Question about SanDisk Electronics - Others
My 8GB sandisk memory card show unlocated space nd every time when i connected to my lapi it always required format. pls tell me the solution to make my card working properly
Harsh.smarty1990@gmail.com mobile no. 9999867838
  • 23 Answers
SOURCE: PC does not recognize SanDisk Ultra II 8GB memory card.
install the usb drivers 3.0 it wi;l solve u r problem...........
Posted on Oct 06, 2009
athouba239
  • 122 Answers
SOURCE: Bought a new Sandisk 8GB microSDHC card (Product
try formatting ur card with the following steps:
right click om my comp then click on manage then disk menagement and right click on ur card then format it will forcely format ur card. gud luck....
Posted on Oct 19, 2009
P0W3R GL1CH
  • 185 Answers
SOURCE: Sandisk U3 Cruzer Micro 8Gb Cant Format :S
rite click on it in mycomputer and click propertys to see if your thunb drive even has memory on it could have ben fried by sum and has no memory now
Posted on Nov 07, 2009
  • 28 Answers
SOURCE: how do i format a 8gb sandisk microsdhc card to my
Use an adapter to put it in your PC, then use the windows format tool to format it as FAT32.
Posted on Nov 13, 2009
steve_e_uk
  • 1675 Answers
SOURCE: how do i format my sandisk 8gb m2 memory card to
hi are you formatting it as NTFS? windows xp, vista and 7 format using the NTFS format, try formatting it in fat, or fat32 this could be the reason it is not working....hope this helps
Posted on Mar 18, 2010
Hi I have 8gb Transcent Micro Sd Card that is encounted a problem when i m downloading using 5130. After that its not opening Its Says that not Formatted. when i insert in to my pc only showed my card...
If there are hidden partitions on the memory card, Windows 7 will not allow you to change the partition. So to format use a PC with windows XP or older. You also could format this card in most camera's. For that place the card in a SD adapter and put it in your camera. Let the camera do the format.
When you put the card back in the phone, make sure you first format the card with the phone software. Just to be sure the phone can read and write the card.
Jan 15, 2014 | SanDisk 8gb Micro Sdhc Memory Card Bundle...
My sandisk 8gb pendrive is showing o bytes as its space
It may need to be re-formatted. That is if there is no accessible data.
You can also check for hidden files, by setting you folder options to show all hidden files.
Round radio button on pic.
Sep 25, 2012 | SanDisk Electronics - Others
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    I can't open/ format my 8gb sandisk mdhc..i've tried several app to format it..and it always end up to have ah error in formatting..the other app said it is write-protected..and the size shows only 30mb
    Hi there
    1. 1 Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
    2. 2 Open up 'My Computer'. You should see it under the list of available drives.
    3. 3 Check its contents first to make sure that you have the right drive.
    4. 4 In 'My Computer', right-click on the drive and choose 'Format'.
    5. 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
    6. 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
    May 20, 2010 | SanDisk 2GB microSD Memory Card
    My 8gb microSDHC memory card fits in my phone, but no memory card shows up
    The memory card may have to be formatted for the phone with the phones format procedure via the PC and the proper software.
    Apr 19, 2010 | SanDisk 8GB microSDHC Memory Card with...
    I CANT FORMAT IT IM USING WINDOWS I HAVE AN 8 GB SANDISK SDHC CARD ND IM TRYING TO ADD MUSIC TO IT ... IT SAYS THERE IS 0 MB LEFT ON THE CARD ITS BRAND NEW !!!
    LLFTOOL is a utility for low-level disk drive formatting,
    also supports formatting of FLASH cards using a card-reader.
    1. Download this tool:
    http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
    2. Format card
    (WARNING: After running this low level format tool,
    the whole USB flash disk surface will be fully erased.
    Therefore, data restoration will be impossible after using this utility!)
    Feb 06, 2010 | SanDisk 8GB microSDHC Memory Card with...
    Bought a new Sandisk 8GB microSDHC card (Product Description : Micro SD/8GB SDSDQ-8192-P36M) for my Nokia E51. It worked fine for two months, in this had many times used in PC with my card reader for...
    Oct 19, 2009 | SanDisk 8GB microSDHC Memory Card with...
    I have a SanDisk Cruzer USB 8GB that is only allowing me 1.33 GB of space - says 6.594 GB used and there's nothing on here - how do I gain that storage space back? tx
    There might be a hidden file(s) on the drive that are taking up that space. Open the drive in My Computer, click Tools > Folder Options... On the View tab, click Show hidden files and folders. Then check the drive to see if any hidden files or folders are present.
    You can also try formatting the drive. Right click the drive in My Computer and click Format...
    Mar 23, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
    Formatting troubles for a 8gb Sandisk Micro SDHC
    Hi Tony,
    Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
    Rob
    Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
    Electronics - Others Logo
    24 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Piyal Perera
    Piyal Perera
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
