Question about Canon PIXMA MP160 All-In-One InkJet Printer
Reset my printer canon pixma mp 160
How to reset my printer canon mp 160
  • hamimah May 11, 2010
    resetnya mp 160
  • Anonymous Mar 27, 2014
Posted on Oct 28, 2008
Canon Help said press Black or Color ink button to reset.
Oddly this works
Posted on Jan 13, 2009
3 Suggested Answers
  • 4041 Answers
SOURCE: canon pixma mp 160 all in one printer
Hello try it may work
The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings.
From what I gather, it’s both a time consuming and expensive proposition to take to Canon to fix.
And they won't tell people how to do it themselves.
Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free.
You have to be slightly mechanical to do this.
If you you've never used a screwdriver and are all thumbs, but give it a shot or give it to someone halfway coordinated to do this for you.
You may RESET the printer code first if you like or do it after you clean the pad
Here this step by step to resetting waste ink counter printer Canon Pixma MP130
1.You will include printer
2. Press button MENU, then SCAN, COPY and again SCAN - they entered
into the service regime
3. Select NVRAM ACCESS and further BY OK.
4. Select SET Abs- m level and advance value equal to zero
5. Select SET Abs- r level (if there is) and also you will establish into zero
6. You will turn off printer by button POWER.
Posted on Feb 08, 2010
  • 70 Answers
SOURCE: Error code 22 in canon pixma mp 160
reinstall ur printer driver
Posted on Mar 11, 2010
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
How to fix an error O7P of 258 pixma canon printer?
In order to reset ink in canon pixma mp258 printer, press the reset button present on the canon mp 258 printer after you have refilled the ink cartridges of your canon mp 258 printer.
Jan 19, 2011 | Canon PIXMA MX310 All-In-One Printer
Canon MP140 Error Code injet printer reset procedure:
Canon waste ink tank problem.
1. Change the waste ink absorber
2. Reset waste ink tank counter
Go to the service menu;
1. With the printer power OFF , press the Power button while pressing and holding the Stop/ Reset button.
2. When the Power is ON, hit the Stop/Reset button 2 times while pressing and holding the Power button.
3. When releasing the Power button and the Stop / Reset button , the printer will go into a service mode.
4 When the ON-OFF lights in Green, hit the Stop/Reset button the specified number of times according to the function listed in below.
Each time the Stop/Reset button is pressed, the LED lights in orange and green, starting with orange.
Hit 4 times for waste ink counter reset.
The number of the Reset button pressing LED
0 time ... Green Power off
1 time ... Orange Service pattern print
2 times ... Green EEPROM print
3 times ... Orange EEPROM reset (EEPROM reset)
4 times ... Green Waste ink counter reset
On the end press POWER button to exit .
FOR USE IN : Canon PIXMA iP1200, Canon PIXMA iP1600, Canon PIXMA iP1700, Canon iP1800, Canon PIXMA iP2600, iP6210D, PIXMA iP6220D, iP6310D, Canon PIXMA MP140, Canon PIXMA MP150, Canon PIXMA MP160, PIXMA MP170, Canon PIXMA MP180, MP210, Canon PIXMA MP450, MP460, MP470, Canon PIXMA MX300, Canon PIXMA MX310, Canon PIXMA MX470
Jul 31, 2010 | Acer Office Equipment & Supplies
When I use the ''print'' command, I get the following message on my screen, ''The ink absorber is full'' Contact the service center. My printer is a Canon PIXMA MP 160. What can I do to get past this...
You have to reset waste ink counter using MP Tool. Try to find at Or you can do it manually. Try this. 1. Unplug power 2. Press and hold ON/OFF button 3. Press and release Stop/reset button 4. Release ON/OFF 5. Press Stop/reset 4 times Turn off printer and turn on.
Nov 13, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Error Code 5 on Canon MP160 Printer
your problem is waste ink absorber is full,you need the canon mp tool which is use to reset the counter of your printer,but you must dismantle your printer to clean the waste absorber because if you will reset the counter without cleaning it, all waste ink will overflow on your printer.
Apr 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printers Problem Canon MP 145 code E27
Try this fix.....CLICK HERE
It works the same for the Canon MP 150 or MP 160
Jan 25, 2009 | Canon PIXMA MP160 All-In-One InkJet...
I want to know if I can print without USB using my wireless, I have a Canon pixma mp160.
Canon Pixma MP 160 do not support Wireless Interface
So you will need to connect it to USB port in order to print the documents
USB 2.0 Hi-Speed3
Direct Print Port
Specifications for Canon MP 160
You can refer the Canon MP 160 Manual for further inofrmation
I hope the above resolves your query
all the best
Do rate the Solution, as we can guide others accordingly
Thanks in advance
Jan 04, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Installation CD for canon pixma mp160
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
Dec 11, 2007 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
1,617 people viewed this question
old marine
old marine
