Question about Linksys RangePlus WRT100 Wireless Router
I can not reach control panel. the password and ID don't work and I have held the red button on back twice for more than 30 sec. to set to default factory settings but still asks for p/w when I enter "admin" for id. ?
I have the router connected at my desktop. I am working now from my laptop wireless, but it is connected as "unsecured." I also turned off power and rebooted - I can't find the CD.
  • 35 Answers
Connect to the router using a wired connection and use a blank username and "admin" as a password not username.
Posted on Oct 27, 2008
How to reset a forgotten admin password on a Xeroc DC252
DocuColor 242 252 260 Online Support Solution Modify the Administrator...
Solution : Modify the Administrator Password From the Control Panel
  1. Press the small round [Log In / Out] button located on the left side of the Control Panel. The System Administrator Login screen will be displayed.
  2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
    NOTE:The System Administrator Login ID and UserID is "11111" by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
  3. Select the [System Settings] button twice. The System Settings screen will be displayed.
  4. Select the [Change System Admin Login ID] button.
  5. Enter in the new password.
  6. Select the [Save] button to save the setting.
  7. Select the [Close] button several times, and then select the [Exit] button to exit.
Apr 03, 2014 | Xerox Office Equipment & Supplies
I have GE JVM1540DN1BB microwawe. It beeps all the time and says "keypad sorted" and service needed. The beep sound is annoying and it beeps every 30 seconds
see this causes and fix it. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | GE Microwave Ovens
How to take off control panel
Are you trying to reach the control board behind the panel or replace the entire control panel with buttons?
Sep 22, 2012 | Frigidaire ATF6000ES Front Load Washer
My tv starts changing channels in the middle of us watching tv how do i fix this?
stop spraying 'windex" on your display! It drips down or goes to the side, where your "control buttons" located. Won't take a long for ammonia to penetrate "tact' switches and cause them to engage without physically pushing them. next: you TV will start to do the same way to 'on/off"! If you can disassemble tv, just carefully locate control panel and remove it from TV's plastic frame. You may need to use caution! Usually, couple screws must be removed to reach that thin board. Watch for plug! If wires are long enough, you may remove the panel. If not, don't take a chance: reach to switches with WD40 thin straw dispenser and apply a little bit of that to every switch. It might smell like WD for a little while, but problem is solved! Don't forget to push every button 10 times after applying WD! for a 'deep ***********"!
Nov 08, 2011 | Samsung Televison & Video
I'm trying to program my ''Comcast'' cable box remote control to operate my byd:sign model d:5032M plasma TV. Comcast does not have a standard 4 digit TV code to use. How can I get the code as there is no...
If your brand of TV does not respond to the remote control after trying all of the codes listed, or if your brand is not listed at all, try searching for your code.
1. Turn on your TV.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Enter in 9 - 9 - 1. The Red Light will blink twice.
4. While pointing the remote control at the TV and press and release the CH + key until the TV turns off. (Note: You may need to press [CH+] numerous times).
NOTE: In the search mode, the remote control will send IR codes from its library to the TV.
5. Press SETonce to lock in the code. The Red Light will blink twice.
Sep 19, 2009 | byD sign d:5032 50 in. HD-Ready Plasma...
How i check to see if my router is faulty
Check to see if you can access the router's control panel. To reach the control panel make sure you are DIRECTLY connected to the router with a CAT5 (Ethernet) cable.
Now go to Start>Programs>Accessories>Command Prompt. In here type: ipconfig
Press Enter. The command should return results similar to these:
IP Address: . . . .
Subnet Mask: . . .
Default Gateway: .
What you want is the IP Address associated with the, "Default Gateway." Now open your Internet Browser (Internet Explorer, Firefox, etc...) and type that same IP Address into the address field. DO NOT add www. or .com. Now press ENTER (Or GO) as if you want to visit a website. This should take you to the router's control panel. Once here you will probably have to log in, if you don't know the username and password try the default:
User ID:
Password: admin
If that doesn't work you'll have to call Linksys for assistance in reseting the login User ID and Password. Once you manage to log in try some of the links. If no errors are returned (Page not Found, etc...) your router should be functional and is not the source of your troubles.
Jan 28, 2009 | Linksys Wireless-G WRT54G Router
Dvd parental controls
With a DVD disc inserted in your PS2, press the Select button to bring up the on-screen Control Panel. Press the X button to select the Setup icon. Use the directional pad to reach the "Custom Setup" menu, and press the X button. Move to "Parental Control" and select with the X button. A window will appear asking you to enter a four-digit password. Enter your choice of password using the number buttons that appear then enter it again for confirmation. You're now able to set the Parental Control level using the "Region" and "Level" options, and change your password
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Linksys RangePlus WRT100 Wireless Router Logo
56 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
