Question about DeLonghi (284748) Kitchen Hood
Delonghi beta 900 inox extractor unit. can the motor and fan assemble be moved to a remote position within the roof space; it makes a hell of a noise when operating within the metal cowl in the kitch
Approx 3 years old, works fine at removing odour but is so noisy in operation, both mechanically and air noise
2 Suggested Answers
  • 199 Answers
SOURCE: Hi, model Beta 900 Inox. There was a bang and now
it sounds like there is a short in one of the wires going to the fan be carefull not to dig into with power on (breaker) a wire may have come loose and shorted to the housing. look for a black soot mark and fused metal.
Posted on Jun 24, 2009
My bosch extractor fan makes such a noise when the light is on. I sometimes just use the light function of my fan when I'm cooking but it makes such a noise I can bear to keep it on for long. Is there...
check the vent is not restricted. I had had one where the installer accidentally stopped the butterfly flap from opening with a fixing for the flue. Also one where builder squashed the pipe in the roof. Another where there was no pipe from hood, not moving air at all,just a noise maker!
Oct 16, 2013 | Kitchen Ranges
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
Refrigerator making squeeling noise once in a while. Noise is like someone complaining in a Charlie Brown cartoon.
. The next time the noise starts , open the freezer door and see if that is where the noises coming from . If yes , replace the circulation fan located in front of the evaporator assembly . If the noise is coming from the bottom of the unit and you can hear it clearly with the doors closed , more than likely it would be the condenser fan located next to and sometimes even mounted on the condenser assembly . If the unit has a static condenser , which will be indicated by the metal lines running up and down and all around the back of the unit itself , there is no condenser fan . The squealing noise you hear is a bad bearing in one of the motors . As the motor shaft spins , it actually wobbles within the bad bearing as too much clearance between the two exists .
Feb 19, 2011 | GE GSS20IEPWW / GSS20IEPCC Side by Side...
2003 Corolla moonroof won't close
Check fuses and wiring. If all is good, I suggest carrying around towels and plastic wrap... Just kidding. If nothing works, take it to O'Reilly and have the computer checked. It could just be a burned motor, which is an entirely different story.
Mar 18, 2010 | 2003 Toyota Corolla
Jun 24, 2009 | DeLonghi (284748) Kitchen Hood
05' lincoln navigator sunroof won't open and motor makes noise but nothing happens?
The motor is stripped out. The sun roof might be binding on the sun roof track and the motor is not strong enough to move the roof. I would first replace the sun roof motor if available seperately.
You mihgt have to get the complete assembly because of part availability
Mar 19, 2009 | Lincoln Navigator L Cars & Trucks
Every winter water drips from my bathroom ceiling mounted extractor fan, worse when there is bad condensation. The vent goes straight up and up through the loft space and out of the roof, there appears to...
condensation is created by 2 exteme temperature change.
looks like the loft space is colder than the rest of the house.
first make sure there is not blockage in the vent. then warp the vent with fiberglass as much as you can. it doesn't matter what R value the fiberglass is. just enough to cut the temperture change.
you still going to need a exhust fan in the bathroom.
Oct 31, 2008 | Hampton Bay 24002 Ceiling Fan
I own an LG up right refrigerator with the freezer on the bottom. The unit is about three years old and we have been very happy with the frig. Lately the unit has been making a loud fan winding noise....
  • i would just replace the fan motor $40
  • they have bushings in them that sometimes make noise when the motor shaft moves to a certain position. when you open the door it disrupts the airflow of the refrigerator and the motor shaft will go to a different position causing the noise to stop.
Jul 10, 2008 | LG Refrigerators
Hampton Bay Ceiling Fan - Clarington 503837 52"
It slides in above right above the ball, in the mounting bracket where the canopy is. You may have to kind of encourage it to go in there, and you will need to push wiring off to the sides and out of the way to help it have clearance to get in there.
Mar 10, 2008 | Hampton Bay AC414-LRU 52'' Kemper...
DeLonghi (284748) Kitchen Hood Logo
79 people viewed this question
Top DeLonghi Kitchen Ranges Experts
JP Services
JP Services
Vitaliy Gins
Vitaliy Gins
Paul Bade
Are you a DeLonghi Kitchen Range Expert? Answer questions, earn points and help others
