Question about RCA L26W11 26 in. HD-Ready LCD Television
Unusable signal on rca jack inputs
Then i have to turn tv on n off couple of time before screen comes on
The Slash
  • 53 Answers
SOURCE: Unusable Signal
Hello Mike:
The issue that you are having is with your small signal board and it needs to be replaced, it sounds like the microprocessor on that board is getting locked up.
Posted on Aug 19, 2008
  • 23 Answers
SOURCE: I am having a problem with an RCA tv..unusable signal.
make sure that you have it set to the right input signal source and that your source is working properly. if so then yeah, you need to replace the fuzle modulator.
Posted on May 02, 2009
SOURCE: When I turn on my tv, I get a black screen that says unusable signal. I change the channel, same thing. I try to use the DVD player or another add on and it is still black. My TV is an RCA 37in flat s
Thank you ryolkowski!!!! We just tried your solution and MAN it worked like a damn. We were all ready to make a trip to the city to get a new tv, an expense we just didn't need right now. You made our day. I can't thank you enough. jabo
Posted on Aug 02, 2009
  • 8457 Answers
SOURCE: 42 RCA TV flashing unusable signal
Ur backlight video board it dead,must replaced.
Posted on Dec 05, 2009
mpaint
  • 36 Answers
SOURCE: 42 inch rca lcd tv says unusable signal
This is a very common problem with these models.
The problem is very likely a fuse that has blown, if the following is true:
No Video on any input BUT HDMI and
No Audio at all.
Purchase a fuse, these are freaking tiny from digitalkey.com or mouser.com F1455ct-nd
Pull the back off of your unit
Pull the cover off of the PCB housing. It is the box that contains the hook ups including the cable tuner.
The silver box that you screw the cable to is where you begin to look for this fuse.
About two inches behind this silver box is some numbers printed on the board 7c32 and partially obscured will be 1c33
Using a big magnifier look next to the numbers listed above, you should see a tiny rectangle fuse with an F on it.
This F fuse is a 500ma fuse that is too small for the load
The fuse listed above will have a G on it. It is a 750ma fuse.
Call the repair shops in your area, tell them that you know the problem, have the part and you want to know how much the bench time and labor will be to repair your unit.
Posted on Jul 23, 2010
White light coming from bottom area of screen in a couple of palces.
This often happens when the logic board or the screen itself is is about to give in. Some times it can be a build up of static which does happen with these HDTV's, Try the following
  • Plug the TV directly into the wall, no extensions or adapters
  • Turn off the wall socket
  • Press and hold the power button on the TV in for about 30 seconds
  • Turn on the power at the wall back on and check you TV
This is called a static discharge and often will fix issues like this. If you still have this issue you may have to take it to a repairer.
Apr 17, 2014 | Panasonic VIERA TC-L42E30 42-Inch 1080p...
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
Rca model j27435 trying to use dvd player says unusable signal
Most DVD players and maybe the Wi are connected via rear audio and video input jacks so that may be your issue.
Jun 11, 2012 | RCA F27442 27" TV
I have a LG47" tv
Your DVD audio is sent directly to your receiver - not to you TV. That's why you can hear the audio on your stereo. The TV audio is not being sent anywhere - it is "stuck" in the TV and is amplified and sent to the TV speakers. Since the TV speakers are off, you don't hear anything. In order to listen to the TV audio on the stereo system's speakers, you need to send it to the receiver.
You need to have a pair (left + right signals) of audio cables (assuming you wish to listen to stereo sound) from the TV's Audio Output jacks to a pair of Audio Input jacks on the receiver / amplifier. You can use any unused input - CD, Video, Tape, Sat, etc. If you use Tape or Sat audio inputs, when you wish to listen to the TV audio, you must select the Tape or Sat input on the receiver.
Do not send more than one signal to a set of inputs on the receiver. Typically, a CD, DVD and Sat inputs offer two or more of the following types 1) Analog audio. These are the older RCA jacks that have been around since the beginning and require separate cables for left and right channels. 2) Optical inputs. This is the newer digital interface that provides for Dolby Digital (and others) format sound over a single fiber optic cable. 3) Coaxial inputs. This jacks looks like an RCA jack, but usually has an Orange ring - instead of the Red & White rings that analog RCA jacks have. They use a single coaxial cable. 4) HDMI input. This jacks carries both digital video and digital audio signals. If you are using an Optical input for the DVD on the receiver, do not use any other unused analog or digital inputs associated with the DVD to "piggyback" another device like a CD , VHS tape, etc.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 25, 2011 | Audio Players & Recorders
The inputs on my RCA scenium dlp tv wont work.
It sounds like your talking about the ITC222 chassis series which is having a small signal board problem. Very common in the RCA ITC222 and ITC222A Chassis HDTV's
Jul 12, 2010 | RCA Televison & Video
Pioneer Elite Pro-118 rear projection tv
ya mine did something close to the same. at the moment i covered the blue canon inside the tv now the picture isnt 2 of eveything. the tv comes apart easy from the front good luck mike
May 02, 2010 | Pioneer PRO-200 60" Rear Projection...
Sharp LCD flat screen TV turns on with a grey screen
Whats happening is that the TV' sets of today are really PC's dedicated to a TV tuner..sort of.. As such, well PC's, hang up, get into "Loops" and the like. Also as such they need to be "Reset" to clear any faults, now sometime the circuit called the P.O.R. "Power On Reset", well, it doesn't... and it often takes a couple of "Reboots" to clear the "Fault".
Feb 04, 2010 | Televison & Video
RCA L26W11 26 in. HD-Ready LCD Television Logo
27 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
