Back to:
Tags:
Sharp R-1610 / R-1611 / R-1612 1000 Watts Microwave Oven
Hood lights will not dim or turn off
posted by Wojo on Aug 27, 2006
My Sharp R-1611 microwave hood lights will not dim or turn off when I push the button on the control board. Any Ideals?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Nov 02, 2006
Helpful (85)
MicrowaveSvc
Rank:Guru Guru
Rating: 87%, 2997 votes
The problem is damage to the control circuit board.
This damage happens usually when the lamps are removed or installed without disconnecting the oven from the power line first.
We regularly repair these boards for this very problem for customers from across the country for $32.50.
We have an important file called "safety.txt" which you can find by a doing a search for "microwave safety.txt" on Yahoo.com.
It's important information to consider before proceeding.
Comment by MicrowaveSvc, posted on Nov 05, 2007
I wanted to give an updated answer, since this is such a popular post:
The problem is almost certainly on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Hood lights will not dim or turn off:
I don't want to Accept this solution
Can you Help with these Microwave Ovens problems?
Microwave Ovens
Sharp Microwave Model #R4A83 was on briefly when I pushed...
Microwave Ovens
I have a GE model JES1358WL01 microwave. There is power,...
Microwave Ovens
Goldstar MV-1500, over range microwave stop microwaving. ...
Sharp R-1610 / R-1611 / R-1612 1000 Watts...
all numbers are shown only, either top half or bottom half
Dear All , I have a Sharp Microwave model R-340D ....
Loading problems.
Repair Service
Find Microwave Oven Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
