Dislex prestige dish waser is stuck on empty
It completed rinse cycle and now the pump to empty the water operates continuously. and none of the controls will shut it of, even opening the door won't shut it off.
CMV9
  • 594 Answers
SOURCE: fwt449gfs2 washes, empties some water, does not spin, knob does not advance
i would check the timmer. run it through a cycle and when it stops slightly move the timmer ahead. if that works than you need to replace the timmer... i had a washer that did that and it turned out to be the timmer on mine.
Posted on Aug 06, 2008
  • 5 Answers
SOURCE: Ariston AML125 won´t spin or empty water.
Dislodge the white covering infront (just located at the bottom). Once opened, unscrew the black button at the right hand side. Once open, check for blockages like coins, loose items, even lint. This worked for me and saved me $$$!!!! Now my Ariston is back to its superb performance. Do read the manula once in a while, it does help!
Posted on Feb 07, 2009
  • 9 Answers
SOURCE: model GHW910PWO shuts down during the rinse,spin cycle
First, pressing cancel twice should clear the error code and it should restart when you press start. Then you can press cancel to stop the whole thing This should also unlock it. Unplugging it for a long while may also clear the code and unlock the door, not sure.
the F-9 says it is an overflow condition and may need to be serviced. The F-11 says there is a serial communication error.This might be the case if the pump is running overtime due to clogging.
 See  http://appliancejunk.com/forums/index.php?topic=1785.0
To check if the filter is clogged, open the front panel, put a bucket in front of the unit, unseat the rubber feet holding in the white plug,  pull the white plug out so when you unscrew it, any water will run into the bucket, then unscrew it and clean the filter. screw the filter back in, set the white plug back into the unit, being sure to secure it with the rubber feet.
As for it stopping, you may be filling it too heavy and the motor stopped if it over heated?
Posted on Apr 24, 2009
  • 353 Answers
SOURCE: won't complete cycle get an F 21 error
check your filter
Posted on Jun 11, 2010
wpcustomer
  • 362 Answers
Creating cleaner, more efficient homes
    Verified Fixya Pro
    SOURCE: My Maytag Neptune front load washer continues to fill with water.
    For troubleshooting assistance please click on the following link
    http://maytag.custhelp.com/app/answers/detail/a_id/2027/kw/continues%20to%20fill/p/293/r_id/108284
    Posted on Jul 17, 2010
    Oko 72630. Why is it stuck on rinse cycle?
    Could be several reasons:
    - Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
    - Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
    According to your description I think that this is not a failure otherwise error E20 will be appears on display.
    Once the washing programme has come to an end, END illuminates on the programme progress display.
    If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
    1. After a rinse hold, the water must first be pumped out:
    - Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
    After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
    - Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
    - Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
    At the end of this programme step, the END indicator will illuminate.
    2. Open the door.
    As soon as the DOOR indicator lights up green, the door can be opened.
    Dado
    Aug 15, 2015 | AEG Washing Machines
    Cycle starts, but does not fill with water
    When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
    Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
    Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
    Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
    If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
    You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
    Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
    Jul 23, 2011 | Dishwashers
    The dishes, glassware and sliverware do not look clean when they come out. The dishes are oven scummy with something stuck on, the glassware has an all over film or film and blotches, the silverware is...
    There are 3 standard answers to solving the white-deposits-on -dishes problem: 1) Use a rinse aid; 2) use less detergent; 3) use vinegar in the washer. If you have hard water, none of these may work, especially if you've had the problem for a while. Because phosphates were ordered removed from dishwasher detergents, hard water minerals can now react with the soap to create a heavy greasy-feeling scum. That scum can build up in the water lines, arms, bottom reservoir, and filter, providing an endless supply of goo to spray on your dishes. This can be fixed. You need to remove and clean out the spray arms, the filters, and especially the array of parts at the bottom of the tub. I've seen up to 1 cup of coagulated/crystallized scum in the bottom of dishwasher tubs. Once you clean out the scum, then run the washer empty with a completely full detergent cup on the highest temperature setting, extra rinse. Before you start it add to the detergent cup 1 teaspoon of TSP(tri-sodium phosphate), a very powerful phosphate cleaner available at hardware stores. Your washer will now have all scum gone from the inner workings. From now on you must always fill both your detergent and pre-wash cups to the max and use a high temperature water setting, extra rinse. Chemically what you're trying to do is add so much detergent that the scum-forming reaction is overwhelmed by the dispersant action of the detergent, and the extra heat helps this to be more effective. I am not a fan of vinegar in the wash cycle. Why? In some washers the vinegar fumes can reach the exposed contacts of the printed circuit board or touch pad, corrode them, and then your washer won't work at all, along with being very expensive to fix.
    Nov 15, 2010 | Whirlpool 24 in. DU927QWD Built-in...
    The wash cycle runs and runs.
    Most diswashers have a complete cycle that lasts over an hour. The machine fills with about 1.5-2 quarts of water, rinses the dishes for a few minutes, then empties the water, then fills again with new water and rinses for a few more minutes, then empties. This is to get a good bit of the looser gunk off the dishes, and to soften up any other stuff that has dried on there. Then the machine fills a third time, the soap door pops open, and it washes for a much longer time to hopefully dissolve away pretty much anything left on the dishes. Then it empties, and does a rinse the soap off cycle, and usually a final cycle that rinses again with a little bit of rinse agent to help them dry quickly.
    The whole process uses about 2 gallons of water.
    Sep 14, 2009 | Dishwashers
    Dishes not completely clean or rinsed, and mold
    get some dishwasher salts and unscrew the cap at the bottom of the dishwasher empty the filters and run the cycle. fill up the water with dishwasher salts in the white unscrewable cap put about two cup fulls in.there it should work better then. there is also a product called rinse add you can by this from the local supermarket. hope this helps
    Mar 27, 2009 | GE Nautilus 24" Built-in Dishwasher
    Fisher paykel will not complete rinse spin cycle
    will sence it will spin once the water is out .that must mean your pump is restricted.unplug go to buttom of washer find pump and clean out
    Dec 31, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
    Water left after finishing wash
    I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
    I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
    I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
    Please assist.
    Reagrds,
    Brian
    Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
    Whirlpool Ultima Wash II Intermittent Rinse/Spin
    Hi, the water not drain , the drain pump was stuck , causes are the small linen and other foriegn materials are bind the pump infeller , pump connot completely turn . so drain stuck need to clean , also the drain hose have sedimentation of soap and dust.
    Feb 03, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Washing Machines Logo
    22 people viewed this question
    Top Washing Machines Experts
