Question about IBM Infoprint 6500 Matrix Printer
Error 102: lower driver short?
What actually happen to my printer? anyone can answer?
C9050 code
Kyocera code c9050 Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > code c9050 > Printers & Copiers
Kyocera printers & copiers code c9050 related questions and answers. ... error code C-6 for kyocera km 1500 blingking code C-6 in my kyocera km 1500 c6-400
Oct 15, 2015 | Cars & Trucks
Lower driver short
Bad CMX PCB, you will need to flash it after replacing it.
This is the part you would need
MRP provides IT Parts Product Supplies and Services
Jan 23, 2014 | IBM 6400 Matrix Printer
Siemens SpeedStream 4200 Error 102 Modem is hooked up and installed. All lights are on. Tried disconnecting for 15 seconds and reconnecting. Has been working previously. No noticeable changes since...
Hi
If you are using the google chrome browser, there are a number of issues that would cause that error.
I would try testing with another browser to see if you can connect. ( IE, firefox, opera.)
if you can get to the net with another browser, google has posted this info.
http://www.google.com/support/chrome/bin/answer.py?hl=en&answer=117805
hope this helps
Feb 16, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. keeps coming up oon google chrome im wondering why and how to fix it
This is the help page for Google Chrome which defines the trouble shooting steps for the Error 102 problem: http://www.google.com/support/chrome/bin/answer.py?hl=en&answer=117805
Feb 05, 2010 | Google Chrome
Xerox 3535 error code 102 372
have a xerox 3535 with one blinking light and error code 102 372 on start up any ideas ?
Oct 15, 2009 | Xerox DocuColor 3535 Copier
Getting error, "cartridge error" 50C. Dell All-in-one printer, model A940
Hi there Error 50c
Yes this allways happens.
Regarding the Dell A940 "Error 50c"....the user guide doesn't seem to mention "Error 50c". They do, however, mention a "Cartridge Error" on page 52 of the manual. They claim this means that the printer has detected a short circuit (fuse/resister) in the cartridge. As you may or may not have noticed in the manual, this is what they recommend doing about it:
1) Press Power to turn the printer off.
2) Lift the printer cover/lid (scanner unit) until the scanner support holds it open.
3) Turn the printer on.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
4) Remove the color ink cartridge.
5) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the black cartridge with a new black cartridge.
If the error message does not display, repeat steps 1–3 and then go to step 6.
6) Reinstall the color cartridge and remove the black ink cartridge.
7) Lower the printer (scanner unit) until it is completely closed.
If the error message displays again, replace the color cartridge with a new
color cartridge.
If there is no error message (indicated by flashing lights), repeat steps 1–3 and then reinstall both ink cartridges.
8) Lower the printer (scanner unit) until it is completely closed.
If you get the error message again, while both cartridges are installed, replace both of the cartridges.
Basically, what they want you to determine is,....if the short circuit is with the "black ink" cartridge or the "color ink" cartridge and then replace the cartridge that has the problem.
You may have to buy a new cartrige.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 13, 2009 | Dell A940 All-In-One InkJet Printer
Forms Jam
probably the sensor. The one the paper goes under, lower left front of the machine. Had this loads of times.
Cheers
Aug 15, 2007 | IBM 4230 Model 102 Matrix Printer
IBM Infoprint 6500 Matrix Printer Logo
67 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
