Question about Canon Office Equipment & Supplies
CANON COPIER C2020L ERROR CODE 360
After coping 1st. paper and trying to copy the 2nd an error 020000 360 , appear in the touch pad , what should I do to fix it . Thanks.
  • 883 Answers
SOURCE: how do i get rid of e000 system error?
is the fuser unit getting hot as it should be?
Posted on Jun 06, 2007
checkitright
  • 1362 Answers
SOURCE: canon imagerunner 7130 b/w copier
Is it copying the size of a Letter paper?
If yes it's not set to Legal, go in the menu and set to Legal.
Posted on Oct 26, 2007
  • 6 Answers
SOURCE: COPIER GIVES THIS ERROR E0000-840-0001
this err belongs to sensor problem.
chech thermostat sensor
Posted on Dec 01, 2008
  • 117 Answers
SOURCE: Canon copier show error code:E100
E100 means the copier is not warming up.Make sure all the wires to the fuser are properly connected, then open and close the front door.you may have to go into the service mode to reset the error code.Good Luck
Posted on Mar 26, 2009
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
Posted on May 19, 2009
E000022-000 ERROR CODE IN C2020L
its an error code from ATR sensor / abnormal detected patch reading vaue to reset it clean the toner hopper sensor and enter the service mode>clear>eng>trans>ok then turn OFF and ON
Jan 16, 2015 | Canon Office Equipment & Supplies
Kindly give me the solution for canon C2020L error code E000002-0006
Detection of abnormal temperature increase in the fixing assembly.
Most of the time just change the fixing assembly. part # FM4-6227-000
Dec 20, 2013 | Canon for IMAGERUNNER C2020 C2050 C2058...
Error code e000007 canon 2420
MY CANON IR 2420 WITH ERROR 000007-0000 HOW CAN ISOLVE THIS PROBLEM
Dec 06, 2012 | Canon Office Equipment & Supplies
I have the copier machine Sharp AR-5127, the error code H4-00 appears and coping cannot be done what do i do
The heating element or the thermal fuse in the fuser unit has failed. Try pressing clear,interupt, 0, interupt, 1,4, the blue copy button to reset it.
May 23, 2012 | Office Equipment & Supplies
Canon IR2000 feeder noise
uhm i know that the reset function helps when on the control pannel display is displayed with the error code E000, but what was said from the noise the copier makes when it copies, i would say that the pick up paper assembly, will stop working, if u have other trays in your copier, try coping from there and see if it makes the same noise, if not..then probably, u have to replace that part soon " pick up paper assembly" am not an expert, but i also have one, and some things i've seen with it:)
Mar 06, 2012 | Canon imageRUNNER 2200
I have Canon IR 400 photocopier. My problem is -
This not really a problem. Canon Copiers have various counters that track the counts of Various sized papers. Long, short and the like. The only counter that really matters in the 101 or total counter. This the counter that tracks every piece of paper that goes through the copier. This is the counter used to track copy usage. If you have a service contract this the counter the dealership will use to track copies for billing. Ignore anything but the total counter.
Mar 22, 2010 | Canon imageRUNNER 400S Copier
Error 6A00 appears. Will not print. Cannot find
Try it maybe
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Jan 08, 2010 | Canon PIXMA MP610 InkJet Printer
Canon imagerunner 7130 b/w copier
Oct 20, 2007 | Canon NP 7130 Black and White Copier
97 people viewed this question
old marine
old marine
