Question about Home Security
Pearpoint p371 cctv camera user manual - Home Security
My CCTV is showing hacked on the cameras. How do I reset my password
Your CCTV is connected via an Internet connection.
I'll recommend to isolate the network devices from the Internet before continuing.
This is covering only basic steps, I recommend to get the instruction manual for the CCTV and read it.
  1. Enter the administration section of the CCTV recorder/DCR/NVR by entering your admin account name and password.
  2. Go to the admin setup of the CCTV. Search for overlay and verify if the hacker inserted text on the overlay feature, if you don't use overlay, disable it.
  3. Then check each camera name tags in the admin section. Change the text if it was hacked.
  4. Change the password for the CCTV DVR/NVR/Camera, I bet it was never changed. Write the password down and store it in a safe place.
  5. Last option: If you can't find the place do a factory reset of the DVR/NVR/Camera. (Do make a backup before a factory reset to an external device if possible).
  6. Once the factory reset is done, you will have to reconfigure the recording options for each camera.
  7. Last point after the factory reset, change the admin password.
Are there other devices sharing the Internet connection with the CCTV?
If this answer is YES, then check them for hacker breach.
  1. I'll recommend to increase the security on the Internet Router.
  2. Any device sharing the Internet with the CCTV should be checked for breaches and made secure.
  3. Speak to your ISP and ask for assistance if you have a fixed IP address to your CCTV system. Ask them for advice. Layer 7 routers are more expensive but more secure.
  4. Load all updates for any devices!
Get an IT security expert to assist you with the breach if necessary.
Sep 29, 2017 | The Home Security
Close circuit TV
Have you got the user manual ?
http://www.samsungcctv.pl/instrukcja/00769B_SHR-8162_ENG-NEW-0105-web.BM%281%29.pdf
Have you connected a monitor to the DVD device ?
Single mode would stop video from rotating through each camera
Jan 11, 2015 | Samsung CCTV-GVI SECURITY SHR-8162-1T 16CH...
I bought 2 outdoor CCTV.camera RV537B with night vision. one of the unit has not functioning properly on night. i tested it by covering the photo cell that switch the LED lamp which is ok but it seems to...
I think I answer you question--when?? Take the good CCTV camera and hook it up to monitor. Then hook up the CCTV camera and turn it on. Point the working CCTV camera at the bad camera that is turn on. Now, look at the monitor which is working with your operational camera. Look at the bad camera while it on, and see how many IR LED's you can see on the bad CCTV, while it turn on. You should be able to the IR LED glowing red. If not, then there is a problem with bad CCTV IR LED's. Short wire, no power to the IR LED's. stewbison
Jun 24, 2011 | Optics
I changed the admin password on my sentient cctv dvr from the default 123456. I saved the changes but now get the message incorrect password when I input the six digit password I stored. Please help
Hello
After system boot-up, hold a right mouse click
button and there will be login window. Hold a left
mouse button to click the order of "Account", and
input correct account. Then left click the order of
"Password" and input correct password. At last
left click "Login" to enter system. There is one
factory-preset login "account/password"
"admin/111111" at admin level. The user can
use it to login the system for the first time
May 22, 2011 | Ganz DR4NC-160 DVR DIGITAL VIDEO RECORDER...
Sentient 250GB DVR-RW CCTV N63HH - recording for longer peroids
Just reduce the frame rate slightly on each camera or the record quality and it will increase the data retention period.
Jun 14, 2010 | Dome 4 CCD CCTV Camera Surveillance...
NEED USER MANUAL FOR LOREX 4CH MPEG 4DVR
Check the exact model of the dvr and get your manual here
Cheers
TeaCii
If you own website, addlive support almost free
Realsecurity guard to watch your cctv for $1/day
Apr 12, 2010 | Lorex 4 Channel Home Surveillance System
User Manual for KTL CCTV 4004
I located a copy of the owner manual under the brand name of AVC model 760AS - apparently the same model as the KTL CCTV 4004, just another name sticker.
http://scorpiontheater.com/Documents/AVTech_AVC760AS_Nubix4ST_manual_V0.95.pdf
This is only valid for the KTL DVR unit model 4004 - not any VCRs.
Sep 25, 2008 | Ktl TLR1280 VCR
Home Security Logo
285 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
