Question about Gateway GT5694 Desktop Computer
Gateway with 2 data ports
Trying to hook up an second monitor to the second data port, It was covered with a note that read, connect monitor to alternate video port, see setup poster for instructions,,however i don't have any such poster any more.. thank you, Moby
  • Gateway Master
  • 5,477 Answers
The "Connect monitor to alternate video port" message suggests that it is the motherboard video port. Since your computer has a video graphics card, the motherboard connections are disabled in the BIOS. (This avoids conflicts.)
Many video cards have several display ports each of a different type (VGA, DVI, HDMI, DisplayPort (less likely on a low-end desktop)) . Some of these cards can drive two monitors at the same time. Look at where your current monitor is connected, then consider an adapter to connect the second monitor to that video card. (For example, a DVI to VGA adapter will let you connect a VGA monitor cable to the DVI port.) Some DVI ports will let you run two monitors from the one port with a splitter.
Gateway has support documents for their computers here: http://support.gateway.com/us/en/support/default.aspx . You'll need to use the model number and look for the User's Guide, Top Answers and support documents tabs.
The only way to use the blocked port would be to enable it in the BIOS (usually press F2 on start up for Gateways). Press this key repeatedly from power on until it responds. I frequently miss the timing, just shut down and try again. However, first you would need to remove the graphics card drivers (uninstall program (Catalyst for AMD/ATI) and the drivers) from your Windows OS. Then remove the graphics card from the desktop. Since this requires opening the computer, you will need to be careful to remain grounded relative to the computer. (Use a ground strap or work carefully touching a metal surface of the case.)
Please add a comment with your computer's model number and I'll be glad to give you specifics on running two monitors from your system.
I hope this helps.
Posted on Feb 21, 2012
I want to know how I can re-set my 3Com 3crwe955275 wireless access point to its default factory settings. Can anyone help?
1 Remove power from the Gateway. 2 Disconnect all your computers and the cable/DSL modem from the Gateway router. 3 Using a straight through Ethernet cable, connect the Ethernet Cable/DSL port on the rear of the Gateway to any one of the LAN ports. 4 Re-apply power to the Gateway. The Alert LED will flash as the Gateway starts up, and after approximately 30 seconds will start to flash more slowly (typically 2 seconds on, 2 seconds off). Once the Alert LED has started to flash slowly, remove power from the Gateway. 5 Remove the cable connecting the Cable/DSL port to the LAN port, and reconnect one of your computers to one of the Gateway LAN ports. 6 Re-apply power to the Gateway, and when the start-up sequence has completed, browse to: http://192.168.1.1 and run the configuration wizard. You may need to restart your computer before you attempt this. 7 When the configuration wizard has completed, you may reconnect your network as it was before
Here on page 85 of the manual
3Com 3CRWE53172 User Manual Forgotten Password And Reset To Factory...
Feb 18, 2015 | 3Com Computers & Internet
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
The 2 right (monitor's right) usb ports are not working, is there a fix
did you attach the usb cable from the computer to the monitor, needs this for powering the usb ports and to transfer data to the computer?
Dec 14, 2010 | Gateway FPD2275W LCD Monitor
I am trying to hook up a Samsung WIS09ABGN LinkStick Wireless USB 2.0 Adapter to a Samsung BD-C5500 Blu-ray DVD player. In going through the setup process after I set up the router connection which...
To resolve issues with the Internet Gateway connecting to the MyQ server
1. Determine if you can connect to the Internet using your computer. If you cannot connect, proceed to step 2.
2. Reset the router. Unplug the router for 30 seconds and plug back in. It can take a few minutes to reconnect to the internet. If you still cannot connect to the internet, contact your Internet Service Provider before proceeding.
3. Move the Internet Gateway ethernet cable to another port on the router. Put it in one of the ports on either side of the current position on router. Make sure that the Internet Gateway is plugged into a LAN port, normally numbered 1-4. Proceed to step 4 if none of the ports work.
4. If you are using a modem and a router, disconnect from the router and plug the Internet Gateway directly into a LAN port in the modem to bypass the router. Note: This will turn off the internet to the rest of your home network temporarily. If this works:
5. If step 4 doesn't work, power cycle your home's internet modem, it may need to be restarted to provide a new IP address to your network.
6. Perform a Soft Reset on the Internet Gateway. This renews the IP address with the router. The LED lights will blink like a normal power up. To perform a soft reset:
1. With a safety pin or paper clip, press and hold reset button while the Internet Gateway is still plugged in.
Note: The reset button is located on the side of the Internet Gateway in a recessed hole.
2. Hold the button in until you see a yellow LED light blink and release.7. Perform a hard reset on the gateway. This deletes all the devices and renews the IP address with the router.
1. Unplug the AC adapter from the gateway.
2. With a safety pin or paper clip, press and hold the reset button on the side of the gateway.
3. Plug the AC adapter back in while continuing to hold down the reset button until the yellow LED light blinks.
Dec 08, 2017 | Samsung WIS09ABGN (8808993304486)...
Monintor does not read sd card or usb with inserted on monitor.
you need to connect a usb cable on it and attache the otehr end on the usb port of the comp
Mar 03, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Ethernet port is ''locked'' dsl modem
reset your router to factory default....look for a small button on the router and keep pressing it until all the lights blink together at once.....do reply back
Nov 11, 2009 | Computers & Internet
When I hook up my Xerox WorkCentre to my computer the printer doesn't work. I have tried two different routers. Everything esle works but the printer.
hi
check the ip address on xerox and computer both have to be the same and if u want our technician support contact us at http://tinyurl.com/ldnuy2
Jun 21, 2009 | Xerox WorkCentre M20i All-In-One Laser...
I recently bought an ASUS external monitor to use in parallel with my Gateway laptop. The external monitor will stop working (go blank, but remain on) after about 30 seconds when I plug it into my...
Is it a BRAND NEW monitor? The only way to be SURE your VGA port is bad really, is to see if it does the same thing with a completely different monitor. What I'm getting at is it could be the monitor itself. Maybe the monitor has some kind of "sleep" mode set? (There is such a thing as brand new AND defective. It's not common, but it does happen.) See if you can get the manual for the monitor, and read up on the different applications this one has. Most monitors have multiple ways to hook up. On the other hand, if your VGA port IS defective, it's probably safer to send out for repairs than replace the port yourself, unless you happen to be an accomplished solderer/electrician.
Hope this helps.
Apr 15, 2009 | Gateway FPD2275W LCD Monitor
I have a new Dell Studio 540 computer and I'd like to hook it up to my Gateway EV910 monitor. I connected everything correctly. The monitor has power, turns on to the monitor self test screen where it...
You dont need to install a driver for the monitor. The power save mode message appears when the monitor is not able to get a signal from the computer. Make sure the the vga/blue cable is securely plugged to the back of the pc.
note: Inspect the back of your studio. You may have two blue ports where you can connect the monitor, if you do, connect the monitor to the one at the bottom half of the computer.
Jan 02, 2009 | Gateway EV 910 19" CRT Monitor
I have a Gateway mx3422 notebook. I cannot get the display to clone when I hook it up to a projector. The notebook screen goes black and the display shows on the projection screen.
hi!!!
there is a setting in your desktop
try go into control panel
then click on display then go to
settings and the
advance try locate the dual monitor settings
Oct 31, 2008 | Computers & Internet
Gateway GT5694 Desktop Computer Logo
114 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
