The processor has nothing to do with it. Definetly your system is infected by a virus or a trojan or spyware.Please download free antivirus like QUICK HEAL and make a thorough scan.
If this doesnt solve, the IC [circuits] of your chipset might be overheating.The general symptom for this is the computer freezes and refuses to perform any tasks after few minutes of loading the os.
First please make a scan and also post the picture of your taskmanager showing the different processes running.
Computer's speed [whether it be a desktop or laptop, whatever be] depends on many things. Even with the highest core speed computers too can hang, and go with little speed. In your case, it will be best to contact the authorized service center, or any skilled computer technician to resolve this problem.
In most cases, a re-installation of the O/S will resolve the problem. Anyway, contact the authorized service center. It will be best. http://electronicshelponline.blogspot.com/
I think you have installed too many applications/software in your system. In some cases, laptop becoming really hot that cause in slow processing and hanging.
Here are two programs to help you keep your HDD clean.and moore memory would help the computer.at last remove all programs you never use and them you rarely use.
First of all you should have loaded the 64bit version of Windows 7 on that machine. Second, slow response could be several different problems. The most likely culprit is that hard drive is failing and needs to be replaced.
The answer to your first question is yes, your computer is compatible with the MAC OS. However it is very important to continue to ask this question to the MAC Salesperson you deal with when purchasing the software.
The answer to your second question is to do with Heat. Your computer is overheating and is therefore slowing down so it does not fry your CPU. You need to ensure that the Processor Heat sink is making proper contact with the CPU and the fan is connected to the computer main board. Clean the computer of all dust and install as many fans as your computer chassis will allow.
I think this chassis supports up to 80mm fans.
A well cooled computer chassis will work efficiently and effectively.
The Cooler Master Geminii S CPU cooler is a very good CPU cooler for your Processor.
It will reduce the temperature of your Processor by several degrees.
It is very important to get as much, cooler fresh air into your computer chassis as possible. As this will mean that your computer system will run at a far cooler temperature.
Goto BIOS of your computer and enable " QUICK BOOT" it will solve your problem. Plus i would personally recommend you to Format your C:\ Drive and reinstall windows (Windows XP SP2 is the best option for fast performance). After you install Windows i would also recommend you to Install any Anti-Virus and Scan your computer for viruses.
if your system go slow as well as hangs while playing the games only you can get the external video card for the computer because the integrated video card's graphics resolution is not high & the games demands more...
It is probably because your internet connection is slow or you lack bandwidth. You have a fast computer and if you've wiped the hard drive and reinstalled windows then its unlikely that it is a windows problem. Also if you're using a modem instead of a dedicated connection they do tend to be rather slow managing only up to 56k per second.
