Question about Olympus DS-330 Digital Voice Recorder
Not able to install DS-330 driver in Windows 7 (32\64 bit) OS
When is connect DS-330 device its shows the message as installing drivers but after some time, it will fail. Even if i install related player pro 2002 or version 7, same is the case. Player pro also not able to detect the device. Please help me regarding this.
5 Suggested Answers
crystal515
  • 3 Answers
SOURCE: Need drivers for Olympus VN-960pc; os Windows XP home
Vista compatible software can be downloaded here:
http://downloads.olympus-europa.com/consumer/VoiceRecorder/720/eng_2000_xp.zip
After installing the software you need to install following updates
http://www.olympusamerica.com/files/DWPUP4EN.zip
http://www.olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
The software will work with the 32 bit edition of win Vista, not with the 64 bit edition.
Posted on Aug 07, 2008
  • 479 Answers
SOURCE: Olympus vn-2100pc driver not installing
go through device manager and update driver
Posted on Aug 20, 2008
dequeue
SOURCE: device not detected by olympus digital wave player on win xp plat
What I did was follow the advise from this page -> https://www.fixya.com/secure/support/t1684682-file_transfer_vn_480pc_doesnt_work
Solution:
Go to Control Panel and press Add Hardware. Search for new hardware and allow windows to go on the net to search for the drivers. It will find and install drivers. After that functionality in the Digital Wave Player will become active and you can transfer your files onto pc.
Posted on Sep 09, 2009
  • 1218 Answers
SOURCE: Is there a patch available to allow the DS-330 to
Any software upgrades will be at www.olympusamerica.com .
Posted on Sep 07, 2010
Instalador de class pad 330 para 64 bits
You do not need any driver for the ClassPad 330. You connect it through the USB port. If it came with the ClassPad manager 32 bits application, just install it. Windows 64 bits system have a 32 bits subsystem to run 32 bit applications.
Google translate (without accents)
Usted no necesita ningun controlador driver para la ClassPad 330. Se conecta a traves del puerto USB. Si viene con el gestor de aplicaciones de 32 bits ClassPad, solo lo instale. Sistema Windows de 64 bits tienen un subsistema de 32 bits para ejecutar aplicaciones de 32 bits.
Mar 03, 2014 | Casio ClassPad 300 Calculator
Could not find audio drivers for windows xp 64 bit
you should be able to install the 32bit driver normally.
go to device manager and click on update driver once their point towards your 32bit driver
Jan 17, 2014 | IBM ThinkCentre Computers & Internet
I downloaded printer driver for brother mfc240c, but even after install, I get a message that says the driver isn't installed.
Open the printer and scanners folder an delete all the devices (Brother Printer, Brother Fax, Brother PC-Fax if installed). Point to device an right click the mouse button.
Restart the computer.
Download the software from Brother Solutions Center. Download the whole suite not just the drivers. Make sure you select the software that is compatible with your version of the OS :Windows 7 32 bits, Windows 7 64 bits, Windows 8 32 bits, etc.
Install the software. If you are going to use a USB cable to connect the MFC to the computer, install a local USB printer. If you are going to use Ethernet network cable, install a wired network printer, and if wireless connection then install a wireless printer.
If you have problems finding or attributing an IP address to your printer (for Non-USB connections) there is Brother program that helps you attribute an IP address. You will find it on the same page as the software suite on Brother's site.
Nov 07, 2013 | Brother Multi-Function Center MFC-240C...
System error found
Hope this will help someone else:
InWindows' Device Manager (devmgmt.msc), the SXUPTP driver was showing as disabled.Windows gave a warning that the device was known to have stability issues. Ifound out that SXUPTP is a driver from a company called Silex. Silex makesnetwork USB hubs, so I assume that the Belkin hub is a rebranded Silex hub.
In order to update the Silex driver follow these steps:
1. Close the Belkin network hub's tray application.
2. Download the latest version of SX Virtual Link(sx-virtual_link_win_3120.zip).
3. Extract all of the files.
4. In Windows Explorer, navigate to sx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVistaX64if you are running a 64 bit OS, orsx-virtual_link_win_3120\s-33a3120\Files\Bin\Sxcsapi\WinVista if you arerunning a 32 bit OS.
5. Right-click on "Sxuptp.inf" and select "Install" fromthe menu.
The driver will be installed and the warning icon in the device manager shoulddisappear. You may need to reboot for the changes to take effect.
Nov 03, 2013 | Belkin Computers & Internet
How do I get Olympus DS-4000 to work on Win 8 64-bit
do you have programs files (86) in your PC "C" drive menu menu? If yes that;s where yiou should install the software. That's because it;'s a 32 bit on a 64 bit.
Oct 17, 2013 | Olympus DS-4000 Digital Voice Recorder
I reloaded Windows Ultimate 64 bit.I had Windows Ultimate 32 bit. I did a complete re-installation of Windows and now my installation disc of my motherboard shows Error Code;2(2H) cannot find specified...
is the motherboard 64 bit compatible? usually a 32bit system will not accept a 64bit OS. missign a motherboard driver it sounds like..check your control panel device drivers for errors
Feb 18, 2011 | Computers & Internet
Will the DS-330 software work with Windows 7?
Download your driver from here driverupdate us . Download the software (for free), scan for the required driver and update, It will take 2 mins. Hope this was helpful. cheers
May 10, 2010 | Olympus DS-330 Digital Voice Recorder
How to connect motorola w388 model to pc to access internet
Motorola Mobile Phone USB Drivers (for Windows®) This USB Driver is used for connecting your Motorola Mobile Phone to a Windows® computer via a USB cable in order to charge your phone or to access the data on your phone.
Supported Handsets This USB Driver supports most Motorola OS, Motorola Linux OS, Motorola iDEN, Motorola Symbian/UIQ, Motorola Windows Mobile® and Motorola i-mode Handsets.
System Requirements
  • A 32-bit or 64-bit version of Windows 2000®, Windows XP®, or Windows Vista® Operating system.
  • You must have Administrator permission to install this driver.
Notes
  • Please reboot the system after installing the USB Driver.
  • Installation of Motorola Phone Tools may affect the performance of this driver. Please re-install the USB Driver after the installation of Motorola Phone Tools.
* MotoConnect is a PC application that keeps your Motorola device drivers up-to-date. Additionally, on supported phones, MotoConnect can launch the owner support page for your phone giving you easy access to user guides, FAQs, tutorials, videos and more.
PC Charging Drivers These drivers allow you to charge your phone using your PC and a USB cable.
Feb 05, 2010 | Cell Phones
MY IBM COMPUTER SHOWS A WINDOW SAYING IT DOES NOT RECOGNIZE THE HARDWARE, WHEN AN ATTEMPT IS MADE TO DOWNLOAD PHOTOS FROM MY MOTOROLA CELL PHONE.WITH USB CONNECTION.
System Requirements
Notes
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 03, 2010 | Motorola Cell Phones
Install macally icekey keyboard to windows?
It is only for Mac, there are drivers available from the site, all OS and OSX.
Driver - Macally Peripherals
www.macally.com/driver
Keyboard & Mouse · Bluetooth & Wireless · Webcam · Hub & Adapters ... usb. IceCam. IceCam Driver for OS X 10.4 to 10.5 ( updated on 2/16/2008); IceCam ... ICEKey installer for PowerPC and Intel-based Mac OS 10.4 to 10.6(32-bit system only) ... USB 3.0 to Gigabit Ethernet driver for Windows XP/Vista/7/8 (9/10/2013).
Amazon.com: Customer Reviews: Macally USB Slim Keyboard - ICEKEY
https://www.amazon.com/Macally-USB-Slim-Keyboard-ICEKEY/.../B00006HYP6 ... and review ratings for Macally USB Slim Keyboard - ICEKEY at Amazon.com. ... F9 for me shows application windows, F10 isolates the window and F11 ... Macally USB Slim Keyboard ICEKEY Google Search
Mar 13, 2017 | Macally iceKEY Keyboard
Olympus DS-330 Digital Voice Recorder Logo
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
