Question about Pioneer VSX-D506S Receiver
VSX-D498 power-off, How can i fix it by myself...
When i try to turn on reciever a "poweroff" lights up all my other equipment is connected to reciever and powered up but the reciever just lights up poweroff and when i don't have my other equipment conected then shuts down to stand bye mode.
2 Suggested Answers
  • 93 Answers
SOURCE: vsx-d506s problem
It may be a PROTECT MODE. Check is your other equipment properly connected to receiver.
Posted on Oct 11, 2007
Optical inputs
You have to re route the sound from the samsung to the optical output. You do this is the audio setup section of the setup menu.
Jan 23, 2014 | Pioneer VSX-D498 Receiver
I have a vsx-305 and it flashes POWEROFF. What is happening?
It's thrashing.
Generally speaking, an amp protects itself from heat, shorts and overloads by refusing to turn on or stay on.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Check for loose speaker connections as a root cause for intermittent shutdown.
Feb 14, 2011 | Pioneer VSX-D498 Receiver
MY PIONEER VSX-D498 DIGITAL SIGNAL PROCESSOR BECAME HOT AND BLEW. HOW DO I FIX IT?
As with anything, diagnosis comes before repair. It needs a hands-on pro to look at it.
Feb 03, 2010 | Pioneer VSX-D498 Receiver
VSX-D308
Maybe the audio amplifier IC is damaged and you gotta change it.Good luck.
May 26, 2008 | Pioneer VSX-D308 Receiver
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Vsx-d506s problem
Oct 09, 2007 | Pioneer VSX-D506S Receiver
Pioneer VSX-D498
Sounds like the on board computer (micro-processor) is waiting for a process to happen and when it does not happen then the unit times out and shuts off. Could be a mechanical or electrical process. Good luck.
Mar 23, 2007 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
Perhaps the unit isn't switched to 5.1 Maybe the movie wasn't recorded in 5.1 or if it was perhaps the recording was faulty. Try a known good recording to check the system. Check your outputs and inputs plus your speaker cables. Check the fuse if there's a seperate one for left and right, which there should be. Try swapping the front speakers to the rear and the rear to the front and see if the fault is still with the rear sound. BMW
May 15, 2006 | Pioneer VSX-D498 Receiver
Pioneer VSX-D498
silly Question John?? Have you or anybody changed modes on the reciver??? Not so silly as i've seem even a power do that. if not in the system then try unplugging for 24 hours and starting over again . let us know as maybe we can come up with more as we get more info. Good Luck
60 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
