled.
I beleive it is the Potential of the "drum sensor"
there is a sensor that reads the drum and adjust the machine, this may need to be adjusted, cleaned or replaced. Has to be done by a tech.
Posted on Aug 25, 2008
  • 24 Answers
SOURCE: canon copier 3300i error code E000007-0000
Change the fixing film! It is broken!
Posted on Nov 16, 2008
  • 37 Answers
SOURCE: CANNON IRC -2880
this code is for a bad OHP sensor, wich detects transprerencies.
Posted on Aug 26, 2009
randula7
  • 78 Answers
SOURCE: my copier canon IR6000 shows error code E000061-0001. plaese help
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} E061
Main Cause The laser shutter is faulty. The laser unit is faulty. The potential measurement
PCB is faulty. The DC controller PCB is faulty.
Mode of
Detection
0001 As the result of potential control, the drum surface potential (VL2)
of the white background is about 200 V (generating solid black images).
0002 The primary charging output used for print output and the drum
surface potential after laser output has been made are about 200 V
Posted on Sep 08, 2009
  • 7 Answers
SOURCE: When I start the copier canon c 31000 I get error e000070-0001
is it canon irc 3200 color copier
Posted on Mar 11, 2010
My canon irc 5185i prints faded at the right side, how can I fix it
hi . good day there are so many things that could make that problem. one of them is dirty laser mirrors. or faulty drum units. and or faulty transfer belt. I recommend you search for technical assistance
Jan 04, 2016 | Canon Office Equipment & Supplies
Error 000004-0401 on irc 5185i
you may have to uninstall your printer then reinstall it to see if that takes care of the problem
Jun 09, 2014 | Canon Office Equipment & Supplies
Canon iRC 5185i with the erro code E000007-0201 . i need solution
Belt push-off temporary escape mode error.
Occurs when the belt deviation is not eliminated within 1 minute in the belt push-off temporary escape mode.
Oct 25, 2013 | Canon iRC 5185i
E00004-0502
Pressure main thermistor or pressure sub-thermistor 1 or 2 connection error Check the connections of the pressure belt unit connectors. Replace the pressure belt unit.
Or replace the fixing unit.
Sep 12, 2013 | Canon iRC 5185i
IRC 3380i error code E000001-0003 please help
get into service mode
To get into service mode.....
Press *
Then 2 & 8 together
Then *
then choose COPIER
then choose FUNCTION
then choose CLEAR
then choose ERROR
then press OK
turn power off and on
Sep 03, 2013 | Canon C3380i Color Copier
Canon error 5185 E751-1413
Memory error on Cyan toner cartridge/drum unit.
Check the memory chip connecrions.
Oct 17, 2012 | Canon iRC 5185i
Canon irc 3080i error code e000020-0023
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
Mar 28, 2012 | Office Equipment & Supplies
Canon IRC 2570 IC Error Code is E000012-0002 problem what is the solution
May 22, 2011 | Office Equipment & Supplies
CANNON IRC -2880
Aug 19, 2009 | Canon IMAGERUNNER 2230 Copier
Canon imageRUNNER C5180 Color Copier Logo
128 people viewed this question
old marine
old marine
