Question about Ovens
Replace Simpson hotplate
I need to replace two of the hotplate coils. How do i remove the coils and replace them?
How do I remove my Simpson Jupiter oven door
tip open part way and lift it off the hinges .
Oct 24, 2015 | Ovens
I have a 'Simpson 2001 Thermaflow Oven' and a few months ago, i was heating it up, and i heard a pop, from then on my oven has not heated up, i cannot seem to find what is wrong with it!! Please...
I would say that the oven element has blown. It is common especially if you have a fan forced model. Make sure the fan works before you go buying a new element as the replacement will fail early. Simpson ovens have to be removed from the wall cavity to replace the fan and the element. Make sure you tuen the power off before doing anything...
Give the parts supplier your model number so that you get the fight element ( and fan) if necessary.
Jul 31, 2011 | Ovens
Our Simpson Esprit hob has terrible heat control. We are burning everything, even on low because the temp is too hot, but then when we try and boil pasta on a high heat we cant seem to get it even to...
I am assuming the cooktop is electric. Are the hotplates the solid type, coil type or beneath the glass. Are these new to you or have you been cooking with these for a long time?
Mar 06, 2011 | Ovens
Yes i have a westinghouse ppl776 ceramic cooktop and can not regulate temperature on any control knobs ,plates run flatout, is the problem with the control knobs or hotplates
When this occurs the problem is always with the hotplate controllers. Has this happened to all hotplates at the same time or has it occurred over a certain time period?
When i turn on one of the hotplates it trips the electric out how do i fix it
Remove that hotplate. Reset the breaker and see what happens,
Other hot plates do the same?
Jan 28, 2011 | Ovens
Cant remove glass cover to replace bulb on Simpson La Stella Atlas series oven
I have a Simpson Atlas Mira. Was having a hard time getting the glass cover off too so looked on the net for a solution. Couldn't find one so I persevered and sorted it...
The glass cover has a screw-off thread (like a glass jar) which unscrews anti-clockwise (lefty loosey). I had to give it a good few wiggles and pulls before it would start unscrewing. I also had to use a damp towel to get a proper grip - it's a slippery little bugger - but I got it in the end!
Hope this helps someone - good luck!
JD Hamilton, NZ
Aug 23, 2010 | Ovens
Simpson Evolution 906 Oven light. how to replace it?
I have just replaced mine & had the same problem. I couldnt remove the cover. I found that I just couldnt grip the cover well enough. I got some rubber washing up gloves & used them to grip the cover. It was still tight but it un skrewd quite easy this way.
Jun 28, 2010 | Ovens
Oven door removal and installation please. Simpson Neptune
open oven door to first 'notch' pull door straight up off of hinge levers.maintain alignment of hinges to aid in replacement.
if they 'snap' back to closed position,pull them out equally to replace door
Oct 17, 2009 | Ovens
The hot plate is heating up when the selector is in off position
Hotplate heating up when regulator/selector switched off. Hi ,this is gil1714 in Scotland. Two possibilities on this one, 1) the regulator is faulty:- replace
2) if the control circuit (regulator) is wired on the neutral side the hotplate may be leaking current to
earth, thereby completing the circuit. This would only occur on a supply that was not protected by
an RCD. If so replace hotplate. Hope this is useful,
Dec 15, 2008 | Ovens
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
