Question about Olympus Evolt E510 Digital Camera
My olympus e510 makes a squealing noise when I turn it on.
When I turned on my e510 I get a squealing noise. I havent cleaned the camera sense I purchased it in 2007. Should I send it in or is there something I can do before spending the $200+ cost?
jackboy
  • 2985 Answers
SOURCE: my olympus turnsoff by itself when in camera mode.
Olympus Tewchnical Support- especially if of recent purchase. If an older camera - then simply buy the next one - repair is not an option.
Posted on Jun 18, 2007
  • 479 Answers
SOURCE: Olympus FE-280
1 year warranty on olympus products, but does not cover physical damage such as impact, water, or sand
Posted on Aug 20, 2008
  • 479 Answers
SOURCE: Olympus e510 shutter button locking up
reset the camera through the menu.... put the camera in P mode, menu, right over to card setup, down to custom reset, right arrow, ok, up arrow to yes, ok
Posted on Oct 15, 2008
SOURCE: IR-300 Olympus
I had what sounds like the same problem. The camera was dropped and the shutter was stuck open. Just kept showing error message.
As I felt I had nothing to lose I began tapping it on a soft book and the shutter started to appear. I then shut it just using the end of my finger. When I then turned the camera on again it opened and shut when turned off. It has worked fine ever since.
Seems a rather poor design.
Hope this helps. Very best regards Peat.
Posted on Oct 20, 2008
  • 919 Answers
SOURCE: Olympus E510, Flash Flicker
If you are in a low lit area with the camera dial set to Auto the flash will do a strobing type of flash trying to help allow more light into the scene. This is called the AF illuminator function. To just go ahead and take the image, put the camera dial to P (program Auto) go to Menu - go to Wrench 1 tab - then right arrow over and then down arrow to AF Illum - right arrow and turn this function from On to Off and then take the image in the P mode setting. No flash flicker should occur.
Posted on Dec 15, 2008
Looking in view finder shutter film looks torn?is it an easy fix?
For Olympus Digital Camera repairs, if your camera is still in the one year warranty contact Olympus directly, otherwise, here is a good reliable repair company https://www.teleplancamerarepair.com/Olympus_EVOLT_E-510
repair will include a cleaning.
Jul 16, 2010 | Olympus Evolt E510 Digital Camera
I have a Blank LCD screen and everything else seems to function fine
The problem you are describing is a problem with one of the chips in the camera that controls image processing. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $139.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 15, 2009 | Olympus Evolt E510 Digital Camera
Nov 03, 2008 | Olympus EVOLT E-510 Body Only Digital...
I have an Olympus e510-- it makes a wierd clicking noise when I shut the power off. It also takes pictures on its own for no apparent reason. This is my first SLR so I do not know as much as I probably...
when the IS (image stabilization) is on, the camera will make a noise or vibration when turned off. also you may try to reset the camera using the menu under custom reset... (make sure you are in P mode when resetting camera
Oct 01, 2008 | Olympus Cameras
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
Olympus FL36 flash unit
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see. The flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu, Get hold of your manual or download one My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 29, 2008 | Olympus FL-36 TTL Flash
DIGITAL CAMERA
clean the battery and battery compartment with alcohol and let air dry for an hour before inserting battery
Dec 20, 2007 | Olympus SP-700 Digital Camera
Olympus Evolt E510 Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
