Question about Hampton Bay Dryers
Fan switch are LJY-280A and E198635
The fan switch is broken
  • Vanessa melgar Feb 21, 2012
    where can I get the 4 speed fan switch... also the side switch
    New Friend:
I have a Hampton Bay indoor/outdoor ceiling fan with 3 speed fan switch WU Pin LJY280A, E198635. It is a L-3-1-2 (ccw) switch with purple, grey, black and brown wires. The wiring is different than most on web. The L is not black, 2 is black. My wiring for the switch is L-Purple, 3-Grey, 1-Brown, 2-Black.
Found schematic on web that I think is correct:
Off-none,
Hi-L,1 4uF,
Med.-L,2,3 10uF & 4uF,
Low-L,3 5uF & 4uF.
I hope this helps someone.
Posted on May 15, 2017
How do you open a wu pin switch. the chain broke & went inside switch
My chain was broken about 1.5 - 2 centimeters inside the wu pin. I took a chain connector (with some chain hanging off one end) and fed it into the hole, trying to connect it to the broken chain. After a couple of tries I managed to get the end of the broken chain inside the wu pin to connect to the chain connector by gently pulling down once it was somewhat inside the chain connector. I hope this works for you. I was so glad I didn't have to resort to cutting any wire or making a trip to a home improvement store!
Jun 13, 2011 | Westinghouse Electric Westinghouse...
Thermo fan will not work on 1996 klx 650, when engine is running or hot, there is a wire to the sensor and another which is broken, beside it. Should the broken wire be connected to something? If so, what?...
Hello;
Let's figure this out. Broken or otherwise disconnected wires usually cause an open circuit preventing adequate current to a componant. Two wire switches act as light switches do. they either close or open a circuit.In this case, the warning lamp or fan relay is ativated when the temp rises. Cold, the circuit is open/ broken preventing any controlled componant from activating.
First check for any power/voltageat the disconnected wire and the connected wire. Which ever wire that is powered is the supply wire. The one without is your controlled componant wire. Touch the two wires together, bypassing the switch. The fan should come on and turn off when disconnected again. Ignition switch needs to be on.Because of the load the fan pulls, a relay is between the fan and switch.
The switch closes powering the relay, then relay close contacts closing a secondary circuit which in turn permits power to the fan. The fan circuit is powered by the battery and controlled only by the relay.
Yuup, two circuits. Switching and fan drive circuits. Yes, Hook the wire back onto the switch after testing as outlined here. Good Luck and remember to always verify power (fusec ondition). _Ned_
Apr 03, 2011 | kawasaki KLX 650 R Motorcycles
Switch broken
May not be identical but an appliance store or hardware store should be able to assist you with that. Home depot or Lowes as well. Take old one with you if you can.
Jul 10, 2010 | Lakewood 200I Floor / Box Fan
The fan switch broken away from dash board Honda Accord 1997
You should be able to buy just the fan switch from Homnda.
May 24, 2010 | 1997 Honda Accord
My ceiling fan, model, 5745, has a broken switch.
ANy electric store will have different switches (lowes and home depot do too) just make sure you bring the old one with you. The colors of the wires shouldn't make too much of a difference just the amount
May 15, 2010 | Aloha Housewares (93645) Ceiling Fan
Switch is broken on my Vornado floor fan, circulating
Hello. Here is the link to Vornado Support. See what a new switch will cost plus shipping before you decide whether to repair or not. http://www.vornado.com/Default.aspx?ISC_PageName=Support
Apr 09, 2010 | Vornado Circulating Fan
Broken on/off switch
YOU CAN GET A NEW SWICTH AT ANY HARDWARE STORE. SHOULD BE A PRETTY EASY REPACEMENT
Sep 21, 2009 | Hampton Bay 30 In. High Velocity Pedestal...
Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Jun 08, 2008 | Dryers
PLEASE HELP with PYLE PLUS GXA-280A
If the ground terminal is connected to a ground wire, the ground wire isn't connected to a good ground.
Sep 24, 2007 | Pyle PLA985R Car Audio Amplifier
Dryers Logo
1,350 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
