Question about Russell Hobbs RH-MC1 Mini Chopper Food Processor
110cc engine has no kick start compression how do i fix it?
Ive rebuilt a 110cc chopper engine and the kick start has no compression, can i get a diagram somewhere or have i missed something out putting it back together?
  • Neale Gray Feb 21, 2012
    Have you done a compression test yet?Does the motor turn over ?
  • Tane gibbons Feb 21, 2012
    no ive just got the 2 bikes and have made 1 good 1 out of them, how do i do a compression test? im still tryna figure out how to connect the electric start aswell,
I need replacement chopping blade. Help please
You should be able to do a search for your particular manufacturer and model food processor using one of the search engines. For example if you are looking for a Cuisinart model CH-4-DC chopper blade enter the search terms Cuisinart Model CH-4-DC chopper blade replacement in your search engine. Amazon is usually a pretty good place to start.
Mar 29, 2015 | Food Processors
The housing with 2 blades is cracking. It has not had heavy use just soft items I is a ultimate chopper. How can I get a new replacement.
You cannot buy spare parts. Like many such products promoted on tv home shopping channels it's a poorly made overpriced item with no aftersales care.
Sorry, but your only fix is to replace the chopper with a better one where more than half of the price isn't used to pay for over-the-top adverts.
Jul 28, 2011 | As Seen On TV Ultimate Chopper Food...
NEED TO BUY A NEW REPLACEMENT ULTIMATE CHOPPER
I did some additional web searching due to the fact that the Ultimate Chopper website or 1-800 # doesn't support this product anymore. I located a website (Maxi-Matic, USA) that has an identical Ultimate Chopper (names Super Elite Cuisine Chopper) - model EC-750 - Phone # (626) 912-9877. They have replacement parts including the clear plastic cover lid.
Oct 25, 2009 | Ultimate Chopper Food Processor
Broke a hole in the chopper dish
If still interested in a replacement parts for the Ultimate Chopper - there is a website called TV Time Direct - http://www.tvtimedirect.com.
Their phone # is 800.238.7119. On their website, use the Quick Find option (upper right corner) - type in Ultimate Chopper and it will show the replacement list for this item.
Jun 14, 2009 | Ultimate Chopper Food Processor
Help
Ultimate chopper is still in business and direct sells from their own website. This link will take you there:
http://www.ultimatechopper.com/
Jun 11, 2009 | As Seen On TV Ultimate Chopper Food...
B&D 2-spd chopper SC400 will not start
Thanks for the follow up.
I managed to find a manual online and was able to figure out my problem from there.
Jan 03, 2009 | Black & Decker SC400 Super Chopper 2 Cups...
On the KitchenAid 3 cup Chef's Chopper, How do you lock the blade so I can turn on the chopper?
The Kitchenaid food choppers have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
Dec 29, 2008 | KitchenAid KFC3100 Chef's Chopper Food...
Ultimate CHopper won't start
greeting from belize.first of all check the cord if it is broken,if not your switch is broken or burn replace the switch.if that does not work it is time to take it to a repair man.the equipment can be repaired if parts are available.good luck.but you can send your the digital picture let me see if i can help you my email is nicodhem@yahoo.com
Mar 23, 2007 | Ultimate Chopper Food Processor
Russell Hobbs RH-MC1 Mini Chopper Food Processor Logo
100 people viewed this question
Top Russell Hobbs Food Processors Experts
ray gallant
Tom Chichester
Are you a Russell Hobbs Food Processor Expert? Answer questions, earn points and help others
